Managing Your Z-Wave® Network
The https://shop.homeseer.com/collections/z-wave-usb-sticks-network-controllers/products/homeseer-smartstick-g-usb-z-wave-stick is a serial interface from HomeSeer that also uses the built-in driver included with Mac OS X (AppleUSBCDC Modem), so you don't need to install any drivers for it. Note that if you move the stick to a different port or if you upgrade to a new OS version you will need to reselect the serial port.
- Choose the
Configure Z-Wavedialog.
Adding a Z-Wave Device
- Select
Using Encryption
- Select
- Select
Edit…button). - Click the
Syncbutton. - When the
- Select
- When the
Deleting a Z-Wave Device
- Select
- Click the
Replacing a Z-Wave Controller
- Select the
- Finally, select the
Z-Wave Menu Options
Manage Associations
Send Raw Z-Wave Command
Stop Inclusion / Exclusion
Reset Z-Wave Interface
