delayAmount | integer | number of seconds to delay before executing the actions (0 for none) |
replaceExisting | boolean | if true then any existing delayed action is replaced by this one |
textToSpeak | string | this is the text to speak when the action is executed |
Complementary Delays
| Complementary Actions |
| Action | Complement |
DeviceAction
kDeviceAction.TurnOff
kDeviceAction.TurnOn
kDeviceAction.Toggle
kDeviceAction.Lock
kDeviceAction.Unlock | DeviceAction
kDeviceAction.Lock |
DisableScheduleAction | EnableScheduleAction |
DisableTriggerAction | EnableTriggerAction |
EnableScheduleAction | DisableScheduleAction |
EnableTriggerAction | DisableTriggerAction |
complementDelay | integer | the number of seconds to delay before issuing the complementary action (0 for no action) - see Complementary Delays for details |
deviceId | integer | the id of the device |
deviceAction | kDeviceAction | this is the command to send to the device |
actionValue | integer or dict | if deviceAction is in [Brighten, Dim, SetBrightness] then this is an integer value |
Device Action Enumeration
| indigo.kDeviceAction |
| Value | Description |
AllLightsOff | turn off all dimmer (light) devices |
AllLightsOn | turn on all dimmer (light) devices |
AllOff | turn off all dimmer (light) and relay (appliance) devices |
BrightenBy | brighten a dimmer (light) device by the amount specified in the actionValue integer property |
DimBy | dim a dimmer (light) device by the amount specified in the actionValue integer property |
SetBrightness | set a dimmer (light) device to the brightness specified in the actionValue integer property |
SetColorLevels | set the color (RGB) and white levels to the values specified in the actionValue dict property |
Toggle | toggle the on/off state of a dimmer (light) or relay (appliance) device |
TurnOff | turn off a dimmer (light) or relay (appliance) device |
TurnOn | turn on a dimmer (light) or relay (appliance) device |
Lock | lock a deadbolt or door device |
Unlock | unlock a deadbolt or door device |
complementDelay | integer | the number of seconds to delay before issuing the complementary action (0 for no action), in this case an EnableScheduleAction - see Complementary Delays for details |
scheduleId | integer | the id of the schedule to disable |
complementDelay | integer | the number of seconds to delay before issuing the complementary action (0 for no action), in this case an EnableTriggerAction - see Complementary Delays for details |
triggerId | integer | the id of the trigger to disable |
emailBody | string | the body of the email to send |
emailSubject | string | the subject of the email to send |
emailTo | string | the (semicolon separated) list of email addresses |
complementDelay | integer | the number of seconds to delay before issuing the complementary action (0 for no action), in this case an DisableScheduleAction - see Complementary Delays for details |
scheduleId | integer | the id of the schedule to enable |
complementDelay | integer | the number of seconds to delay before issuing the complementary action (0 for no action), in this case an DisableTriggerAction - see Complementary Delays for details |
eventId | integer | the id of the event to enable |
groupId | integer | the id of the action group to execute |
scriptCode | string | this is the source code of the script to execute |
deviceId | integer | this is the ID of the I/O device |
action | kIOAction | this I/O action to execute |
index | integer | if action is TurnOffOutput, TurnOnOutput, the index of the input or output to control |
| indigo.kIOAction |
TurnOffOutput | turn off the output specified by index |
TurnOffAllOutputs | turn off all outputs |
TurnOnOutput | turn on the output specified by index |
RequestStatusAll | request status of all hardware input/outputs |
RequestAnalogInputValues | request all analog input values from the device |
RequestBinaryInputsStatus | request all binary input statuses |
RequestBinaryOutputsStatus | request all binary output statuses |
RequestSensorInputValues | request all sensor input values |
variableId | integer | the id of the variable |
variableAction | kVariableAction | the type of variable action to execute |
variableValue | string | the new variable value |
Variable Action Enumeration
| indigo.kVariableAction | |
DecrementValue | decrement the variable value by 1 |
IncrementValue | increment the variable value by 1 |
SetValue | set the variable to the variableValue property |
pluginTypeId | string | the id specified in the Actions.xml (or it’s documentation) |
props | dictionary | an indigo.Dict() defining this action's parameters |
SendInsteonGroupCommandAction
command | kInstnGroupCommand | this is the group command to send |
group | integer | this is the group number to send command to |
| indigo.kIOAction | |
InstantOff | send the instant (fast) off command to group ignoring ramp rate |
InstantOn | send the instant (fast) on command to group ignoring ramp rate |
Off | send the off command to group |
On | send the on command to group |
deviceId | integer | the id of the sprinkler device |
multiplierVarId | integer | API v1.20+ only: optional elem ID for the variable multiplier (None if no multiplier is specified) |
sprinklerAction | kSprinklerAction | this sprinkler action to execute |
zoneDurations | list of float | list of floats that represent the durations in minutes for each zone to schedule - used when sprinklerAction is RunNewSchedule |
zoneIndex | integer | the zone to turn on as a 1-based index – used when sprinklerAction is ZoneOn |
Sprinkler Action Enumeration
| indigo.kSprinklerAction |
RunNewSchedule | run a new sprinkler schedule |
RunPreviousSchedule | run the last executed sprinkler schedule |
PauseSchedule | pause the current sprinkler schedule |
ResumeSchedule | resume the current sprinkler schedule |
StopSchedule | stop the current sprinkler schedule |
PreviousZone | set sprinkler to the previous zone |
NextZone | set sprinkler to the next zone |
ZoneOn | turn on a single zone |
AllZonesOff | turn off all zones |
RequestStatusAll | request status of all valves |
deviceId | integer | this is the ID of the thermostat |
thermostatAction | kThermostatAction | this thermostat action to execute |
actionMode | kFanMode
OR
kHvacMode | if action is SetFanMode, then a kFanMode enumeration
if action is SetHvacMode, then a kHvacMode enumeration |
actionValue | float | if action is Decrease* or Increase*, the amount to increase/decrease the setpoints
if action is Set*, the temperature to set the setpoint to |
Thermostat Action Enumeration
| indigo.kThermostatAction |
DecreaseCoolSetpoint | decrease setpoint by value |
DecreaseHeatSetpoint | decrease setpoint by value |
IncreaseCoolSetpoint | increase setpoint by value |
IncreaseHeatSetpoint | increase setpoint by value |
SetCoolSetpoint | set the setpoint to value |
SetFanMode | set the fan mode to mode |
SetHeatSetpoint | set the setpoint to value |
SetHvacMode | set the hvac mode to mode |
RequestStatusAll | request all current values from the thermostat |
RequestMode | request the current mode of the thermostat |
RequestEquipmentState | request the current operational state of the compressor, furnace, etc. |
RequestTemperatures | request all current temperatures from the thermostat |
RequestHumidities | request all current humidities from the thermostat |
RequestDeadbands | request the current deadband ranges from the thermostat |
RequestSetpoints | request all current setpoints from the thermostat |
API v2.0+ only: This class represents a universal action that can be used with devices of different classes. Previously this class was named GeneralDeviceAction – it was renamed in API v2.0.
deviceAction | kUniversalAction | this is the command to send to the device |
| indigo.kUniversalAction |
Beep | request that the device perform an audible beep or buzz |
EnergyUpdate | request that the energy meter send its most recent meter data |
EnergyReset | request that the energy meter reset its accumulative energy usage data |
RequestStatus | send a device a status request for a complete update |
