Folders
Delete the specified folder.
Get ID
indigo.devices.folders.getId("Some Folder Name")
Since folders aren't available in AppleScript (Deprecated in Indigo 7.2 and later), we're only providing Python examples here.
except ValueError, e:
newFolder.refreshFromServer()
# change the name of a folder
newFolder.replaceOnServer()
# duplicate the folder
# delete a folder
  • /www/perceptive/wiki/data/pages/indigo_7_documentation/folder_class.txt
