Additionally, make sure you have Insteon Repeaters, Access Point RFs, or other dual-band modules correctly installed on opposite power legs. If the Repeaters/Access Point RFs or other dual-band devices are improperly installed or missing, then you may not be able to control some of your Insteon devices. See the instructions included with your Access Point RF pair for installation details.
To add a new Insteon device:
- Press the
New…button at the top of the Home window.
Managing INSTEON Links
Managing INSTEON Device Links
- Select the
Defining the Scene
- Choose
Executing the Scene
- Select the
Scenepopup item.
INSTEON Link Syncing
Resetting your PowerLinc
- Release the button
- In Indigo, select the
Sync Linksbutton
Replacing Your PowerLinc
The Interfaces→INSTEON/X10 Power Line submenu contains a collection of miscellaneous INSTEON commands that will help you manage specific aspects of devices as well as do so low-level INSTEON commands not directly supported in the UI. Note that these are also actions available in the Insteon Brand Specific submenu.
Send Raw INSTEON Command
Set Motion Sensor Timeout
Set LED Brightness
if insteonPlugin.isEnabled():
actionProps = dict()
Configure SynchroLinc
Set I/O Linc Momentary Mode
