Adding and Managing X10 Devices
TIP: You may also need to bridge the two phases of your power line to get reliable communication. Search for “X10 signal bridge” in your favorite search engine for details.
To add an X10 device, select DEVICES in the outline view (or one of it's sub-folders) and click the New… button. Select X10 from the Type: popup and you'll see the following:
However, you may have a device module not currently listed in the Type popup menu. To use devices that are not defined in the device Type popup, you can click the Definition… button you will be shown the Module Definition dialog:
