# some code here
# that does something
You should be able to tell from the context if it's Python code or, sometimes, AppleScript (which will be deprecated in Indigo 7.2 and later), if we're comparing how to do something.
TermMeaning
For Scripters and Developers:
For Developers:
ClassCommand namespaceNotes
Schedule
Triggers
DeviceStateChangeTrigger (indigo.DeviceStateChangeTriggerindigo.devStateChange.*manipulate a device state change trigger
Variables
Protocol Specific Commands
General Commands
If you are a user of the Indigo AppleScript Dictionary (AppleScript support will be deprecated in Indigo 7.2 and later), you may have certain expectations set about how you would use the IOM in Python. While there are similarities, there are also some non-trivial differences. Most of these will become apparent in the following sections, but we’d like to outline a few here.
First, and most obvious, is the nature of most objects in the IOM as we discussed earlier - using copies and updating the server when you change the properties. In AppleScript, when you alter an object’s property the change is instantaneous since the script is running in the IndigoServer process. That significant architectural difference is what led us to the split between objects and the commands that work on them.
item 1 of myArray
myArray[0]
IOM Object Hierarchy Image
  • keys cannot contain spaces.
c = indigo.List()
c.append(4)
c.append(5)
c.append(True)
c.append(False)
a = indigo.Dict()
a['a'] = "the letter a"
a['b'] = False
print(str(a))
c.append(6)
a['c'].append(6)
a['c'] = c
print(str(a))
Object Description
Iterating Object Lists
Python AppleScript (which will be deprecated in Indigo 7.2 and later)
for dev in indigo.devices:
    # do stuff with dev here
repeat with dev in every device
	-- do stuff with dev here
end repeat
Filter Description
indigo.x10include X10 devices
indigo.dimmerdimmer devices
indigo.sprinklersprinklers
indigo.thermostatthermostats
Triggers also have filters:
Filter Description
for var in indigo.variables:
    # all variables
Possible Exceptions
>>> dev.__class__
<class 'indigo.DimmerDevice'>
>>> hasattr(dev,'onState')
True
>>> dir(dev)
>>> thermo.__class__
>>> dir(thermo)
>>> tunes.__class__
<class 'indigo.Device'>
>>> dir(tunes)
>>> tunes.deviceTypeId
u'mediaserver'
  • /www/perceptive/wiki/data/pages/indigo_7_documentation/object_model_reference.txt
