Indigo Overview
Object Definition
Here is the device dialog:
Device Dialog New Image
Device Dialog Z-Wave Image
Fanlinc Dimmer Image Fanlinc Fan Speed Image
Trigger Dialog Image
Email Received Trigger Image
Use the Type Z-Wave Command Received to trigger an action when Z-Wave commands are sent from a device, like a scene controller or motion sensor, and then received by the Z-Wave interface. Each device type will have different options based on it's capability
Schedule Dialog Image
Action Type Menu Image
Universal Controls
  • Turn On Keypad Button - turn on the specified button' light on the device. Only applies to devices which have separate buttons that indicate state with a light.
  • Turn Off Keypad Button - turn off the specified button'light on the device. Only applies to devices which have separate buttons that indicate state with a light.
Light/Appliance Controls
  • Match Brightness - set the brightness of any number of dimmer devices to the value of the selected dimmer device - so you can quickly and easily create a very simple scene.
Sprinkler Controls
Sprinkler Action Image
  • Run Schedule - selecting this action will show you the zone table (shown above) that will allow you to set the duration for each zone and optionally multiply those durations by the selected variable. This last option is useful if you change durations based on time of year - you can change the variable value but keep the existing schedule and it'll adjust the duration as appropriate.
Thermostat Controls
  • Set Mode - set the mode of the thermostat to one of the following:
  • Get Ambient Humidity - get the humidity
v1 INSTEON thermostat adaptors didn't broadcast out changes to update it's internal state representations for the thermostats - which is why there are so many options to get status. Indigo 7 catches the v2 thermostat update broadcasts so the need to manually get updates should be reduced.
Fan Speed Controls
  • Cycle Through Speed Control (FanLinc) States - use this action to cycle through the fan speeds in this order: High, Medium, Low, Off. It's basically an electronic version of pulling the fan's chain.
I/O Action Image
Virtual Device Controls
Brand Specific Controls
There are a few controls specific to certain brands of devices:
Insteon
Note: in versions earlier than Indigo 7.2, these commands are on the Insteon Actions menu described below.
  • Turn On/Off KeypadLinc Buttons - turn on/off groups of buttons. Why not just have multiple actions using the built-in Turn ON/Turn OFF LED actions? Because each of those requires a lot of INSTEON traffic - and if you need to set several buttons at once this action will do it in one (or two if you want to maintain some buttons) action(s). It's more efficient and easier to configure (one action versus potentially seven actions). Select the action you want to take for each button: Turn On, Turn Off, Leave Alone. The latter option will require that we query the KPL to find the states first so if you select that for any of the buttons the action may execute a bit slower than it would otherwise. Note: using this action, which is sending raw INSTEON commands through the IndigoServer, will cause the KeypadLinc's button states in Indigo to become out of sync. This is because the server doesn't know that you're changing the button states given that it's just a raw command message that it's being asked to send to the PowerLinc. If you need to keep the states in sync then add another action to do a status request to the KeypadLinc (after a short delay to avoid collisions).
HomeSeer
New in Indigo v7.2+ are the following actions that are specific to HomeSeer switches:
The Server Actions category has three actions and three subcategories.
Execute Action Group
Execute Action Group Action Image
Remove Delayed Action Image
Reset Interface Connections
This action will attempt to reset all built-in hardware interfaces. There are no options.
Script and File Actions
Execute Script
Execute Script Action Image
The Execute Script action allows you to execute either a Python or AppleScript as an embedded script or stored in a script file. In general, you should use embedded scripts for scripts that are short and very quick to execute.
Embedded Python scripts will be limited to 10 seconds of execution time - if they run longer than that they will be killed. If you have a Python script that is a long running script you should save it in a separate file and execute it from the file by selecting the File radio button then selecting the file. Python scripts executed from files are executed in their own process and are therefore much less likely to adversely effect the server process if they don't work as expected.
Embedded AppleScripts must run on the server's main execution thread so if it delays, can hang on external events like network access, or otherwise does a lot of processing, then everything else in the server will be put on hold until the script is finished. Therefore, you definitely should keep embedded AppleScripts very simple. As with Python scripts, long running AppleScripts should be stored in a separate AppleScript file (created with Script Editor) and executed that way - external AppleScript files execute in their own process and are therefore much less likely to adversely effect the server process if they don't work as expected.
Open File
Open File Action Image
Run Shell Script
Run Shell Script Action Image
This will run the specified script file optionally with the output being inserted into the specified variable. The script must be marked executable and a valid shebang (#!/path/to/shell) must be specified at the top of the script. Note - this won't work for AppleScripts - you should use the built-in Execute Script action and select the script file that way. Also, if you're running a Python script you'll probably just want to use the Execute Script action since script files run from this plugin won't have access to the IOM (import indigo, which is Python-only).
Log Actions
Log Actions Type Menu Image
Write to Log
Write To Log Action Image
Email Event Log Data
Email Log Action Image
Enable/Disable Actions
Enable Type Menu Image
Enable Device
Enable Trigger
Enable Schedule
Disable Device
Disable Trigger
Disable Schedule
There are three actions that are specific to variables.
Modify Variable
Modify Variable Action Image
Toggle Variable
Toggle Variable Action Image
Set Variable to Variable
Set Variable To Variable Action Image
In the standard install of Indigo, there are two actions: Send Email and Growl Notify. Plugins are allowed to add menu items to this category so there may be more options if you've installed some 3rd party plugins.
Send Email
Send Email Action Image
Growl Notify
Note: In versions earlier than Indigo 7.2, the menu items in the Insteon Brand Specific Controls menu were in the above menu.
Execute INSTEON Scene
Insteon Scene Action Image
Send Raw INSTEON Command
Lower Action Dialog Image
Multiple Actions List Image
To create a new action group:
Action Group Dialog Image
Control Page Editor Image
Page Element Examples Image
  • iPhone/iPod touch
  • iPad
Other Editor Features
Page Element Details
Device State
Variable Value
Static Image/Caption
Refreshing Image URL
Server Status Text
Server Status Icon
Client Actions
  1. Popup UI Controls - this will cause the client to pop up a dialog with the controls appropriate for the device or variable selected (it doesn't do anything for other page element types)
  2. Link to Control Page - this will cause the client to display the selected control page so it's useful to navigate between control pages. The Open in new window checkbox really only effects viewing pages in a browser, not Indigo Touch
  3. Link to URL - this will cause the client to open the provided URL in a browser window (a new browser window if the Open in new window checkbox is checked).In Indigo Touch, it will cause Mobile Safari to open and show the page specified by the URL.
Server Actions
Variables are used to hold information that can help your home automation logic. For instance, Indigo ships with an AppleScript which stores weather information in variables. You can use that information to display on control pages, as part of your conditional logic (see Conditions below), or as a trigger for some other action.
Variable Window Image
Conditions Tab Image
Motion Sensor Example Image
  2. if it's too cold outside
Sprinkler Condition Image
Complex Condition Rule Image
    "If dark"
  • /www/perceptive/wiki/data/pages/indigo_7_documentation/overview.txt
