Indigo Plugins and APIs
Indigo has a long history of extensibility - AppleScript Attachment scripts were available from the start (which will be deprecated in Indigo 7.2 and later). Later, the Indigo Web Server was added along with the IWS plugin and the ability to add custom images.
in this location:
The Indigo Plugin Bundle
The Info.plist File
PluginVersion- this is the version number for your plugin - it’s shown to the user in the UI and will help you when supporting your plugin users. This key is required and should only contain numerical characters and periods (0-9 and .). For example, “1.0.5.2” is valid, but “1.0.5b2” is not. This is very important as it will help Indigo determine what do to when a user double-clicks a plugin to install it (it won't install old ones over new ones) and will eventually be used in version checking and automatic updates.ServerApiVersion- this is the version of the server plugin API as defined by us - for Indigo 7.0, it is 2.0. While we hope to keep API changes to a minimum, it’s prudent to version the server API used. This key is only required if your plugin implements a server plugin.- Bundle display name (
CFBundleName) - this is another standard macOS key, and it's a name that should be less than 16 characters long and be suitable for displaying in menu items with various strings appended (i.e. “ShortName Device Controls”). If it's not provided we'll use the bundle display name instead. - Bundle identifier (
CFBundleIdentifier) - this is another standard macOS key, and it represents a unique string that represents your plugin. This is used for namespacing where necessary in the code, so it is critical that it is unique. The standard reverse DNS naming scheme is what should be used, although if you aren’t a company you’ll need to figure something out (maybe your blog, etc.). You should limit your bundle id to standard alphanumerics as special/extended characters may cause problems. You should not use thecom.yourorgidentifier.*namespace. This key is required. - Bundle version (
CFBundleVersion) - another standard macOS key, and it represents the layout of the bundle. This is controlled by us, and for Indigo 7.0 it will be 1.0.1. This key is required. - URL types (
CFBundleURLTypes) - you must specify one URL that represents a web page where your user can get support. Your plugin will have a menu item called “About [PLUGIN NAME]” - when the user selects this menu item, the default browser will open to this URL. Note - this can be a link to your plugin's GitHub repo wiki if there is one, or could be a forum topic in the “User Contributions” section of our user forums if you don’t have any other place to host the support page. This key is required.
Menu Items Folder
You can drop Python scripts and AppleScripts (AppleScript support will be deprecated in Indigo 7.2 and later) into this folder and they will show up in your plugin's sub-menu on the new “Plugins” menu. When the user selects the menu item, the script is executed. This is a really simple way of giving your plugin some visible UI.
Resources Folder
Indigo Server Plugins
Indigo Plugin Host
Plugin Failure Handling
Server Plugin Folder
Indigo Plugin XML Conventions
Configuration Dialogs
<ConfigUI>
<Field id="autoLabel"
type="label"
visibleBindingValue="false">
</Field>
<Field id="exampleButton"
type="button"
<Title>Find Node ID</Title>
</Field>
<Field id="nodeID"
type="textfield"
readonly="YES"
<Label>Node ID:</Label>
</Field>
<Field type="checkbox"
id="manualEntry"
defaultValue="false">
</Field>
<Field id="manualNodeID"
type="textfield"
visibleBindingValue="true">
<Label>Enter Node ID:</Label>
</Field>
</ConfigUI>
Text Field
<Label>Text Field:</Label>
</Field>
Popup Menu
return valuesDict
List
Dynamic Lists
Class: indigo.devices |
Class: indigo.triggers |
def myListGenerator(self, filter="", valuesDict=None, typeId="", targetId=0) # From the example above, filter = “stuff” # You can pass anything you want in the filter for any purpose # Create an array where each entry is a list - the first item is # the value attribute and last is the display string that will # show up in the control. All parameters are read-only. myArray = [(“option1”, ”First Option”),(“option2”,”Second Option”)] return myArray
Serial Port
Checkbox
return valuesDict
Label
<Field id="exampleLabel" type="label" <Label>This is where you can put your label text. If need be it'll wrap. </Label> </Field>
Separator
Button
The process flow is this:
<Name>Music Server</Name>
<ConfigUI>
<Title>Begin Pairing</Title>
</Field>
<!-- SNIP -->
</Device>
return valuesDict
Validation Methods
return True
return (True, valuesDict)
errorDict = indigo.Dict()
Validating serialport Fields
Dialog Close Notification
PluginConfig.xml
/Library/Application Support/Perceptive Automation/Indigo 7/Preferences/Plugins/
Devices.xml
type | Attribute | Yes | This must be one of: relay, dimmer, thermostat, sensor, speedcontrol, or custom. We’ll discuss each below. |
Custom Device Type
<State id="temperature">
<ValueType>Number</ValueType>
<State id="heatSetPoint">
<State id="coolSetPoint">
<State id="mode">
Events.xml
<Events>
<Event id="updateAvailable">
</Event>
</Events>
<Event id="sep1"/>
Actions.xml
<Actions>
<Action id="resetInterface">
<Name>Reset Interface</Name>
</Action>
</Actions>
<Action id="sep1"/>
deviceFilter | Attribute | No | If present a popup list of devices that match the specified device filter will be shown in the UI. Many actions may not need any configuration beyond a device selection so we've enabled you to specify that a device must be selected and passed to the action's CallbackMethod. This will avoid the necessity to create a ConfigUI element with just a device popup. |
def writeToLog(self, action):
if theType:
indigo.server.log(theMessage)
%%v:12345%%
%%d:12345:someStateId%%
MenuItems.xml
<MenuItems>
<MenuItem id="menu1">
</MenuItem>
<MenuItem id="menu2">
</MenuItem>
<MenuItem id="menu3">
<ConfigUI>
<Label>Light:</Label>
</Field>
</ConfigUI>
</MenuItem>
<!-- Added in v1.2 -->
<MenuItem id="menu4">
</MenuItem>
</MenuItems>
def checkForUpdates(self):
In API v1.x
plugin.py
| General Plugin Methods | ||
__init__(self,
pluginId,
pluginDisplayName,
pluginVersion,
pluginPrefs)
You'll most likely use the |
Note: |
while True:
# Do your stuff here
self.sleep(60) # in seconds
except self.StopThread:
# do any cleanup here
pass
You must call |
self.stopThread = True
getDeviceStateList(self,
dev)
getDeviceDisplayStateId(self,
dev)
deviceStartComm(self,
dev)
deviceStopComm(self,
dev)
origDev,
newDev)
deviceCreated(self,
dev)
| Deprecated in 1.4 | This method was deprecated in v1.4 of the API. It will continue to be called internally, but you'll find the device passed to it not fully created in most circumstances. Use deviceStartComm() instead. |
deviceUpdated(self,
origDev,
newDev)
deviceDeleted(self,
dev)
triggerStartProcessing(self,
trigger)
triggerStopProcessing(self,
trigger)
origTrigger,
newTrigger)
triggerCreated(self,
trigger)
triggerUpdated(self,
origTrigger,
newTrigger)
triggerDeleted(self,
trigger)
| Name | Required | Notes |
bundleID)
browserOpen(self,
url)
debugLog(self,
msg)
errorLog(self,
msg)
openSerial(self,
ownerName,
portUrl, baudrate, bytesize,
parity, stopbits, timeout,
dsrdtr, interCharTimeout)
sleep(self,
seconds)
substituteVariable(self,
inString,
validateOnly=False)
substituteDeviceState(self,
inString,
validateOnly=False)
substitute(self,
inString,
validateOnly=False)
Logging
| Attribute | Description |
self.indigo_log_handler
self.plugin_file_handler
Log Levels
Logging from submodules
Add discussion about how to log from submodules and give an example.
Event and Message Flow
Plugin Preferences File
Add discussion about the preferences file and when it is cached and written (both periodically and when the plugin quits).
3rd Party Python Libraries
