Indigo Scripting Tutorial
Talking to the Indigo Server
Example Code Snippets
Device Examples
Turn off all devices:
indigo.device.allOff()
indigo.devices.len()
from datetime import datetime
Access a custom device state
Variable Examples
Getting a variable object and using it's value:
myVar = indigo.variables[123]
if myVar.value == "true":
Duplicating a variable:
import urllib, urllib2
myUnicodeString = u"éçø"
myInteger = 1
myFloat = 1.0
import simplejson as json
myNewDictionary["myList"]
class myCustomClass:
def __init__(self):
self.a=1
self.b=2
def __unicode__(self):
return outputString
Date and Time Examples
Get the current server time:
indigo.server.getTime()
Action Group Examples
Log Examples
Log to the Indigo Event Log window all of the attributes/properties of the device "office desk lamp":
lamp = indigo.devices["office desk lamp"] indigo.server.log(lamp.name + ": \n" + str(lamp))
Folder Examples
except ValueError, e:
myFolder = None
Miscellaneous Examples
Sending emails
# Simple Example
If you already have a Terminal shell running, you can launch it directly. The file path to the IPH executable is a bit deep, so create an alias to it inside your .bashrc (or .bash_profile) file by copying/pasting this into the Terminal (you only need to do this once!):
echo "alias indigohost='/Library/Application\ Support/Perceptive\ Automation/Indigo\ 7.2/IndigoPluginHost.app/Contents/MacOS/IndigoPluginHost'" >> ~/.bashrc
Next, close the Terminal window and open a new one to load the shortcut alias to the IPH executable. To start the IPH in interactive mode we pass the -i flag to it inside the Terminal:
indigohost -i
As shown, the IPH will automatically connect to the IndigoServer running on the same Mac and will show the server's version information. Additionally, you'll notice that Indigo Server logs the connection of the interactive shell plugin.
Connecting Remotely over SSH
ssh username@indigo_mac_ipaddr -t "/Library/Application\ Support/Perceptive\ Automation/Indigo\ 6/IndigoPluginHost.app/Contents/MacOS/IndigoPluginHost" -i
What Else Can it Do?
indigohost -e 'return indigo.devices["office lamplinc"].brightness'
indigohost -e '
Caveat: Each call creates a new IPH (indigohost) process which must establish a connection to the Indigo Server. Although this is relatively fast, calling it multiple times a second is not recommended.
Executing Indigo Python Files
indigohost -x /SomeFolder/indigo_script.py'
Executing AppleScript
Often times, you may find yourself wanting to execute an AppleScript from Python. You want to send some parameters to the AppleScript and you want to get results back in some format. There's a pretty straight-forward way to do this that we've described in this blog post.
This is a great pattern for calling AppleScripts from Python, and may help alleviate some of the pain of the Mac OS X “application isn't running” bug (error -600).
In Indigo, if you want to write AppleScript handlers that are shared by any script that Indigo executes, you can just put an AppleScript full of handlers in the /Library/Application Support/Perceptive Automation/Indigo 7.2/Scripts/Attachments folder. You can do the same thing with Python using a built-in mechanism that Python provides. There is a folder in the Library folder at the top level of your boot disk that is very similar to the Attachments folder:
Any Python files in this directory that define methods and/or classes will be available to any Python script whenever the interpreter is loaded (note that it's the Library directory at the top level of your boot disk, not the one in your user folder). These are referred to as Python modules. So, you can create files of classes, functions, etc. you want to share between all Python scripts. If you add/change something in that directory while the Indigo Server is running, you'll need to tell the server to reload - select the Plugins→Reload Libraries and Attachments menu item and Indigo will restart the Python interpreter (which will cause your module to be reloaded).
Files here can also import the entire IOM - IF the script that's actually running is started by Indigo. Here's a simple script that you can use that will safely import the IOM and will show a specific error when used from a Python script that's not started by Indigo:
indigo_attachments.py
import indigo
except ImportError:
raise ImportError
def log(message, label=None):
import indigo_attachments
raise ImportError
ImportError
Scripting Indigo Plugins
| pluginDisplayName | The name displayed to users in the clients |
| pluginId | The ID of the plugin (same as was passed to the getPlugin() method above) |
| pluginSupportURL | The URL supplied by the plugin that points to it's user documentation |
| pluginVersion | The version number specified by the plugin |
iTunes Toggle Play State
if itunesPlugin.isEnabled():
iTunes Set Volume to 50
Restart a Plugin
