Scenes (Indigo 6)
With the addition of Z-Wave (and various plugins that define dimmer and relay devices) it's become obvious that we needed to provide some way to create technology agnostic scenes. You can, of course, implement basic scenes through Action Groups, and for many cases that's good enough.
To create a scene, you just create a new device, select Scenes from the Type menu, select On/Off Scene from the model menu, and you'll see the configuration dialog:
Scenes Configuration Image
  • All devices are ON - so the scene state will be set to ON when all devices in the scene are ON
  • Any device is ON - so the scene state will be set to ON when any of the devices in the scene are ON
To use a scene device, just use the standard Control Light/Appliance action to turn it ON/OFF, and create triggers on the scene's ON and OFF state. That's it!
  • /www/perceptive/wiki/data/pages/indigo_7_documentation/plugins/scenes.txt
