Example Twisted Telnet Server Plugin
This is an example plugin for developers that illustrates how a plugin can use the python twisted event framework. In this example the plugin creates a simple telnet server which can be used to remotely flash devices ON/OFF for a few seconds. Once enabled you can connect to the telnet server from the Terminal using:
telnet 127.0.0.1 9176
indigo_7_documentation/plugins/example_twisted_telnet_1.txt · Last modified: 2019/01/26 00:10 (external edit)
