INSTEON Commands
This plugin is a collection of miscellaneous INSTEON commands that aren't yet available natively in the UI (and may never be). There are several reasons for adding some INSTEON commands as actions via this plugin: it's sometimes desirable to be able to perform these actions more frequently than just once during setup (so it's in addition to the native UI) and it's often faster than adding it into the native UI. In any event, here are the actions available:
This action will set the brightness of the LEDs on certain devices. Newer KeypadLincs are supported as well as some SwitchLinc models. Unfortunately, there isn't really a way to tell you which devices are supported so you'll just have to try it and see if it works.
Available in v1.0.0.
Available in v1.0.1.
As of v1.0.2 all the above actions can be run interactively from the plugin's menu so you don't need to create a separate Action Group to run them.
We'll add other functionality here where it makes sense. Drop us an email if you have an idea.
Plugin ID: com.perceptiveautomation.indigoplugin.InsteonCommands
Set LED Brightness
Action id: setLedBrightness
Properties for scripting:
device required the ID of the target device
brightness optional desired brightness of the device from 1-100 (100 is default)
brightenMethod optional method to use to try the command, one of “kpl” (default) or “swl”
acId = "com.perceptiveautomation.indigoplugin.InsteonCommands"
actionPlugin = indigo.server.getPlugin(acId)
if actionPlugin.isEnabled():
	actionPlugin.executeAction("setLedBrightness", props={'device':'1435361545','brightness':'1', 'brightenMethod':'kpl'})
Action id: setKPLLeds
keypadlinc required the ID of the target keypadlinc
button2 optional one of the following actions for button: “turnOn” (default), “turnOff”, “leaveAlone”
button3 optional one of the following actions for button: “turnOn” (default), “turnOff”, “leaveAlone”
button4 optional one of the following actions for button: “turnOn” (default), “turnOff”, “leaveAlone”
button5 optional one of the following actions for button: “turnOn” (default), “turnOff”, “leaveAlone”
button6 optional one of the following actions for button: “turnOn” (default), “turnOff”, “leaveAlone”
button7 optional one of the following actions for button: “turnOn” (default), “turnOff”, “leaveAlone”
button8 optional one of the following actions for button: “turnOn” (default), “turnOff”, “leaveAlone”
	actionPlugin.executeAction("setKPLLeds", props={'keypadlinc':'1435361545','button4':'leaveAlone'})
Action id: setAutoOffButtonGroup
controlButton required the control button (the one that turns off the others) - value from 1-8
button2 optional True if you want a press on the controlButton to turn off, False (default) otherwise
button3 optional True if you want a press on the controlButton to turn off, False (default) otherwise
button4 optional True if you want a press on the controlButton to turn off, False (default) otherwise
button5 optional True if you want a press on the controlButton to turn off, False (default) otherwise
button6 optional True if you want a press on the controlButton to turn off, False (default) otherwise
button7 optional True if you want a press on the controlButton to turn off, False (default) otherwise
button8 optional True if you want a press on the controlButton to turn off, False (default) otherwise
	# Here we set button 3 so that it turns off buttons 4, 5, and 6
	actionPlugin.executeAction("setAutoOffButtonGroup", props={'keypadlinc':'1435361545','controlButton':'3', "button4":True, "button5":True, "button6":True})
Action id: setKPLToggleMode
button1toggle optional True if you to put the button into non-toggle mode, False (default) if you want it to toggle (standard behavior)
button1onMode optional True (default) if you want a press on the button to always send ON when in non-toggle mode, False to have it send OFF (has no effect if the button isn't set to non-toggle mode)
button2toggle optional True if you to put the button into non-toggle mode, False (default) if you want it to toggle (standard behavior)
button2onMode optional True (default) if you want a press on the button to always send ON when in non-toggle mode, False to have it send OFF (has no effect if the button isn't set to non-toggle mode)
button3toggle optional True if you to put the button into non-toggle mode, False (default) if you want it to toggle (standard behavior)
button3onMode optional True (default) if you want a press on the button to always send ON when in non-toggle mode, False to have it send OFF (has no effect if the button isn't set to non-toggle mode)
button4toggle optional True if you to put the button into non-toggle mode, False (default) if you want it to toggle (standard behavior)
button4onMode optional True (default) if you want a press on the button to always send ON when in non-toggle mode, False to have it send OFF (has no effect if the button isn't set to non-toggle mode)
button5toggle optional True if you to put the button into non-toggle mode, False (default) if you want it to toggle (standard behavior)
button5onMode optional True (default) if you want a press on the button to always send ON when in non-toggle mode, False to have it send OFF (has no effect if the button isn't set to non-toggle mode)
button6toggle optional True if you to put the button into non-toggle mode, False (default) if you want it to toggle (standard behavior)
button6onMode optional True (default) if you want a press on the button to always send ON when in non-toggle mode, False to have it send OFF (has no effect if the button isn't set to non-toggle mode)
button7toggle optional True if you to put the button into non-toggle mode, False (default) if you want it to toggle (standard behavior)
button7onMode optional True (default) if you want a press on the button to always send ON when in non-toggle mode, False to have it send OFF (has no effect if the button isn't set to non-toggle mode)
button8toggle optional True if you to put the button into non-toggle mode, False (default) if you want it to toggle (standard behavior)
button8onMode optional True (default) if you want a press on the button to always send ON when in non-toggle mode, False to have it send OFF (has no effect if the button isn't set to non-toggle mode)
	# Here we set button 3 so that it always sends an OFF command
	actionPlugin.executeAction("setKPLToggleMode", props={'keypadlinc':'1435361545', "button3toggle":True, "button3onMode":False})
Action id: setMotionSensorLedBrightness
device required the ID of the target motion sensor
brightness optional desired brightness of the motion sensor from 0-255 (100 is default)
	actionPlugin.executeAction("setMotionSensorLedBrightness", props={'device':'554249383','brightness':'0'})
Set Motion Sensor Timeout
Action id: setMotionSensorTimeout
timeout optional desired timeout of the motion sensor from 0-255 (1 is default)
	actionPlugin.executeAction("setMotionSensorTimeout", props={'device':'554249383','timeout':'5'})
Action id: setMotionSensorSensitivity
sensitivity optional desired sensitivity of the motion sensor from 0-255 (128 is default)
	actionPlugin.executeAction("setMotionSensorSensitivity", props={'device':'554249383','sensitivity':'200'})
Set I/O Linc Momentary Mode
Action id: setIOLincMomentaryMode
iolinc required the ID of the target device
momentaryMode optional the mode, one of “A”, “B”, “C”, and “None” - see the I/O Linc docs for details
	actionPlugin.executeAction("setIOLincMomentaryMode", props={'iolinc':'1053088701','momentaryMode':'A'})
Configure SynchroLinc
Action id: configureSynchroLinc
synchrolinc required the ID of the target device
triggerWatts optional (0 to 1800 watts in 0.5 watt steps): the wattage needed before the SynchroLinc broadcasts (will retain existing setting if not included)
thresholdWatts optional (aka hysteresis, 0 to 127.5 watts in 0.5 watt steps): tolerance before on/off toggle is sent (will retain existing setting if not included)
delaySeconds optional (0.15 to 38.25 seconds): prevents message flooding if thresholdWatts is too low (will retain existing setting if not included)
	actionPlugin.executeAction("configureSynchroLinc", props={'synchrolinc':'662726927','triggerWatts':'14.5','thresholdWatts':'4.0','delaySeconds':'4.50'})
Send Raw INSTEON Command
Use the indigo.insteon.sendRaw() and indigo.insteon.sendRawExtended() commands. FIXME add links when those methods get documented
  • /www/perceptive/wiki/data/pages/plugins/insteon_commands.txt
