Timers and Pesters
As the name implies, this plugin implements a very simple timer device object that works almost exactly like a manual kitchen timer (if the kitchen timer had the ability to pause and resume). Pesters are little mini schedules that can cycle for some fixed number of times. They are lightweight versions of Indigo Schedules. The Timers and Pesters plugin was introduced with Indigo 6.
Timers
  1. Select DEVICES (or one of its subfolders) from the Outline View
  2. Click on the New… button
  6. Click Save
  • Set Timer Start Value - use this action to set the default timer value without actually starting the timer. If the timer is running when it has its start value changed, it will stop running.
  1. Select TRIGGERS (or one of its subfolders) from the Outline View
  6. Click Save
Pesters
Scripting Support
Start Timer
Action id: startTimer
if timerPlugin.isEnabled():
Pause Timer
Action id: pauseTimer
Restart Timer
Action id: restartTimer
Resume Timer
Action id: resumeTimer
Stop Timer
Action id: stopTimer
Action id: setTimerStartValue
Properties for scripting:
  • /www/perceptive/wiki/data/pages/plugins/timersandpesters.txt
