In-wall X10 Dimmer Switches
X10 in-wall dimmer switches come in 1-way and 2-way. 1-way switches are only controllable via an X10 command - the switch, when manually activated, doesn't send out a status change message nor will it respond when Indigo asks for its status. So, you may find that Indigo isn't correctly representing the state of the device - that's normally because the switch was manually activated.
2-way switches are different: they often times will broadcast their state change when manually operated and will almost always respond to a status request from Indigo. Some will not do the broadcast but will respond to the status request. When you have that type of switch, it's often advantageous to create a Time/Date action that will periodically poll the device(s) for their status so that Indigo will keep in sync. Be aware, however, that polling too frequently can cause your X10 signal performance to degrade, because there will be too many signals on the powerline at the same time, and X10 doesn't have much in the way of signal error recovery.
Note: while dimmer switches and relay switches look very similar, they have a fundamental difference that you should read about. This page talks about dimmers - there is a corresponding page that talks about X10 in-wall relay switches.
You may find these how-tos useful with in-wall switches:
