HomeSeer
HomeSeer is the maker of a variety of home automation products. On this page we'll focus on it's Z-Wave devices
SmartStick+
This is HomeSeer's USB Z-Wave interface which supports Z-Wave Plus (Gen5).
It will be found by the built-in macOS modem driver, so no 3rd party drivers need to be installed. It will show up as usbmodemXXXXXXX where the XXXXXXX is a number derived from the USB port it's plugged into. Note that it will change if you move it to a different USB port so you'll need to reselect in the Z-Wave config dialog if you do.
HS-WD100+ Dimmer Switch
This switch's basic on/off/dim functionality should work with Indigo 6. Indigo 7+ contains the following device specific support.
Configuration Options
- Reverse switch controls - reverses the on/off ends of the paddle
- Local dim delta - sets the amount of dim change used for each dim step while being locally controlled
- Local dim timer - sets the delay between dim step changes while being locally controlled
- On/Off dim delta - sets the amount of dim change used for each dim step when receiving ON/OFF dims
- On/Off dim timer - sets the delay between dim step changes when receiving ON/OFF dims
Events
- Button pressed
- Button double tap
- Button triple tap
- Button held down
- Button released
HS-WS100+ Relay Switch
This switch's basic on/off functionality should work with Indigo 6. Indigo 7+ contains the following device specific support.
- LED mode - changes how the LED on the switch works: Nightlight (on when device is off), Mirrors load (on when device is on), Off (never turns on)
Events
- Button pressed
- Button double tap
- Button triple tap
- Button held down
- Button released
