Indigo Plugins and APIs
Indigo has a long history of extensibility - AppleScript Attachment scripts were available from the start. Later, the Indigo Web Server was added along with the IWS plugin and the ability to add custom images.
With Indigo 5.0, we wanted to add a new server plugin API that would allow 3rd party developers to more natively add devices, triggers, and actions to Indigo. This new server API would allow users and 3rd party vendors to implement their own functionality in Python with full access to all the objects and events that Indigo understands (referred to as the Indigo Object Model, or IOM). Finally, users wouldn’t have to wait for us to add support for, say, the Global Caché IR devices, the THUM devices from Practical Design, etc. Someone with sufficient skills could implement support for those devices, have them integrated into the Indigo UI as first-class citizens. No strange variable state hacks, fake X10 devices, etc. - these new devices are actually recognized as real devices in Indigo.
What’s more, we wanted to ensure that Python programmers have complete access to everything that AppleScript scripts have access to. While AppleScript is a good language for a lot of things (and we aren’t dropping support for it) we believe that using a more modern, standard, capable, and platform agnostic scripting language is much better for our users in the long run.
To deliver this additional functionality, we've introduced a new concept: the Indigo plugin bundle. First, let’s look at the new Application Support folder structure.
Back to Top
Indigo has always supported customization by the user via various folders in the main Indigo directory located here:
/Library/Application Support/Perceptive Automation/Indigo 4
Located inside this folder were several sub-folders where users could put various scripts, web plugins and images. In Indigo 7 (and Indigo 5), we changed the folder structure such that it looks like this:
in this location:
Notice are the two new folders: Plugins and Plugins (Disabled). These two folders are where the new plugin bundles are stored (see the next section for details). Plugins that are enabled from the UI are located in the Plugins folder and when a user disables a plugin it’s moved to the Plugins (Disabled) folder.
Back to Top
The Indigo Plugin Bundle
One of the biggest problems with extending Indigo was that there were pieces/parts all over the Application Support folder. As the developer of a solution, you often had to tell people to put various parts of your solution in various places, which of course has a huge margin for user error. To address that problem, we’ve created a new bundle type, the Indigo plugin bundle (.indigoPlugin), which has a very specific structure:
The first thing you’ll notice is that this is actually a real Finder bundle - so it appears to be a single file called Example.indigoPlugin. It’s moved around and treated as a single file, and all the user has to do to install your solution is to drag the plugin file (bundle) to the Plugins folder.
First, though, you can see that there is only one top-level folder in the bundle - Contents. All other files/folders are inside that folder. This is the standard Mac OS bundle construction, so we decided to follow the pattern.
So, why did we go to the trouble of using the bundle format when there's just a file and a couple of folders? Because in future versions, we're going to add capabilities to the plugin bundle (AppleScript Attachments, AppleScript background scripts, shared images, IWS plugins, etc).
The Info.plist File
Editing a plist file isn’t difficult, but it’s much easier using the Property List Editor application that Apple ships with the Xcode tools. However, it is just a text XML file that looks like this:
<plist version="1.0">
<dict>
    <key>PluginVersion</key>
    <string>1.0</string>
    <key>ServerApiVersion</key>
    <string>2.0</string>
    <string>Example Indigo Plugin</string>
    <key>CFBundleName</key>
    <string>Example</string>
    <key>CFBundleIdentifier</key>
    <string>com.yourdomain.plugin</string>
    <key>CFBundleVersion</key>
    <string>1.0.0</string>
    <key>CFBundleURLTypes</key>
    <array>
        <dict>
            <key>CFBundleURLName</key>
            <string>http://www.yourdomain.com/plugin/</string>
        </dict>
    </array>
</dict>
</plist>
In Property List Editor, it looks like this:
  • PluginVersion - this is the version number for your plugin - it’s shown to the user in the UI and will help you when supporting your plugin users. This key is required and should only contain numerical characters and periods (0-9 and .). For example, “1.0.5.2” is valid, but “1.0.5b2” is not.
  • ServerApiVersion - this is the version of the server plugin API as defined by us - for Indigo 7.0, it is 2.0. While we hope to keep API changes to a minimum, it’s prudent to version the server API used. This key is only required if your plugin implements a server plugin.
  • Bundle display name (CFBundleDisplayName) - this is a standard Mac OS X key, and its value represents the name of your plugin. It’s used in a bunch of places in the UI, so make sure that it appropriately identifies your plugin. This key is required.
  • Bundle name (CFBundleName) - this is another standard Mac OS X key, and it's a name that should be less than 16 characters long and be suitable for displaying in menu items with various strings appended (i.e. “ShortName Device Controls”). If it's not provided we'll use the bundle display name instead.
  • Bundle identifier (CFBundleIdentifier) - this is another standard Mac OS X key, and it represents a unique string that represents your plugin. This is used for namespacing where necessary in the code, so it is critical that it is unique. The standard reverse DNS naming scheme is what should be used, although if you aren’t a company you’ll need to figure something out (maybe your blog, etc.). You should limit your bundle id to standard alphanumerics as special/extended characters may cause problems. You should not use the com.perceptiveautomation.* namespace. This key is required.
  • Bundle version (CFBundleVersion) - another standard Mac OS X key, and it represents the layout of the bundle. This is controlled by us, and for Indigo 7.0 it will be 1.0.0. This key is required.
  • URL types (CFBundleURLTypes) - you must specify one URL that represents a web page where your user can get support. Your plugin will have a menu item called “About [PLUGIN NAME]” - when the user selects this menu item, the default browser will open to this URL. Note - this can be a forum topic in the “User Contributions” section of our user forums if you don’t have any other place to host the support page. This key is required.
You can drop Python scripts and AppleScripts into this folder and they will show up in your plugin's sub-menu on the new “Plugins” menu. When the user selects the menu item, the script is executed. This is a really simple way of giving your plugin some visible UI. In Indigo 4, if you had loose scripts in the “Scripts” folder, they showed up under the “Scripts” menu item in the Indigo Mac Client. This is no longer the case - if you want scripts to show up in a menu somewhere, you'll need to create a plugin bundle with the scripts you want in the “Menu Items” folder. You don't need to implement a Server Plugin to do this - only have a valid Info.plist file and a Menu Items folder with your scripts.
Indigo Server Plugins
Back to Server Plugins
The IOM is used for two similar purposes: scripting Indigo and building Server Plugins. They aren’t mutually exclusive, but they serve different needs. For instance, you may just want to write an embedded Python script action vs building a full Server Plugin. Likewise, you may be interested in building a Server Plugin that doesn’t actually create any new device types, but simply adds events, actions, and menus to Indigo. This is fundamentally different from how AppleScript works with the IndigoServer.
Embedded AppleScripts have an issue: they are required to run on the main thread of the server application. So if an embedded script got hung up, it would hang up the server as well. Not so with Python scripts - they always run in a separate thread (and are killed if they take longer than 10 seconds to execute) so they are somewhat safer. Obviously, if you have a script that takes a long time to run or makes network or other potentially long-running calls, putting it in a script file (where it will execute it it's on special process) is a better idea.
Indigo Plugin Host
More specifically, the IOM is presented to your plugin as a module, indigo, that all plugins automatically import. Every object that represents an Indigo object and every command that you use to communicate with Indigo is done through the indigo module. For example, to write something to the Indigo Log, you would do this:
Plugin Failure Handling
Server Plugin Folder
Indigo Plugin XML Conventions
  • id's cannot contain spaces
Configuration Dialogs
<ConfigUI>
    <Field id="autoLabel"
            type="label"
            visibleBindingValue="false">
    </Field>
    <Field id="exampleButton"
            type="button"
        <Title>Find Node ID</Title>
    </Field>
    <Field id="nodeID"
            type="textfield"
            readonly="YES"
        <Label>Node ID:</Label>
    </Field>
    <Field type="checkbox"
            id="manualEntry"
            defaultValue="false">
    </Field>
    <Field id="manualNodeID"
            type="textfield"
            visibleBindingValue="true">
        <Label>Enter Node ID:</Label>
    </Field>
</ConfigUI>
Text Field
    <Label>Text Field:</Label>
</Field>
Back to Configuration Dialogs
	<Label>Popup Menu:</Label>
</Field>
</Field>
    return valuesDict
List
	<Label>List:</Label>
</Field>
Static list fields are constructed almost identically to static popup menu fields - with a Label element and a List element which contains multiple Option elements. Each Option element must have a value attribute and that attribute is what is what will be passed back to your plugin when the dialog is validated; it may not contain comma characters. The text inside the Option element is what is displayed for each line in the user interface.
Dynamic Lists
</Field>
Class: indigo.devices
Optional Filters Description
indigo.relayrelay devices
indigo.dimmerdimmer devices
indigo.sprinklersprinklers
indigo.thermostatthermostats
Class: indigo.triggers
indigo.varChange variable changed triggers
</Field>
def myListGenerator(self, filter="", valuesDict=None, typeId="", targetId=0)
	# From the example above, filter = “stuff”
	# Create an array where each entry is a list - the first item is
	myArray = [(“option1”, ”First Option”),(“option2”,”Second Option”)]
	return myArray
Note: both parameters should be strings. Specifically, items with None as the value (first item) will be skipped.
</Field>
</Field>
Serial Port
Checkbox
	<Label>Checkbox:</Label>
</Field>
</Field>
    return valuesDict
Label
<Field id="exampleLabel" type="label"
	</Label>
</Field>
fontColor No 1.4 Use this attribute to control the color of the label text. Valid options are: “black (default), “red”, “orange”, “blue”, and “green”.
Separator
<Field id="simpleSeparator1"
		type="separator"
		visibleBindingValue="1"/>
Button
		type="button"
		visibleBindingValue="1">
</Field>
The process flow is this:
    <Name>Music Server</Name>
    <ConfigUI>
            <Title>Begin Pairing</Title>
        </Field>
<!-- SNIP -->
</Device>
    return valuesDict
Validation Methods
    return True
    return (True, valuesDict)
    errorDict = indigo.Dict()
Validating serialport Fields
	errorsDict = indigo.Dict()
	if len(errorsDict) > 0:
Notice that at the top of the validation method after we define the errorsDict, we call self.validateSerialPortUi(). This method will look for the fields that make up the specified field (“devicePortFieldId” in this case). It will make sure that a valid serial port is selected if it's a physical connection or that the address field is formatted properly if it's one of the network connections. If not, it will automatically add the appropriate errors to the errorsDict and will attempt to correct any URL prefix errors (“socket://” or “rfc2217://”). You can then continue to validate the rest of the fields in your dialog and use the length check on errorsDict to see if there were any errors discovered. If so, return False along with both dicts. If it's empty, just return true with the valuesDict.
Dialog Close Notification
Dialog Type Method Signature
PluginConfig.xml
<?xml version="1.0"?>
<PluginConfig>
</PluginConfig>
/Library/Application Support/Perceptive Automation/Indigo 7/Preferences/Plugins/
Devices.xml
Name Type Required Notes
Custom Device Type
    <State id="temperature">
        <ValueType>Number</ValueType>
    <State id="heatSetPoint">
    <State id="coolSetPoint">
    <State id="mode">
Events.xml
<Events>
    <Event id="updateAvailable">
    </Event>
</Events>
<Event id="sep1"/>
FIXME Add Python examples of how to notify the server that one of these events has occurred.
Actions.xml
<Actions>
    <Action id="resetInterface">
        <Name>Reset Interface</Name>
    </Action>
</Actions>
As with <Event>, your <Action> elements can define a <SupportURL> element as well - the actions dialog now has a help button on it and if one of your actions is selected clicking on the help button will take your user to the specified URL. If you don’t specify one then the default help page for all trigger events will show. You can specify an Action to be a separator in your action list so that when they're displayed in the UI there is a visual separation. Simply insert an Action defined like this between two other Action elements:
<Action id="sep1"/>
uiPath Attribute No Added in API v1.4. You can specify where in the menu hierarchy your action will be placed. By default, Indigo will create a submenu at the bottom of the Actions list and put your actions there. If you specify “DeviceActions”, Indigo will create a submenu on the Device Actions menu and put your actions there. If you specify “NotificationActions”, Indigo will insert your action n the Notification Actions menu without a submenu (be sure to name your action appropriately so that it's clear what it does).
def writeToLog(self, action):
    if theType:
        indigo.server.log(theMessage)
%%v:12345%%
%%d:12345:someStateId%%
<MenuItems>
    <MenuItem id="menu1">
    </MenuItem>
    <MenuItem id="menu2">
    </MenuItem>
    <MenuItem id="menu3">
        <ConfigUI>
			<Label>Light:</Label>
		</Field>
        </ConfigUI>
    </MenuItem>
    <!-- Added in v1.2 -->
    <MenuItem id="menu4">
    </MenuItem>
</MenuItems>
def checkForUpdates(self):
In API v1.x
plugin.py
General Plugin Methods
__init__(self,
         pluginId,
         pluginDisplayName,
         pluginVersion,
         pluginPrefs)
__del__(self)
def __del__(self):
startup(self)
def startup(self):
shutdown(self)
def shutdown(self):
runConcurrentThread(self)
    while True:
        # Do your stuff here
        self.sleep(60) # in seconds
except self.StopThread:
    # do any cleanup here
    pass
stopConcurrentThread(self)
    self.stopThread = True
prepareToSleep(self)
wakeUp(self)
Device Specific Methods
getDeviceStateList(self,
                   dev)
getDeviceDisplayStateId(self,
                        dev)
deviceStartComm(self,
                dev)
No If your plugin defines devices, this is likely the place where you'll want to do the work of starting your device up. For instance, let's say that you have a device somewhere out on the network - the easiest way to “start” your device is to implement this method. You would open the network addrss:port (that's defined in dev.pluginProps), get it's current state(s) and tell the IndigoServer to set those states (using the dev.updateStateOnServer() method).
deviceStopComm(self,
               dev)
                            origDev,
                            newDev)
deviceCreated(self,
              dev)
Deprecated in 1.4 This method was deprecated in v1.4 of the API. It will continue to be called internally, but you'll find the device passed to it not fully created in most circumstances. Use deviceStartComm() instead.
deviceUpdated(self,
              origDev,
              newDev)
deviceDeleted(self,
              dev)
Trigger Specific Methods
triggerStartProcessing(self,
                       trigger)
triggerStopProcessing(self,
                      trigger)
                                   origTrigger,
                                   newTrigger)
triggerCreated(self,
               trigger)
triggerUpdated(self,
               origTrigger,
               newTrigger)
triggerDeleted(self,
               trigger)
Schedule Specific Methods
Action Group Specific Methods
Name Required Notes
Variable Specific Methods
Name Required Notes
variableCreated(self, var)
variableDeleted(self, var)
                                bundleID)
browserOpen(self,
            url)
debugLog(self,
         msg)
errorLog(self,
         msg)
openSerial(self,
         ownerName,
         portUrl, baudrate, bytesize,
         parity, stopbits, timeout,
         dsrdtr, interCharTimeout)
serial.Serial instance This method is identical to creating a new pySerial Serial object except that it never throws an exception. If the serial connection cannot be openned then None is returned and an error will be automatically logged to the Indigo Server event log.
sleep(self,
         seconds)
substituteVariable(self,
                   inString,
                   validateOnly=False)
String
if validateOnly is False
(BOOL, errStr)
if validateOnly is True
%%v:VARID%%
substituteDeviceState(self,
                      inString,
                      validateOnly=False)
String
(BOOL, errStr)
%%d:DEVICEID:STATEKEY%%
substitute(self,
           inString,
           validateOnly=False)
Logging
Attribute Description
self.indigo_log_handler
self.plugin_file_handler
Log Levels
Logging from submodules
Event and Message Flow
Plugin Preferences File
Back to Top
3rd Party Python Libraries
PySerial v2.5 - just “import serial” at the top of your script. PySerial allows your plugins/scripts to access any serial ports on your Mac. The EasyDAQ plugin uses PySerial for it's serial communication so you may find it useful to look at the code for that plugin for examples.
py-appscript v1.0.0 - “import appscript” at the top of your script. Appscript allows you to use apple events to control other applications. Apple events are what AppleScript uses - py-appscript uses the same underlying events. The syntax is obviously Python but it requires a little getting used to. The Airfoil plugin uses py-appscript so you may find it useful to look at the code for that plugin for examples.
indigo_7_documentation/plugin_guide.txt · Last modified: 2017/01/10 16:21 by jay
