iTunes Plugin for Indigo
The old iTunes AppleScripts are included by the installer for backwards compatibility.
Plugin Config
This dialog tells you what to do next. You must pair this new device with the iTunes Server that you intend to control. Switch to iTunes - if you're using iTunes 11, you'll see a button titled Remote in the upper right corner next to the iTunes Store button:
Select Indigo Remote Control
Device States
Actions
{{:plugins:itunes_actions.png|
  • Play - start iTunes playing
  • Pause - pause iTunes
  • Pause iTunes and Say - pause iTunes (if it's running) and speak the supplied text. Restart only if it was paused to begin with.
Scripting Support
Action specific properties
Play
Action id: play
if itunesPlugin.isEnabled():
Pause
Action id: pause
Toggle Play/Pause
Action id: playPause
Next Track
Action id: nextTrack
Previous Track
Action id: prevTrack
Restart Track
Action id: restartTrack
Pause and Speak Text
Action id: pauseAndSay
Properties for scripting:
Set Volume
Action id: setVolume
Increase Volume
Action id: increaseVolume
Decrease Volume
Action id: decreaseVolume
Set Repeat
Action id: setRepeat
Set Shuffle
Action id: setShuffle
Support and Troubleshooting
plugins/itunes.txt · Last modified: 2015/04/10 14:53 by jay
