This version of the API shipped with Indigo 2021.1.0 - check the API Version Chart to see what version of the API is available in which Indigo versions.
indigo.device.groupWithDevice(dev, someOtherDev)
and indigo.device.ungroupDevice(dev)
. Note if the user has the device dialog UI open it will not currently dynamically update, and you shouldn’t call either method if the device factory UI is open.IndigoLogHandler
class to the plugin's base class (self.IndigoLogHandler
) so other modules/subclasses can write to the Indigo Log with their own log type by instantiating an instance of this handler and adding it to their logger.indigo.server.licenseStatus
) to determine the status of the server's license.
