apiVersion string No API v1.7: the currently connected Indigo Server plugin API version as a string (ex: “1.7”)
/* |portNum| integer | No |the port number of the currently connected Indigo Server */ /* |connectionGood| boolean | No |true if the connection to the Indigo Server is currently good| */
License Status Enumeration
Value Description
ActiveSubscription license has an active Indigo Up-to-Date subscription (access to a reflector)
lat = latLong[0]
long = latLong[1]
for posixPath in ports:
	print(posixPath)
	print(uiName)
# iterate through both
	print(posixPath)
	print(uiName)
indigo.server.getTime()
No Parameters
indigo.server.sendEmailTo("[email protected]")
  • /www/perceptive/wiki/data/pages/indigo_2021.1_documentation/server_commands.txt
