Triggers
sharedProps dictionary No API v2.3 : an indigo.Dict() representing the name/value pairs that are shared by all plugins. This is the property dictionary that you can edit via the Global Properties plugin, and your plugin may manage properties in this dictionary as well to add metadata to devices that your plugin can use for other purposes. Use trigger.replaceSharedPropsOnServer() to update them (as with pluginProps, you should get copy first, update the copy, then set them back to that copy so you do not accidentally remove some other plugin's props).
trigger=indigo.triggers[123]
indigo.trigger.delete(123)
Enable/Disable Trigger
Execute Trigger
State Change Type Enumeration
indigo.kStateChange
AnalogInput
BrightnessLevel
HumidityInput
SensorInput
SetpointCool
SetpointHeat
TemperatureInput
BinaryOutput
HvacCoolerIsOn
HvacFanIsOn
HvacFanModeIsAlwaysOn
HvacFanModeIsAuto
HvacHeaterIsOn
HvacOperationModeIsAuto
HvacOperationModeIsCool
HvacOperationModeIsHeat
HvacOperationModeIsOff
OnOffState
Zone
BrightnessLevel
HumidityInput
SensorInput
SetpointCool
SetpointHeat
TemperatureInput
BrightnessLevel
HumidityInput
SensorInput
SetpointCool
SetpointHeat
TemperatureInput
AnalogInput
BrightnessLevel
HumidityInput
SensorInput
SetpointCool
SetpointHeat
TemperatureInput
BinaryOutput
HvacCoolerIsOn
HvacFanIsOn
HvacFanModeIsAuto
HvacHeaterIsOn
OnOffState
Zone
AnalogInput
AnalogInputsAll
BinaryInput
BinaryInputsAll
BinaryOutput
BinaryOutputsAll
BrightnessLevel
HumidityInput
HumidityInputsAll
HvacCoolerIsOn
HvacFanIsOn
HvacFanMode
HvacFanModeIsAuto
HvacHeaterIsOn
OnOffState
SensorInput
SensorInputsAll
SetpointCool
SetpointHeat
TemperatureInput
TemperatureInputsAll
Zone
State Selector Enumeration
indigo.kStateSelector
Value Description
BinaryOutputsAll
KeypadButtonLedFIXME
    folder=1234)
theTrigger.deviceId = 738
theTrigger.stateValue = 80
theTrigger.replaceOnServer()
Email Filter Enumeration
indigo.kEmailFilter
Value Description
    folder=1234)
INSTEON Command Enumeration
indigo.kInsteonCmd
Value Description
Dimwhen a dim command begins
indigo.kDeviceSourceType
Value Description
    folder=1234)
theTrigger.buttonOrGroup = 1
    folder=1234)
    folder=1234)
    folder=1234),
    pluginTypeId="myEvent",
    folder=1234)
    folder=1234)
X10 Command Enumeration
indigo.kX10Cmd
Value Description
X10 A/V Button Enumeration
indigo.kX10AvButton
Value Value
0 Left
1 Menu
2 Mute
3 Pause
4 PC
5 Play
6 Power
7 Recall
8 Record
9 Return
AB Rewind
ChannelDown Right
ChannelUp Stop
Display Title
Down Up
Enter VolumeDown
Exit VolumeUp
Forward
    folder=1234)
myTrigger.address = "F7"
myTrigger.replaceOnServer()
indigo.kVarChange
Value Description
    folder=1234)
  • /www/perceptive/wiki/data/pages/indigo_2021.1_documentation/trigger_class.txt
