Indigo Mac Client
Main Window Image
The Home Window has 4 areas:
  1. Outline View
  2. Item List
  3. Item Detail
  4. Status Bar
Outline View Controls Image
Device Contextual Menu Image
This menu will:
  1. Enable/disable the event.
Device Details Tile Image
Custom States Tile Image
Lights/Appliances
On Off Dimmer Tile Image
Color Controls Tile Image
Sensor Controls Tile Image
Speed Controls
Speed Controls Image
Sprinklers
Sprinkler Controls Image
Thermostats
Thermostat Controls Image
Generic Output Devices
I/O Controls Image
Triggers and Schedules
Action Group Controls Image
Control Pages
Event Log Window Image
Click the Clear Window button to clear the log entries. Click on Show Event Logs Folder to open the Logs folder in the Finder. Here you will find one file for each day's events. You can change how many day's worth of event log files are stored by selecting Indigo 7→Preferences… and then selecting the General tab. There, you can enter the number of days of event log files that you want to keep. Indigo Server will delete all files outside that period of time.
Indigo 7 Menu Image
  • About Indigo 7 - this will show the About window which will show what client and server versions you're running and will show your registration code
  • Preferences… - this opens the preferences dialog
Subscription Status Image
File Menu Image
Window Menu Image
Help Menu Image
  • Email Log… - this option will email some of your event log data to the specified email address. Particularly useful for technical support
  • Indigo 7 Documentation - this will open your browser to the landing page for all Indigo 7 documentation
  • /www/perceptive/wiki/data/pages/indigo_2021.1_documentation/ui_tour.txt
