The Indigo Reflector Service
Reflector Flow Image
Reflectors provide:
  • 3rd party services like Amazon Alexa can get secure, authenticated access to your Indigo Server to open up a broad range of integration possibilities.
  • Hassle free setup:
  2. Turn on the Allow remote access checkbox and enter a User name and good Password. You will *definitely* want password authentication on since you are about to enable access to the Indigo web server from the Internet.
  3. Turn on the Enable secure internet access via Indigo Reflector checkbox.
  1. Shut down the Indigo Server (select Indigo 2021.2→Stop Server) but don't quit the Indigo Client
Manual Reset
  5. In the resulting dialog, copy and paste the following: /Library/Application Support/Perceptive Automation/Indigo 2021.2/Preferences/
  • /www/perceptive/wiki/data/pages/indigo_2021.2_documentation/reflectors.txt
