Install the FTDI VCP Drivers
For earlier versions of the OS, you can get the driver installer at FTDI's web site - be sure to get the installer that's appropriate for the architecture of your machine (Intel or PowerPC). If you select PowerLinc 2412U/2412S/2413U/2413S/2448 from the Interface type
with a separate USB to serial adapter, you can ignore that warning alert. Note: there are known issues with the FTDI driver and macOS High Sierra, Mojave, and Catalina on some Macs - check out our blog post for details.
Connecting the Interface
- Choose
Indigo 2021.2→Preferences…
menu, then make sure theInterfaces
tab is selected. - Select the
Enabled
checkbox next to theINSTEON / X10 Powerline Interface
item. - Double-click the
INSTEON/X10 Power Line Interface
line in the table (you can also get to this dialog by selecting theInterfaces→INSTEON/X10 Power Line→Configure…
menu item) - Choose your
Interface type
in the popup menu.- If you are using the PowerLinc 2412U/2413U/2448A7H interface, then the
Serial port:
popup menu will be enabled and the FTDI driver (see Install the Correct Drivers above) will create a newSerial port:
popup menu item that looks likeusbserial-XXXXXXXX
. Select that item. NOTE: you must have the FTDI driver installed already. - If you are using the PowerLinc 2414U/1132CU/1132U or the CM15 interface, then the
Serial port:
popup menu will be disabled because these interfaces do not use a virtual serial port driver. - If you are using one of the serial based interfaces (PowerLinc 2412S, CM11 / HD11, LynX-PLC), then the
Serial port:
popup menu will be enabled and you should choose which serial port adapter name the interface is connected to in theSerial port:
popup menu. NOTE: if no names are listed in theSerial port:
popup menu, then you probably do not have the proper driver installed for your USB serial adapter. Download your adapter's driver from the driver manufacturer's website.
- Optionally select the
Group addresses on transmission
checkbox to combine like-command transmissions together. For example A1-On, A3-On, A4-On, would be transmitted as A1, A3, A4, On. - Some interfaces, such as the PowerLinc V2 and LynX-PLC, have additional settings that can be accessed from the Interface Options… button. Generally, these options don't need to be changed unless you're troubleshooting a problem.
Choose the Interfaces→INSTEON/X10 Power Line→Disable
(or Enable
menu item. See connecting the Interface above for more details.
To add a new Insteon device:
- Press the
New…
button at the top of the Home window.
The Define and Sync…
dialog:
Resyncing Links
The Re-Sync Links…
dialog:
Replacing a Device
Managing INSTEON Links
Managing INSTEON Device Links
The primary place that you'll manage links between devices is in the Manage INSTEON Device Links dialog. Select the Interfaces→INSTEON/X10 Power Line→Manage Device Links
- Select the
menu item. - Select the module's device name to edit in the
Show links used by device
popup control.
New Link to Responder
button. If you want to change the settings (brightness, ramp rate duration, etc.) of an existing responder module in the scene, then select that module's link in the table with theLink to Responder Device
column title. - Choose the button or group number that identifies the scene you are defining in the controller (ex: RemoteLinc button #1) from the
broadcast of button/group number
popup control. - Choose the responder module's device name from the responder popup control (ex: LampLinc).
cool
andheat
setpoint temperatures. - Optionally turn on the
Persistent
checkbox to force this link to automatically be restored whenever either the responder module or controller module is synced. If the modules are ever reset, replaced, or have this link modified, then Indigo will automatically rewrite the original link on the next sync operation. - Repeat steps 1 through 5 for every new responder module that you want to add to the selected controller.
New Link to Controller
button. If you want to change the settings (brightness, ramp rate duration, etc.) used by the selected module in a controller's scene, then select the controller module's link in the table with theLink to Controller Device
column title. - Choose the controller module's device name from the On controller popup control (ex: RemoteLinc).
popup control. - When responding to a scene command, most modules will control the main load (light or appliance) connected to that module. For these modules (SwitchLinc, ToggleLinc, LampLinc, etc.) you can specify the exact brightness you want for that module as well as a duration for how quickly the module should go to that brightness using the % text box and the rate popup. Some modules will have different options. For example, when a KeypadLinc is responding to a scene command, it can turn one of the secondary button LEDs on instead of controlling the main load, or the thermostat module can respond to a scene command by changing both the thermostat operation mode via the mode popup and the current
cool
andheat
setpoint temperatures via those text boxes. - Optionally turn on the
Persistent
checkbox to force this link to automatically be restored whenever either the responder module or controller module is synced. If the modules are ever reset, replaced, or have this link modified, then Indigo will automatically rewrite the original link on the next sync operation. - Repeat steps 1 through 5 for every new controller module you want to add for the selected responder.
button to close the link editor window and write the changes to the modules at a later time. When you are ready to write the changes to the remote modules, select Start Sync Device Links…
button.
action.
Defining the Scene
- Choose
Manage PowerLinc Links…
from theInterfaces→INSTEON/X10 Power Line
menu. - Select a
PowerLinc Group/Scene
number to use for the scene. Use 1 if this is your first scene. - Optionally enter a
name in the edit field (ex: “reading in bed”).
button. If you want to change the settings (brightness, ramp rate duration, etc.) of an existing responder module in the scene, then select that module's link in the table in the top-half of the window. - Choose the responder module's device name from the
responder
popup control. - When responding to a scene command most modules will control the main load (light or appliance) connected to that module. For these modules (SwitchLinc, ToggleLinc, LampLinc, etc.) you can specify the exact brightness you want for that module as well as a duration for how quickly the module should go to that brightness by using the % text box and the duration popup. Some modules will have different options. For example, when a KeypadLinc is responding to a scene command it can turn one of the secondary button LEDs on instead of controlling the main load, or the thermostat module can respond to a scene command by changing both the thermostat operation mode via the mode popup and the current
cool
andheat
setpoint temperatures using the text boxes. - Optionally turn on the
Persistent
checkbox to force this link to automatically be restored whenever the responder module is synced. If the responder module is ever reset, replaced, or has this link modified, then Indigo will automatically rewrite the original link into the device when it is next synced. - Repeat steps 1 through 4 for every new module you want to add to the scene.
button.
Executing the Scene
- Select the
Actions
tab inside the edit window. - Select
INSTEON Actions→Execute INSTEON Scene
from the actionType
popup item. - Use the
Send
will turn off all of the modules immediately, ignoring any ramp rate duration.
Scene
popup item.
INSTEON Link Syncing
Resetting your PowerLinc
menu item - Unplug your PowerLinc and wait about 15 seconds
- Release the button
- In Indigo, select the
Interfaces→Insteon/X10 Power Line→Enable
menu item - Select the
Interfaces→Insteon/X10 Power Line→Configure…
menu item - Click the
Interface Options…
button - Click the
Sync Links
button
Replacing Your PowerLinc
submenu contains a collection of miscellaneous INSTEON commands that will help you manage specific aspects of devices as well as do so low-level INSTEON commands not directly supported in the UI:
Execute Raw INSTEON Command
Set Motion Sensor Timeout
Set LED Brightness
, Turn Off
, Leave Alone
Configure SynchroLinc
Set I/O Linc Momentary Mode
Set Siren Alarm Sound
Set Siren LED Mode
Set OutletLinc Load Sense
