Indigo Web Server
Web Assets Folder Structure
Indigo 2022.1 contains special folders that are accessible to the Indigo Web Server which are located in:
/Library/Application Support/Perceptive Automation/Indigo 2022.1/Web Assets/images /Library/Application Support/Perceptive Automation/Indigo 2022.1/Web Assets/plugins /Library/Application Support/Perceptive Automation/Indigo 2022.1/Web Assets/public /Library/Application Support/Perceptive Automation/Indigo 2022.1/Web Assets/static
images folder
plugins folder
With Indigo 2022.1, web server plugins are no longer supported.
public folder
For example:
static folder
For example:
Authentication
Information on Indigo Authentication options can be found on the Restful URLS page under the authentication section.
Example
<!DOCTYPE html>
<html lang="en">
<head>
<meta charset="utf-8">
</head>
Hello world.
</div>
</body>
</html>
