Back to Top
Folder Structure Image
in this location:
Back to Top
Bundle Layout Image
<plist version="1.0">
<dict>
    <key>PluginVersion</key>
    <string>1.2.3</string>
    <key>ServerApiVersion</key>
    <string>2.0</string>
    <key>CFBundleIdentifier</key>
    <key>CFBundleVersion</key>
    <string>1.0.1</string>
    <key>CFBundleURLTypes</key>
    <array>
        <dict>
            <key>CFBundleURLName</key>
        </dict>
    </array>
</dict>
</plist>
  • PluginVersion - this is the version number for your plugin - it’s shown to the user in the UI and will help you when supporting your plugin users. This key is required and should only contain numerical characters and periods (0-9 and .). For example, “1.0.5.2” is valid, but “1.0.5b2” is not. This is very important as it will help Indigo determine what do to when a user double-clicks a plugin to install it (it won't install old ones over new ones) and will eventually be used in version checking and automatic updates.
  • ServerApiVersion - this is the version of the server plugin API as defined by us. While we hope to keep API changes to a minimum, it’s prudent to version the server API used. This key is only required if your plugin implements a server plugin.
  • Bundle name (CFBundleName) - this is another standard macOS key, and it's a name that should be less than 16 characters long and be suitable for displaying in menu items with various strings appended (i.e. “ShortName Device Controls”). If it's not provided we'll use the bundle display name instead.
  • Bundle identifier (CFBundleIdentifier) - this is another standard macOS key, and it represents a unique string that represents your plugin. This is used for namespacing where necessary in the code, so it is critical that it is unique. The standard reverse DNS naming scheme is what should be used, although if you aren’t a company you’ll need to figure something out (maybe your blog, etc.). You should limit your bundle id to standard alphanumerics as special/extended characters may cause problems. You should not use the com.yourorgidentifier.* namespace. This key is required.
  • Bundle version (CFBundleVersion) - another standard macOS key, and it represents the layout of the bundle. This is controlled by us. This key is required.
  • URL types (CFBundleURLTypes) - you must specify one URL that represents a web page where your user can get support. Your plugin will have a menu item called “About [PLUGIN NAME]” - when the user selects this menu item, the default browser will open to this URL. Note - this can be a link to your plugin's GitHub repo wiki if there is one, or could be a forum topic in the “User Contributions” section of our user forums if you don’t have any other place to host the support page. This key is required.
Back to Server Plugins
Server Plugin Folder Image
  • id's cannot contain spaces
<ConfigUI>
    <Field id="autoLabel"
            type="label"
            visibleBindingValue="false">
    </Field>
    <Field id="exampleButton"
            type="button"
        <Title>Find Node ID</Title>
    </Field>
    <Field id="nodeID"
            type="textfield"
            readonly="YES"
        <Label>Node ID:</Label>
    </Field>
    <Field type="checkbox"
            id="manualEntry"
            defaultValue="false">
    </Field>
    <Field id="manualNodeID"
            type="textfield"
            visibleBindingValue="true">
        <Label>Enter Node ID:</Label>
    </Field>
</ConfigUI>
Text Field
    <Label>Text Field:</Label>
</Field>
Back to Configuration Dialogs
Configuration UI Menu Image
	<Label>Popup Menu:</Label>
</Field>
</Field>
    return valuesDict
List
COnfiguration UI List Image
	<Label>List:</Label>
</Field>
Dynamic Lists
</Field>
Dynamic List Attributes
Attribute Required Notes
The indigo.devices class specifies that the list will contain Indigo devices. If you don’t specify a filter, all devices defined by the user in Indigo will be returned. You can supply two filters if and only if one is an interface filter (see the first three in the list below). The filters are ANDed together, so one interface filter and one device type filter are the only combinations that will result in a non-empty list.
Class: indigo.devices
Optional Filters Description
indigo.relayrelay devices
indigo.dimmerdimmer devices
indigo.sprinklersprinklers
indigo.thermostatthermostats
Class: indigo.triggers
</Field>
	return myArray
</Field>
</Field>
Serial Port
Checkbox
	<Label>Checkbox:</Label>
</Field>
</Field>
    return valuesDict
Label
Configuration UI Label Image
	</Label>
</Field>
Separator
<Field id="simpleSeparator1"
		type="separator"
		visibleBindingValue="1"/>
Button
Configuration UI Button Image
		type="button"
		visibleBindingValue="1">
</Field>
The process flow is this:
    <Name>Music Server</Name>
    <ConfigUI>
            <Title>Begin Pairing</Title>
        </Field>
<!-- SNIP -->
</Device>
    return valuesDict
Validation Methods
    return True
    return (True, valuesDict)
    errorDict = indigo.Dict()
Validating serialport Fields
    errorsDict = indigo.Dict()
    if len(errorsDict) > 0:
Dialog Close Notification
Dialog Type Method Signature
<?xml version="1.0"?>
<PluginConfig>
</PluginConfig>
/Library/Application Support/Perceptive Automation/Indigo 2022.1/Preferences/Plugins/
Custom HTML Config Dialogs
You can also implement your own custom configuration in HTML if you prefer. Rather than adding lots of <Field> definitions, you simply specify a <URL> element. The URL specified can either be a fully specified URL (%%protocol:host/path%%) or it may be a relative URL (/some/relative/path). If it's the later then Indigo will attempt to guess the best base URL. You would then handle those form requests using the built-in request handling mechanism discussed below. See the Example HTTP Responder plugin in the SDK for an example. ==== Devices.xml ==== One of the main components that a server plugin can define is a device. In Indigo, devices are the primary objects that users deal with. Lights, thermostats, sprinklers, I/O devices are all examples of device types. One of the biggest requests we get is to support the [name your favorite device]. Obviously, we can’t keep up, so the server plugin architecture was designed to allow you to add device support to Indigo. The root element in the Devices.xml file is Devices. Contained in the Devices element are an unlimited number of Device elements that define the device types that your plugin will define. Each Device will contain a ConfigUI element to collect the specific configuration information for a device (note that you don’t need to include name, description, or typeId from the user - Indigo will collect those for you). Here are the specific attributes and elements that can be defined in a Device element: === Device Types === ^Name ^ Type ^ Required ^Notes ^ |type| Attribute | Yes |This must be one of: dimmer, relay, sensor, speedcontrol, thermostat, or custom. We’ll discuss each below.| |id| Attribute | Yes |This is your plugins unique identifier for this device type. It must be unique in this plugin.| |subType| Attribute | No |This must be one of: kDimmerDeviceSubType, kRelayDeviceSubType, kSensorDeviceSubType. We’ll discuss each below. There are also several device SubType examples in the Indigo SDK. | |allowUserCreation| Attribute | No |If set, the value must either be true or false (defaults to true). This attribute is discussed in more detail below. | |Name| Element | Yes |This is the name of the device type that users will see when selecting the type in the Devices dialog.| |ConfigUI| Element | No |This is the custom UI for configuring the device. It’s optional, but in reality we can’t envision a device that needs no configuration. If the optional <ConfigUi> element is not used, the “Edit Device Settings…” button will be displayed, but disabled.| |States| Element | No |This element is used to describe the possible states for the device. For custom devices it is all available states. For subclassed devices it will describe any additional states for the device. See the description below for more details.| <code> <?xml version=“1.0”?> <Device type=“sensor” id=“my_temp_sensor”> <Name>Example Temperature Sensor Module</Name> <ConfigUI> <Field id=“address” type=“textfield” defaultValue=“123”> <Label>Module Address:</Label> </Field> </ConfigUI> <States> <State id=“temperature”> <ValueType>Integer</ValueType> <TriggerLabel>Temperature</TriggerLabel> <ControlPageLabel>Temperature</ControlPageLabel> </State> </States> </Device> </code> === Device Sub-Types === ^Name ^ SubType ^Attribute(s) ^Notes ^ |Device | kDeviceSubType |Amplifier, Automobile, Camera, Keypad, Mobile, Remote, Robot, Security, Speaker, Streaming, Television, Weather, Other |For example, indigo.kDeviceSubType.Amplifier | |Dimmer | kDimmerDeviceSubType |Blind, Bulb, ColorBulb, ColorDimmer, Dimmer, Fan, InLine, Outlet, Plugin, Value |For example, indigo.kDimmerDeviceSubType.Dimmer | |Relay | kRelayDeviceSubType |DoorBell, DoorController, GarageController, InLine, Lock, Outlet, Plugin, Siren, Switch |For example, indigo.kRelayDeviceSubType.Switch | |Sensor | kSensorDeviceSubType |Analog, Binary, CO, DoorWindow, GasLeak, GlassBreak, Humidity, Illuminance, Motion, Presence, Pressure, Smoke, Tamper, Temperature, UV, Vibration, Voltage, WaterLeak, Zone |For example, indigo.kSensorDeviceSubType.Temperature | %%*%% There are no device sub-types for other built-in devices at this time. In Devices.xml <code> <Device type=“sensor” subType=“kSensorDeviceSubType.Temperature” id=“my_temp_sensor”> <Device type=“sensor” subType=“kSensorDeviceSubType.Temperature, ui=Outdoor Temperature” id=“my_temp_sensor” <Name>Example Adjustable Sensor Module</Name> … </code> Device Subtype Example Image In Python: <code> newdev = indigo.device.create(indigo.kRelayDeviceSubType.Plugin, deviceTypeId=“Device1”) newdev.model = “Device 1 Model” newdev.subModel = “Sub Model 1” newdev.name = u”Device 1” </code> To get information on the device group: <code> indigo.device.getGroupList(dev.id) </code> When the allowUserCreation attribute is present and set to false, Indigo will not display the device model type when the user elects to create a new device (the “Model” dropdown will not contain the device type). This is especially useful for complex devices that have multiple sub-types that are set programmatically (but not created using the Device Factory approach). Your plugin may not support individual sub-types as stand-alone devices and, therefore, you wouldn't want users to be able to create them. The allowUserCreation attribute was introduced with Indigo version 2022.1.2 and API 3.1. <code> <Device type=“sensor” subType=“kSensorDeviceSubType.Temperature, ui=Outdoor Temperature” id=“my_temp_sensor”, allowUserCreation=“false”> </code> Check out the SDK for example plugins of each type of device listed above. The examples show config dialogs, required method stubs, etc., to implement the respective device types. > IMPORTANT: Plugin developers should account for each devices' callbacks when implementing built-in device types – even if you don't use all the callbacks within your plugin. For example, if your plugin implements the Speed Control device type, your plugin should include handlers for all the Speed Control callbacks – such as turnOn, turnOff, or toggle. This is very important because these callbacks will still be exposed in the Indigo Client UI for things like Actions and Triggers. It's best to give users an indication that the callback won't do anything in your plugin by writing a warning to the Event log. Consult the SDK for more information on each device types' callbacks and examples of how to handle them. === Custom Device Type === The custom device type is special because it’s completely custom. Therefore, you must specify everything about the device - it’s states and their types (Number, String, List (enumeration), Boolean). So, here’s a simple example of the <States> element of a custom device, in this case a thermostat: <code><States> <State id=“temperature”> <ValueType>Number</ValueType> <TriggerLabel>Temperature</TriggerLabel> <ControlPageLabel>Temperature</ControlPageLabel> </State> <State id=“heatSetPoint”> <ValueType>Number</ValueType> <TriggerLabel>Heat Setpoint</TriggerLabel> <ControlPageLabel>Heat Setpoint</ControlPageLabel> </State> <State id=“coolSetPoint”> <ValueType>Number</ValueType> <TriggerLabel>Cool Setpoint</TriggerLabel> <ControlPageLabel>Cool Setpoint</ControlPageLabel> </State> <State id=“mode”> <ValueType> <List> <Option value=“off”>Off</Option> <Option value=“heatOn”>Heat On</Option> <Option value=“coolOn”>Cool On</Option> <Option value=“heatCoolOn”>Heat and Cool On</Option> </List> </ValueType> <TriggerLabel>Operation Mode Changed</TriggerLabel> <TriggerLabelPrefix>Mode Changed to</TriggerLabelPrefix> <ControlPageLabel>Current Mode</ControlPageLabel> <ControlPageLabelPrefix>Mode is</ControlPageLabelPrefix> </State> </States></code> Each State listed in the States element will be available in various parts of the UI, including the “Device State Changed” Event dialog. The State element has several attributes and elements that should be defined: ^Name ^ Type ^ Required ^Notes ^ |id| Attribute | Yes |This is a unique identifier for this State within the context of this Device element. IDs must follow the XML standard in terms of construction with one addition: they may not include periods ('.') - periods are reserved for internal use only.| |readonly| Attribute | No |If you want this state to be read only, set this attribute to “YES”. For instance, as in this example, the temperature the thermostat is sensing isn’t user settable. (Currently unused but it may be used in the future)| |ValueType| Element | Yes |This is the type of the state, which must be one of the following: Boolean, Number, List (enumeration constructed just like the <List> element of a <Field> as described above), String, and Separator (used only to visually group your states in the various popups). The <ValueType> element may also have an optional attribute if the value is Boolean: boolType can be: “TrueFalse” (default), “OnOff”, “YesNo”, and “OneZero”. Example: <ValueType boolType=”OnOff”>Boolean</ValueType>| |TriggerLabel| Element | Yes |When selecting “Device State Changed” type trigger events, you can select your device in the resulting list. A popup below the device will list all of your States using this text.| |TriggerLabelPrefix| Element | No |When defining an enumeration, trigger change label is usually going to need to be a bit different than just the trigger label (“Mode Changed to Heat” vs “Operation Mode Changed” - the former is to test a specific change, the latter will trigger on any change). To accomplish this, you can specify a prefix that’s prepended to the actual state value (with a space in between). See the example above. | |ControlPageLabel| Element | Yes |In the Control Page Editor, when selecting “Device State” as the display type, then select your device, the next popup will show all your states using this text.| |ControlPageLabelPrefix| Element | No |When defining an enumeration, the control page label is usually going to need to be a bit different (“Mode is Heat” vs “Current Mode” - the former will show whether a the state is true, the latter shows the state value). You can specify a prefix that’s prepended to the actual state value (with a space in between). See the example above.| The ValueType element is particularly important - it controls what types of controls are presented to the user in the UI: an integer tells it to show greater than, less than, equal to, not equal to, etc and a way to enter a number (in the case of a trigger). See the States section of the Devices Class page for details on how to set states once the IndigoServer understands the structure of your device's states. ==== Events.xml ==== The XML in this file describes all events that your plugin will generate for use in Indigo. Your users will use these in the Trigger Events dialog just like any of the built-in Indigo events (like Power Failure, Email Received, etc). Device State Changed events are handled by the <States> defined in the <Device> elements described above, but your plugin can offer other types of events, including update notifications, battery low notifications, button press notifications, etc. Here’s a very small Events.xml file that just defines a plugin update event: <code><?xml version=“1.0”?> <Events> <SupportURL>http://www.yourdomain.com/plugin/pluginEvents.html</SupportURL> <Event id=“updateAvailable”> <Name>Plugin Update Available</Name> </Event> </Events></code> As you can see, your <Event> elements can define a <SupportURL> element as well - the trigger events dialog now has a help button on it and if one of your events is selected clicking on the help button will take your user to the specified URL. If you don’t specify one then the default help page for all trigger events will show. You can specify an Event to be a separator in your event list so that when they're displayed in the UI there is a visual separation. Simply insert an Event defined like this between two other Event elements: <code><Event id=“sep1”/></code> While you don't have to include any elements, the id still must be unique. Here’s how to construct your <Event> elements: ^Name ^ Type ^ Required ^Notes ^ |id| Attribute | Yes |This is a unique id for the event in this Events.xml file.| |Name| Element | Yes |This is the text that’s shown in the trigger event dialog that represents this event.| |ConfigUI| Element | No |If your event requires any configuration, you can specify a <ConfigUI> element that’s defined exactly as above.| ==== Actions.xml ==== Your plugin will also very likely define some actions that a user can take. This is where you define those. Here’s a simple example: <code><?xml version=“1.0”?> <Actions> <SupportURL>http://www.yourdomain.com/plugin/pluginActions.html</SupportURL> <Action id=“resetInterface”> <Name>Reset Interface</Name> <CallbackMethod>resetInterface</CallbackMethod> </Action> </Actions></code> As with <Event>, your <Action> elements can define a <SupportURL> element as well - the actions dialog now has a help button on it and if one of your actions is selected clicking on the help button will take your user to the specified URL. If you don’t specify one then the default help page for all actions will show. You can specify an Action to be a separator in your action list so that when they're displayed in the UI there is a visual separation. Simply insert an Action defined like this between two other Action elements: <code><Action id=“sep1”/></code> While you don't have to include any elements, the id still must be unique. Here’s how you construct your <Action> elements: ^Name ^ Type ^ Required ^Notes ^ |id| Attribute | Yes |This is a unique id for the event in this Actions.xml file.| |deviceFilter| Attribute | No |If present a popup list of devices that match the specified device filter will be shown in the UI. Many actions may not need any configuration beyond a device selection so we've enabled you to specify that a device must be selected and passed to the action's CallbackMethod. This will avoid the necessity to create a ConfigUI element with just a device popup.| |uiPath| Attribute | No |Added in API v1.4. You can specify where in the menu hierarchy your action will be placed. By default, Indigo will create a submenu at the bottom of the Actions list and put your actions there. If you specify “DeviceActions”, Indigo will create a submenu on the Device Actions menu and put your actions there. If you specify “NotificationActions”, Indigo will insert your action n the Notification Actions menu without a submenu (be sure to name your action appropriately so that it's clear what it does). Added in API v2.0: use “hidden” to hide the action in the UI. Useful for actions that are only intended to be used from scripts/plugins (an API of sorts).| |Name| Element | Yes |This is the text that’s shown in the actions dialog that represents this action.| |CallbackMethod| Element | Yes |This is the name of the method that implements the action in your code.| |ConfigUI| Element | No |If your action requires any configuration (as most will), you can specify a <ConfigUI> element that’s defined exactly as above.| Here is the code that implements the Write to Log action defined in the Action Collection plugin: <code>def writeToLog(self, action): # call for variable substitution on the message field they entered theMessage = self.substitute(action.props.get(“message”, ”“)) # set the type for the message if they configured one theType = action.props.get(“type”) # debugging - show the message if debugging is enabled self.debugLog(u”Write to log: “ + theMessage) # if they entered a type, log the message with it, otherwise log the message without a type if theType: indigo.server.log(theMessage,type=theType) else: indigo.server.log(theMessage)</code> Notice the call to self.substitute() - this method is defined in the plugin base class. If your user inserts <code>%%v:12345%%</code> into their string where 12345 is the ID of a variable, the call will return a string with all variable occurrences substituted. If your user inserts <code>%%d:12345:someStateId%%</code> into their string where 12345 is the ID of a device and someStateId is a valid state identifier, the call will return a string with all device state occurrences substituted. Note: To increase the value of your plugin, you should ensure that you test and document the necessary information so that Python scripters can script your plugin's actions - for instance, a scripter can tell the iTunes plugin to pause playback. You can provide that information in a relatively straight-forward way in your plugin's documentation as we've done with our plugins (check the Airfoil and iTunes docs for examples). You shouldn't really have to do much - but you should test each action. Sometimes you can make assumptions about the data that you get from your action's ConfigUI that you may want to change - for instance you may expect data when it would be advantageous to not include it (optional data) from a scripters perspective. ==== MenuItems.xml ==== Your plugin may also define menu items, which will be shown at the bottom of your plugin’s sub-menu on the Plugins menu - they will be the last thing in the menu unless you also include scripts in the Menu Items folder of your plugin’s bundle. If there are scripts there, they will be last, and a separator will be placed between the menu items defined in this XML file and any script files. Here’s a sample MenuItems.xml file: <code><?xml version=“1.0”?> <MenuItems> <MenuItem id=“menu1”> <Name>Reset Interface</Name> <CallbackMethod>resetInterface</CallbackMethod> </MenuItem> <MenuItem id=“menu2”> <Name>Check for Updates</Name> <CallbackMethod>checkForUpdates</CallbackMethod> </MenuItem> <MenuItem id=“menu3”> <Name>Turn Off Light…</Name> <CallbackMethod>turnOffLight</CallbackMethod> <ButtonTitle>Turn Off</ButtonTitle> <ConfigUI> <Field id=“targetDevice” type=“menu”> <Label>Light:</Label> <List class=“self” filter=“self.myLightType” method=“getDynamicList” /> </Field> </ConfigUI> </MenuItem> <!– Added in v1.2 –> <MenuItem id=“menu4”> <Name>Execute Some Action</Name> <ConfigUI actionId=“someAction”/> </MenuItem> </MenuItems></code> It’s pretty straight-forward. The MenuItems element will contain multiple <MenuItem> elements. Here’s how to construct a <MenuItem>: ^Name ^ Type ^ Required ^ API Version ^Notes ^ |id| Attribute | Yes | 1.0 |This is a unique id for the menu item in this file.| |Name| Element | Yes | 1.0 |This is the text that’s shown in your plugin’s sub-menu.| |CallbackMethod| Element | No | 1.0 (1.1) |This is the name of the method defined in your plugin that will be called when your user selects this menu item.
API v1.1: If you specify a <ConfigUI> for the menu, then this property is optional. If it's present, then the the method will be called with arguments much like a validation (see example below). If it's not present (in which case a ConfigUI must be present), then the dialog will contain only a single “Close” button. In that case the functionality in the dialog will be completely left up to buttons contained within the dialog.| |
ConfigUI| Element | No | 1.1 (1.2) |If you want a menu to open an associated dialog, you can include a standard ConfigUI element (see Configuration Dialogs above for details).
API v1.2: You may also specify an actionId attribute on this element with the id of one of your actions and that action UI will be executed rather than having to specify the UI itself. If it requires a device ID that will be added at the top of the dialog. Ex: <ConfigUI actionId=“actionIdHere”/>| |
ButtonTitle| Element | No | 1.1 |If you have a ConfigUI element and a CallbackMethod, you can add this element to specify the title used on the button that executes the dialog. By default it's “Execute”.| Here's an example of a menu item method definition in your plugin.py file for the “Check for Updates” menu item above: <code>def checkForUpdates(self): indigo.server.log(u”checkForUpdates called“) # Do the actual work here to see if there are any updates</code> As of API v1.1 you can have your menu item open a dialog which will allow you to gather input from a user before executing the action. Just add a <ConfigUI> element to your MenuItem definition and define that dialog just like any other. There are a couple of differences between this dialog and other dialogs. First, the CallbackMethod for menu items will be used rather than a validation method. It will, however, operate in much the same way. If you specify a CallbackMethod then it will get called with the valuesDict and the menu item's ID. You can return True, which will cause the dialog to close, or return false with an error dictionary which will mark the invalid fields just like the validation method would. You also have the option of adding a ButtonTitle element - which will allow you to change the name of the button (it defaults to “Execute”). If you don't specify a CallbackMethod then the dialog will not have Execute and Cancel buttons but rather will have just a single “Close” button. Why? We wanted to allow you the flexibility of making a dialog perform multiple actions if you like using button field types within the dialog itself. When doing that it would be awkward to have an “Execute” button that didn't really do anything. Here's an example of a menu item method definition in your plugin.py file for the “Turn Off Light” menu item above: <code>def turnOffLight(self, valuesDict, typeId): indigo.server.log(“Turning off light: %s” % valuesDict[“targetDevice”]) # perform the action here. If there are errors in any of the fields then # you can return (False, valuesDict, errorsDict) just like a validation # method and the dialog won't close and will show the errors. If you # return True then the dialog will close when the method completes. errorsDict = indigo.Dict() return (True, valuesDict, errorsDict)</code> === Custom HTML Menu Item Dialogs === You can also implement your own custom menu item form in HTML if you prefer. Rather than adding <CallbackMethod> and <ConfigUI> definitions, you simply specify a <URL> element. The URL specified can either be a fully specified URL (%%protocol:host/path%%) or it may be a relative URL (/some/relative/path). If it's the later then Indigo will attempt to guess the best base URL. You would then handle those form requests using the built-in request handling mechanism discussed below. See the Example HTTP Responder plugin in the SDK for an example.
General Plugin Methods
__init__(self,
         pluginId,
         pluginDisplayName,
         pluginVersion,
         pluginPrefs)
__del__(self)
def __del__(self):
startup(self)
def startup(self):
shutdown(self)
No This method will get called when the IndigoServer wants your plugin to exit. If you define a global shutdown variable, this is the place to set it. Other things you might do in this method: if your plugin uses a single interface to talk to multiple devices, this is the place where you would want to shut down that interface (close the serial port or network connection, etc). Each device and trigger will already have had a chance to shut down by the time this method is called (see the methods below).
def shutdown(self):
runConcurrentThread(self)
    while True:
        # Do your stuff here
        self.sleep(60) # in seconds
except self.StopThread:
    # do any cleanup here
    pass
stopConcurrentThread(self)
    self.stopThread = True
prepareToSleep(self)
wakeUp(self)
Device Specific Methods
getDeviceStateList(self,
                   dev)
getDeviceDisplayStateId(self,
                        dev)
deviceStartComm(self,
                dev)
deviceStopComm(self,
               dev)
                            origDev,
                            newDev)
deviceUpdated(self,
              origDev,
              newDev)
deviceDeleted(self,
              dev)
Trigger Specific Methods
triggerStartProcessing(self,
                       trigger)
triggerStopProcessing(self,
                      trigger)
                                   origTrigger,
                                   newTrigger)
triggerCreated(self,
               trigger)
triggerUpdated(self,
               origTrigger,
               newTrigger)
triggerDeleted(self,
               trigger)
Schedule Specific Methods
Action Group Specific Methods
Name Required Notes
Variable Specific Methods
Name Required Notes
variableCreated(self, var)
variableDeleted(self, var)
Helper Methods
                                bundleID)
browserOpen(self,
            url)
debugLog(self,
         msg)
errorLog(self,
         msg)
openSerial(self,
         ownerName,
         portUrl, baudrate, bytesize,
         parity, stopbits, timeout,
         dsrdtr, interCharTimeout)
sleep(self,
         seconds)
seconds - the sleep duration as a real number None This method should be called from within your plugin's runConcurrentThread() defined method, if it is defined. It will automatically raise the StopThread exception when the Indigo Server is trying to shut down or restart the plugin. See runConcurrentThread documentation above for more details.
substituteVariable(self,
                   inString,
                   validateOnly=False)
String
if validateOnly is False
(BOOL, errStr)
if validateOnly is True
%%v:VARID%%
substituteDeviceState(self,
                      inString,
                      validateOnly=False)
String
(BOOL, errStr)
%%d:DEVICEID:STATEKEY%%
substitute(self,
           inString,
           validateOnly=False)
Properties
Property Value Type Notes
pluginFolderPath
pluginSupportURL
Attribute Description
self.indigo_log_handler
For convenience, the various log levels are represented in color in the Indigo Event Log.
  • Debug
  • Plugin
  • Warning
  • Error
  • Critical Error
In a future release, we hope to change the server's internal logging to use these same 5 log levels. When we do so, you won't have to do anything - we'll just update the self.indigo_log_handler instance to emit the appropriate messages to the server.
self.plugin_file_handler
Log Levels
class MyClass(object):
    def __init__():
Custom IndigoLogHandler
exc_info
    x = 1 / 0
Full Example
import logging
def __init__(self):
        x = 1 / 0
    except ZeroDivisionError:
Which yields:
    x = 1 / 0
import logging
Embedded Script Logging Image
  • If for some reason you can't include the header, you may pass the API key as an additional GET argument on the URL (?other=args&api_key=KEYHERE)
  • The user may also enable Basic HTTP authentication and pass the username and password on the URL (https://username:[email protected]/message/PLUGINID/actionId/). Note this is less secure and not recommended.
    <Name>some message</Name>
</Action>
    return some_value
Key Value
file_path this will be a list of path parts from the URL after the action ID. So for the url: %%http://host/message/pluginid/actionid/path/to/some/file.txt%% the value will be an indigo.List with the following items: %%[“path”, “to”, “some”, “file.txt”]%%
KeyValue
StatusMeaning
KeyValue
Usage Guidance
  • Binary data - this release of the API isn't designed for binary data
Back to Top
  • /www/perceptive/wiki/data/attic/indigo_2022.1_documentation/plugin_guide.1744661437.txt.gz
