apiVersion | string | No | API v1.7: the currently connected Indigo Server plugin API version as a string (ex: “1.7”) |
connectionGood | boolean | No | true if the connection to the Indigo Server is currently good |
licenseStatus | string | No | API v2.5: returns one of the values specified in the indigo.kLicenseStatus enumeration below |
portNum | integer | No | the port number of the currently connected Indigo Server |
License Status Enumeration
indigo.kLicenseStatus |
Value | Description |
ActiveTrial | the license is a trial |
ActiveSubscription | license has an active Indigo Up-to-Date subscription (access to a reflector) |
ExpiredSubscription | license has an expired Indigo Up-to-Date subscription (no access to a reflector) |
Unknown | license is in an unknown state |
Broadcast to Subscribers
Command Syntax Examples |
Calculate Sunrise
Parameters |
direct parameter | No | datetime.date | a datetime.date object representing the day to calculate the sunrise time for |
Calculate Sunset
Parameters |
Event Log List
Parameters |
returnAsList | No | boolean | if true a list of dicts is returned containing individual log entry attributes; if false a string containing a textual description of the log lines is returned - the default is false |
lineCount | No | integer | the number of lines to return from the event log starting from newest and going backwards in time - the default is 1500 |
showTimeStamp | No | boolean | indicate whether every line should have it’s timestamp prepended to the log entry - the default is true |
Get Database File Name
Get Database File Path
Get Deprecated Elements
Returns the server's list of elements that have attributes orproperties that are now deprecated.
Get Install Folder Path
Get Latitude and Longitude
lat = latLong[0]
long = latLong[1]
Get Plugin
Parameters |
direct parameter | Yes | string | the id of the plugin to retrieve |
Get Plugin List
Get Reflector URL
Get Serial Ports
Parameters |
for posixPath in ports:
print(posixPath)
print(uiName)
# iterate through both
print(posixPath)
print(uiName)
Get Time
indigo.server.getTime()
No Parameters
Get Web Server URL
Reflector (https://reflector.indigodomo.net
) if a reflector is configured.
Bonjour name (http://MacName.local:PORT
) if it can be determined.
Localhost (http://localhost:PORT
) if all else fails.
No Parameters
Log
Parameters |
direct parameter | Yes | string | this is the text that’s written to the log |
level | No | integer | API v2.4: the python logging level which determines both the type shown and the text color used. (ex: using level=logging.WARNING will show orange text) |
isError | No | boolean | if True , it will show up in red in the event log - default is False - if no type is included, the name of the plugin will automatically be used with “ Error” appended |
Remove All Delayed Actions
Restart Plugin
Save Plugin Preferences
Send Email
Parameters |
direct parameter | Yes | string | a semicolon separated string of email addresses |
Speak
Parameters |
direct parameter | Yes | string | the string to speak |
Stop Plugin
Tell the server to shutdown our plugin process. Plugin will remain enabled but be in a stopped state. This command can only be called from a plugin and it refers to the plugin itself (not all plugins).
Subscribe To Log Broadcasts
indigo.server. subscribeToLogBroadcasts("text to speak", waitUntilDone=True)
Wait Until Idle
indigo.server. waitUntilIdle("text to speak", waitUntilDone=True)
