NOAA Weather
Plugin Config
Device States
Current Condition- The current condition in a word or twoCurrent Condition Icon- The current condition icon - Indigo ships with “NOAA Condition+.png” and it's children, one for each condition that's returned in this field. So, in the control page editor, select this state and “NOAA Condition+.png” and you'll have a nice conditions icon (images provided by NOAA).Dew Point °C- Dew point in CelsiusDew Point °F- Dew point in FahrenheitDew Point String- Dew point in a human-readable stringHeat Index °C- Heat index in CelsiusHeat Index °F- Heat index in FahrenheitHeat Index String- Heat index in a human-readable stringHumidity- The relative humidityLatitude- LatitudeLocation- Location in human-readable formLongitude- LongitudeObservation Date/Time- The last time NOAA updated the data. This field is inYYYY-MM-DD HH:MM:SSso it can be parsed by other software if needed.Pressure (inches)- Pressure in inchesPressure (mbar)- Pressure in millibarsQuality Codes- For scripters to account for the relative quality of the various weather observations (JSON). This state is only available in Indigo 2022.1 and later. See below for what the codes mean.Temperature °C- Temperature in CelsiusTemperature °F- Temperature in FahrenheitTemperature String- Temperature in a human-readable string (i.e. “98.0 F (36.7 C)”) - this is the state shown in the “State” column for a Weather Station deviceTime Zone- The timezone as it applies to the observed location. This state is only available in Indigo 2022.1 and later.Visibility- Visibility in milesWind Degrees- Wind direction in degreesWind Direction- Wind direction description in something close to human-readable formWind Knots- Wind speed in knotsWind MPH- Wind speed in miles per hourWind String- A description of the wind in human-readable form
Quality Codes
| MADIS QC Information - Surface QC Data Descriptor Values | |
| No QC available | |
| Z | Preliminary, no QC |
| Automated QC checks | |
| C | Coarse pass, passed level 1 |
| S | Screened, passed levels 1 and 2 |
| V | Verified, passed levels 1, 2, and 3 (BEST) |
| X | Rejected/erroneous, failed level 1 |
| Q | Questioned, passed level 1, failed 2 or 3, where: |
| Quality Levels | |
| level 1 = validity | |
| level 2 = internal consistency, temporal consistency, statistical spatial consistency checks | |
| level 3 = spatial consistency check | |
import json
dev = indigo.devices[12345678] codes = dev.states['qualityCodes'] quality_codes = json.loads(codes) temp_quality = quality_codes['temperature']
indigo.server.log("trust")
Scripting Support
Support and Troubleshooting
