key_value_list = [
"allowOnStateChange": false,
"protocol": "ZWave",
"configured": true,
"states": {
"onOffState": true,
"batteryLevel.ui": "100%",
"batteryLevel": 100
"subType": "",
"globalProps": {
"zwConfigVals": {},
"zwShowWakeIntervalUI": true,
"zwModelId": 0,
"zwClassIds": [
4,
7,
1
"zwShowDumpDevToLog": false,
"zwLibType": 3,
"SupportsBatteryLevel": true,
"zwProtoVersMajor": 4,
"zwEndpointDevTypeMap": {},
"userWakeInterval": 60,
"indigoObjVersion": 10,
"version": "5.01",
"zwClassCmdMap": {
"c134": 1,
"c90": 1,
"c133": 1,
"c132": 2,
"c89": 1,
"c94": 1,
"c128": 1,
"c122": 1,
"c115": 1,
"c114": 1,
"c113": 1,
"c32": 1
"SupportsOnState": true,
"zwShowMainUI": true,
"zwAppVersMinor": 1,
"userPollInterval": 0,
"zwDevSubIndex": 0,
"zwEncryptClassCmdMap": {},
"address": 17,
"zwEndpointClassMap": {},
"zwModelDefnVers": 0,
"zwManufactureId": 0,
"SupportsSensorValue": false,
"zwAssociationsMap": {
"g1": [
1
"zwShowPollingUI": false,
"zwWakeInterval": 60,
"zwClassCmdBase": 0,
"zwAppVersMajor": 5,
"zwProtoVersMinor": 5,
"zwNodeNeighbors": [
1,
15,
16
"userPollingEnabled": true
"pluginProps": {},
"buttonGroupCount": 0,
"id": 854505717,
"supportsAllOff": false,
"errorState": "",
"remoteDisplay": true,
"energyAccumBaseTime": null,
"displayStateValUi": "on",
"subModel": "",
"version": "5.01",
"energyAccumTimeDelta": null,
"batteryLevel": 100,
"supportsSensorValue": false,
"ownerProps": {
"zwConfigVals": {},
"zwModelId": 0,
"zwClassIds": [
4,
7,
1
"zwLibType": 3,
"version": "5.01",
"zwClassCmdMap": {
"c134": 1,
"c90": 1,
"c133": 1,
"c132": 2,
"c89": 1,
"c94": 1,
"c128": 1,
"c122": 1,
"c115": 1,
"c114": 1,
"c113": 1,
"c32": 1
"zwDevSubIndex": 0,
"address": 17,
"g1": [
1
1,
15,
16
"description": "",
"onState": true,
"energyAccumTotal": null,
"address": "17",
"sharedProps": {},
"folderId": 1145028206,
"supportsOnState": true,
"sensorValue": null,
"energyCurLevel": null,
"enabled": true,
"displayStateValRaw": true,
sharedProps | dictionary | No | 2.3 | an indigo.Dict() representing the name/value pairs that are shared by all plugins. This is the property dictionary that you can edit via the Global Properties plugin, and your plugin may manage properties in this dictionary as well to add metadata to devices that your plugin can use for other purposes. Use dev.replaceSharedPropsOnServer() to update them (as with pluginProps, you should get copy first, update the copy, then set them back to that copy so you don't accidentally remove some other plugin's props). |
Protocol Enumeration
| indigo.kProtocol |
Value | Description |
State Image Sel Enumeration
API v1.18+ only:
| indigo.kStateImageSel |
NoImage | overrides to show no device image icon (was None in previous API versions) |
Custom | overrides to show a plugin defined custom image icon (not yet implemented; shows NoImage) |
dev=indigo.devices[123]
<State id="playStatus">
<State id="sep1">
<State id="playlist">
<ValueType>String</ValueType>
<State id="album">
<State id="artist">
<State id="track">
<State id="volume">
<State id="shuffle">
# to update the volume state
# to update the track name
# to update the album name
# to update the artist name
# to update the playStatus
Commands (indigo.device.*)
All Off
indigo.device.allOff()
| Parameters |
indigo.kAllDeviceSel |
Beep
indigo.device.beep(123)
| Parameters |
Create a device. You can create devices that are defined by your plugin, in other plugins, and X10 devices (
you can't currently add INSTEON devices because they need to perform some action to actually make the device function). You use this method to create ALL device types - it will return a device of the correct class to you based on the arguments. It can be considered the “device” factory method.
address='F8',
name='Device Name Here',
folder=1234)
| Parameters |
deviceTypeId | Yes | string | the id of the device type – defined by the plugin or one of the defined X10 devices. |
indigo.device.delete(123)
| Parameters |
| Parameters |
Enable/Disable
| Parameters |
Get Group List
| Parameters |
| Parameters |
ID : 1280166770 (integer)
ID : 106487666 (integer)
| Parameters |
Ping Device
if result["Success"]:
| Parameters |
| Parameters |
| Parameters |
| Parameters |
Status Request
| Parameters |
Toggle
indigo.device.toggle(123)
| Parameters |
Turn Off
indigo.device.turnOff(123)
| Parameters |
Turn On
indigo.device.turnOn(123)
| Parameters |
Unlock
indigo.device.unlock(123)
| Parameters |
Lock
indigo.device.lock(123)
| Parameters |
# Creating a device
name="Office Lamp",
address="F7",
# Getting a device
# Getting a device
if (myDevice.remoteDisplay):
all off
Commands (indigo.dimmer.*)
All Lights Off
indigo.dimmer.allLightsOff()
| Parameters |
All Lights On
indigo.dimmer.allLightsOn()
| Parameters |
Brighten
indigo.dimmer.brighten(123)
| Parameters |
Dim
indigo.dimmer.dim(123)
| Parameters |
Set Brightness
| Parameters |
Set LED State
| Parameters |
Set Color Levels
redLevel,
greenLevel,
blueLevel,
whiteLevel,
whiteLevel2,
whiteTemperature,
delay,
suppressLogging,
updateStatesOnly
| Parameters |
redLevel | No | integer | 0 - 100 |
greenLevel | No | integer | 0 - 100 |
blueLevel | No | integer | 0 - 100 |
whiteLevel | No | integer | 0 - 100 |
whiteLevel2 | No | integer | 0 - 100 |
whiteTemperature | No | integer | 1200 - 15000 |
delay | No | integer | Defaults to 0. |
suppressLogging | No | integer | Defaults to False |
updateStatesOnly | No | integer | is an argument that exists on several device instance APIs that has Indigo update its device state/UI but does not have the corresponding action sent out to physical module. The use cases for this are pretty few, but sometimes you just want the internal state to update and can skip the actual command to the module. Defaults to False |
# RGB value / 255 * 100
redLevel = 128
Set On State
# Getting a device
(myDevice.onState)):
myDevice.folderId
# OR
Commands (indigo.iodevice.*)
Set Binary Output
| Parameters |
index=1,
value=False)
Commands (indigo.sensor.*)
Set On State
| Parameters |
Commands (indigo.relay.*)
Set LED State
| Parameters |
# Toggle the device
Decrease Speed Index
Decreases the speed index.
| Parameters |
Increase Speed Index
Increases the speed index.
| Parameters |
Set Speed Index
| Parameters |
Set Speed Level
| Parameters |
activeZone.ui | string | N/A | the active zone as a human readable string |
Commands (indigo.sprinkler.*)
Next Zone
| Parameters |
Pause Schedule
indigo.sprinkler.pause(123)
| Parameters |
Previous Zone
| Parameters |
Resume Schedule
indigo.sprinkler.resume(123)
| Parameters |
Run Schedule
Run a sprinkler schedule.
| Parameters |
Stop Schedule
indigo.sprinkler.stop(123)
| Parameters |
Set Active Zone
| Parameters |
# run schedule
coolIsOn | boolean | No | 1.0 | is the cooling system (compressor) currently running - shortcut for dev.states['hvacCoolerIsOn']. This property is always present and will be False if the corresponding state dev.states['hvacCoolerIsOn'] is not present. |
heatIsOn | boolean | No | 1.0 | is the heater currently running - shortcut for dev.states['hvacHeaterIsOn']. This property is always present and will be False if the corresponding state dev.states['hvacHeaterIsOn'] is not present. |
Plugin Capabilities
NumTemperatureInputs | Integer | Yes | should range between 1 and 3 |
NumHumidityInputs | Integer | Yes | should range between 0 and 3 |
SupportsHeatSetpoint | Boolean | Yes | True or False |
SupportsCoolSetpoint | Boolean | Yes | True or False |
SupportsHvacOperationMode | Boolean | Yes | True or False |
SupportsHvacFanMode | Boolean | Yes | True or False |
ShowCoolHeatEquipmentStateUI | Boolean | Yes | True or False |
| Attribute | Read-Only |
dev.hvacMode | Yes |
dev.fanMode | Yes |
dev.coolSetpoint | Yes |
dev.heatSetpoint | Yes |
dev.temperatureSensorCount | Yes |
dev.temperatures | Yes |
dev.humiditySensorCount | Yes |
dev.humidities | Yes |
dev.coolIsOn | Yes |
dev.heatIsOn | Yes |
dev.fanIsOn | Yes |
dev.dehumidifierIsOn | Yes |
dev.humidifierIsOn | Yes |
dev.supportsHvacFanMode | Yes |
dev.supportsHvacOperationMode | Yes |
dev.supportsCoolSetpoint | Yes |
dev.supportsHeatSetpoint | Yes |
Fan Mode Enumeration
indigo.kFanMode |
HVAC Mode Enumeration
indigo.kHvacMode |
Decrease Cool Setpoint
| Parameters |
delta | No | integer | Number of degrees to decrease the cool setpoint. If unspecified, the change will be equal to one degree. |
Decrease Heat Setpoint
| Parameters |
delta | No | integer | Number of degrees to decrease the heat setpoint. If unspecified, the change will be equal to one degree. |
Increase Cool Setpoint
| Parameters |
delta | No | integer | Number of degrees to increase the cool setpoint. If unspecified, the change will be equal to one degree. |
Increase Heat Setpoint
| Parameters |
delta | No | integer | Number of degrees to increase the heat setpoint. If unspecified, the change will be equal to one degree. |
Set Cool Setpoint
| Parameters |
Set Fan Mode
Adjust the fan mode.
| Parameters |
value | Yes | kFanMode | the operating mode for the fan |
Set Heat Setpoint
| Parameters |
Set HVAC Mode
Adjust the HVAC mode.
| Parameters |
# set the heat setpoint to 78
