Table of Contents
  key_value_list = [
	"allowOnStateChange": false,
	"protocol": "ZWave",
	"configured": true,
	"states": {
		"onOffState": true,
		"batteryLevel.ui": "100%",
		"batteryLevel": 100
	"subType": "",
	"globalProps": {
			"zwConfigVals": {},
			"zwShowWakeIntervalUI": true,
			"zwModelId": 0,
			"zwClassIds": [
				4,
				7,
				1
			"zwShowDumpDevToLog": false,
			"zwLibType": 3,
			"SupportsBatteryLevel": true,
			"zwProtoVersMajor": 4,
			"zwEndpointDevTypeMap": {},
			"userWakeInterval": 60,
			"indigoObjVersion": 10,
			"version": "5.01",
			"zwClassCmdMap": {
				"c134": 1,
				"c90": 1,
				"c133": 1,
				"c132": 2,
				"c89": 1,
				"c94": 1,
				"c128": 1,
				"c122": 1,
				"c115": 1,
				"c114": 1,
				"c113": 1,
				"c32": 1
			"SupportsOnState": true,
			"zwShowMainUI": true,
			"zwAppVersMinor": 1,
			"userPollInterval": 0,
			"zwDevSubIndex": 0,
			"zwEncryptClassCmdMap": {},
			"address": 17,
			"zwEndpointClassMap": {},
			"zwModelDefnVers": 0,
			"zwManufactureId": 0,
			"SupportsSensorValue": false,
			"zwAssociationsMap": {
				"g1": [
					1
			"zwShowPollingUI": false,
			"zwWakeInterval": 60,
			"zwClassCmdBase": 0,
			"zwAppVersMajor": 5,
			"zwProtoVersMinor": 5,
			"zwNodeNeighbors": [
				1,
				15,
				16
			"userPollingEnabled": true
	"pluginProps": {},
	"buttonGroupCount": 0,
	"id": 854505717,
	"supportsAllOff": false,
	"errorState": "",
	"remoteDisplay": true,
	"energyAccumBaseTime": null,
	"displayStateValUi": "on",
	"subModel": "",
	"version": "5.01",
	"energyAccumTimeDelta": null,
	"batteryLevel": 100,
	"supportsSensorValue": false,
	"ownerProps": {
		"zwConfigVals": {},
		"zwModelId": 0,
		"zwClassIds": [
			4,
			7,
			1
		"zwLibType": 3,
		"version": "5.01",
		"zwClassCmdMap": {
			"c134": 1,
			"c90": 1,
			"c133": 1,
			"c132": 2,
			"c89": 1,
			"c94": 1,
			"c128": 1,
			"c122": 1,
			"c115": 1,
			"c114": 1,
			"c113": 1,
			"c32": 1
		"zwDevSubIndex": 0,
		"address": 17,
			"g1": [
				1
			1,
			15,
			16
	"description": "",
	"onState": true,
	"energyAccumTotal": null,
	"address": "17",
	"sharedProps": {},
	"folderId": 1145028206,
	"supportsOnState": true,
	"sensorValue": null,
	"energyCurLevel": null,
	"enabled": true,
	"displayStateValRaw": true,
Device Base Class
Device Base Class Properties
globalProps dictionary No 1.0 an indigo.Dict() representing all name/value pairs associated with this device - each plugin will have it's own dictionary (globalProps[pluginId]) - see About Plugin Properties below for details
sharedProps dictionary No 2.3 an indigo.Dict() representing the name/value pairs that are shared by all plugins. This is the property dictionary that you can edit via the Global Properties plugin, and your plugin may manage properties in this dictionary as well to add metadata to devices that your plugin can use for other purposes. Use dev.replaceSharedPropsOnServer() to update them (as with pluginProps, you should get copy first, update the copy, then set them back to that copy so you don't accidentally remove some other plugin's props).
Protocol Enumeration
indigo.kProtocol
Value Description
State Image Sel Enumeration
API v1.18+ only:
indigo.kStateImageSel
Value Description
Value Description
replacePluginPropsOnServer(newPropsdict) Yes 1.0 If you need to make a change to your plugin's property dictionary that's stored as part of the device (see About Plugin Properties below) you just use this method to replace the entire dict with a new one. A typical usage will be to get the property dictionary from the device, make changes to the dict, then use this method to store the new dict.
updateStateImageOnServer(stateImageSel) Yes 1.18 Use this method to override which device state image icon is shown for this device on Indigo Touch and the Indgo client UI. The default behavior is for Indigo Server to automatically determine which icon should be shown based on the device class and state value. Only call this method if overriding the default behavior is needed.
Devices have properties - some are class properties, defined by the class itself. One of the biggest requests we've gotten in the past is some way to add arbitrary properties to a device - so that you could store your own data with the device in the database. And with plugin defined devices, we needed a place to store the properties that you need to operate the device. That's what the pluginProps and globalProps represent - the additional properties that are not defined by the class. globalProps is a dictionary of every additional property defined for the device - each plugin has it's own dictionary of props in here which are readable by anyone. pluginProps is a shortcut to get to your plugin's props and are only writable by your plugin once the plugin has been created - a script can create a device supplied by your plugin along with the necessary properties, which are passed in on the create() method. You should publish the properties necessary to make your device work so that scripters can create your devices.
dev=indigo.devices[123]
About Custom Device States
    <State id="playStatus">
    <State id="sep1">
    <State id="playlist">
        <ValueType>String</ValueType>
    <State id="album">
    <State id="artist">
    <State id="track">
    <State id="volume">
    <State id="shuffle">
# to update the volume state
# to update the track name
# to update the album name
# to update the artist name
# to update the playStatus
Commands (indigo.device.*)
All Off
indigo.device.allOff()
Enumerated Type Description
Beep
indigo.device.beep(123)
Create a device. You can create devices that are defined by your plugin, in other plugins, and X10 devices (FIXME you can't currently add INSTEON devices because they need to perform some action to actually make the device function). You use this method to create ALL device types - it will return a device of the correct class to you based on the arguments. It can be considered the “device” factory method.
    address='F8',
    name='Device Name Here',
    folder=1234)
deviceTypeId Yes string the id of the device type – defined by the plugin or one of the defined X10 devices.
indigo.device.delete(123)
Enable/Disable
Get Group List
               ID : 1280166770 (integer)
               ID : 106487666 (integer)
Ping Device
if result["Success"]:
Status Request
Toggle
indigo.device.toggle(123)
Turn Off
indigo.device.turnOff(123)
Turn On
indigo.device.turnOn(123)
Unlock
indigo.device.unlock(123)
Lock
indigo.device.lock(123)
# Creating a device
    name="Office Lamp",
    address="F7",
# Getting a device
# Getting a device
if (myDevice.remoteDisplay):
all off
DimmerDevice
Device States
Commands (indigo.dimmer.*)
All Lights Off
indigo.dimmer.allLightsOff()
All Lights On
indigo.dimmer.allLightsOn()
Brighten
indigo.dimmer.brighten(123)
Dim
indigo.dimmer.dim(123)
Set Brightness
Set LED State
Set Color Levels
               redLevel,
               greenLevel,
               blueLevel,
               whiteLevel,
               whiteLevel2,
               whiteTemperature,
               delay,
               suppressLogging,
               updateStatesOnly
redLevel No integer 0 - 100
greenLevel No integer 0 - 100
blueLevel No integer 0 - 100
whiteLevel No integer 0 - 100
whiteLevel2 No integer 0 - 100
whiteTemperature No integer 1200 - 15000
delay No integer Defaults to 0.
suppressLogging No integer Defaults to False
updateStatesOnly No integer is an argument that exists on several device instance APIs that has Indigo update its device state/UI but does not have the corresponding action sent out to physical module. The use cases for this are pretty few, but sometimes you just want the internal state to update and can skip the actual command to the module. Defaults to False
# RGB value / 255 * 100
redLevel = 128
Set On State
# Getting a device
    (myDevice.onState)):
myDevice.folderId
# OR
MultiIODevice
Device States
Commands (indigo.iodevice.*)
Set Binary Output
		index=1,
		value=False)
SensorDevice
  • X10 Motion Sensors
Commands (indigo.sensor.*)
Set On State
– none –
RelayDevice
Device States
Commands (indigo.relay.*)
Set LED State
# Toggle the device
SpeedControlDevice
Device States
Decrease Speed Index
Decreases the speed index.
Increase Speed Index
Increases the speed index.
Set Speed Index
Set Speed Level
SprinklerDevice
activeZone integer No 1.0 the 1-based index of the active zone (None=all zones off, 1=zone 1, 2=zone 2, …). Note this property has undergone changes in name (previously called activeZoneIndex) as well as semantics (previously the index being 0-based).
Device States
Commands (indigo.sprinkler.*)
Next Zone
Pause Schedule
indigo.sprinkler.pause(123)
Previous Zone
Resume Schedule
indigo.sprinkler.resume(123)
Run Schedule
Run a sprinkler schedule.
Stop Schedule
indigo.sprinkler.stop(123)
Set Active Zone
# run schedule
ThermostatDevice
Plugin Capabilities
Property Type Writeable Description
NumTemperatureInputs Integer Yes should range between 1 and 3
NumHumidityInputs Integer Yes should range between 0 and 3
SupportsHeatSetpoint Boolean Yes True or False
SupportsCoolSetpoint Boolean Yes True or False
SupportsHvacOperationMode Boolean Yes True or False
SupportsHvacFanMode Boolean Yes True or False
ShowCoolHeatEquipmentStateUI Boolean Yes True or False
Attribute Read-Only
dev.hvacMode Yes
dev.fanMode Yes
dev.coolSetpoint Yes
dev.heatSetpoint Yes
dev.temperatureSensorCount Yes
dev.temperatures Yes
dev.humiditySensorCount Yes
dev.humidities Yes
dev.coolIsOn Yes
dev.heatIsOn Yes
dev.fanIsOn Yes
dev.dehumidifierIsOn Yes
dev.humidifierIsOn Yes
dev.supportsHvacFanMode Yes
dev.supportsHvacOperationMode Yes
dev.supportsCoolSetpoint Yes
dev.supportsHeatSetpoint Yes
Fan Mode Enumeration
indigo.kFanMode
Value Description
HVAC Mode Enumeration
indigo.kHvacMode
Value Description
Device States
Decrease Cool Setpoint
delta No integer Number of degrees to decrease the cool setpoint. If unspecified, the change will be equal to one degree.
Decrease Heat Setpoint
delta No integer Number of degrees to decrease the heat setpoint. If unspecified, the change will be equal to one degree.
Increase Cool Setpoint
delta No integer Number of degrees to increase the cool setpoint. If unspecified, the change will be equal to one degree.
Increase Heat Setpoint
delta No integer Number of degrees to increase the heat setpoint. If unspecified, the change will be equal to one degree.
Set Cool Setpoint
Set Fan Mode
Adjust the fan mode.
value Yes kFanMode the operating mode for the fan
Set Heat Setpoint
Set HVAC Mode
Adjust the HVAC mode.
# set the heat setpoint to 78
indigo_2022.2_documentation/device_class.txt · Last modified: 2023/05/30 13:56 by davel17
