Indigo 2022.2 Documentation
Welcome to the Indigo 2022.2 Documentation pages. We've separated the docs into multiple areas, each focusing on some different part of Indigo 2022.2.
Indigo User Documents
Other Help Pages
Indigo Plugin Documents
- Email+ - allows users to integrate with email services.
- NOAA Weather - makes weather data from the U.S. National Oceanic and Atmospheric Administration available for use in Indigo.
Indigo How-To Wiki
Technical Documents
About Python IOM API v3.x: with API v3.0 and later, we have switched to Python 3. Older versions of the API use Python 2, and – for this release only – Python 2 will continue to work with this release (M1 Macs will require Rosetta as it is Intel-only). Plugins specifying API 2.x or earlier will be run with Python 2 (and will stop working in the next release of Indigo) and scripts – both embedded and external – will run in Python 3 only. See the API release notes for v3.0 for details. See Python Packages for a list of the additional Python packages that are installed with the Indigo 2022.2 installer.
- The Indigo Object Model v3.2 (release notes) - this is used to build plugins and write scripts to work with Indigo.
- Plugin Developer's Guide - how to create plugin bundles for easy distribution, plugin UI, APIs, callback hooks, and more.
- Object Model Reference - the Indigo Object Model (IOM) and how to use it in Python in both plugins and scripts.
- Scripting Tutorial - dive into scripting Indigo by examples.
- Server Plugin Tutorial - examples of extending Indigo via plugins.
- Indigo Plugin SDK includes example plugins with full XML and python source. They are a great place to start when developing new plugins (or when upgrading a plugin to Python 3).
- New Integration APIs - these are used to integrate Indigo control into other systems (i.e. Shortcuts, etc)
- HTTP API - a new API which replaces the legacy REST API. If you need to convert, check out the REST to HTTP API Conversion Examples page for some examples to get you started.
- WebSocket API - a new API which allows more modern integration by opening a persistent connection to Indigo and receive updates to all the major Indigo object types as changes are made. You can also send commands through this WebSocket to control devices. It's extremely fast and should make for some great 3rd party clients and other integrations (our new Indigo Touch for Web UI uses them).
- Integrations
- Apple Shortcuts - a new How-To document on how to use Apple Shortcuts with Indigo with the HTTP API.
- IFTTT - a primer on how to integrate IFTTT and Indigo using the HTTP API.
- Home Remote - a step-by-step tutorial on making a Geofence action that updates an Indigo Variable using the Home Remote app and the HTTP API.
