Indigo Object Model Reference
# some code here
# that does something
TermMeaning
For Scripters and Developers:
For Developers:
ClassCommand namespaceNotes
Schedule
Triggers
DeviceStateChangeTrigger (indigo.DeviceStateChangeTrigger)indigo.devStateChange.*manipulate a device state change trigger
Variables
Protocol Specific Commands
General Commands
IOM Object Hierarchy Image
  • keys cannot contain spaces.
c = indigo.List()
c.append(4)
c.append(5)
c.append(True)
c.append(False)
a = indigo.Dict()
a['a'] = "the letter a"
a['b'] = False
print(str(a))
c.append(6)
a['c'].append(6)
a['c'] = c
print(str(a))
Object Description
Object Events
Objects that support subscribeTochanges()
Lower-level Events
Low Level Commands (Insteon and x10 Only)
indigo.x10.subscribeToIncoming()
indigo.x10.subscribeToOutgoing()
        if cmd.cmdType == "sec":    # or "x10" for power line commands
            if cmd.secCodeId == 6:
Iterating Object Lists
for dev in indigo.devices:
    # do stuff with dev here
Filter Description
indigo.x10include X10 devices
indigo.dimmerdimmer devices
indigo.sprinklersprinklers
indigo.thermostatthermostats
Triggers also have filters:
Filter Description
for var in indigo.variables:
    # all variables
Possible Exceptions
>>> dev.__class__
<class 'indigo.DimmerDevice'>
>>> hasattr(dev,'onState')
True
>>> dir(dev)
>>> thermo.__class__
>>> dir(thermo)
>>> tunes.__class__
<class 'indigo.Device'>
>>> dir(tunes)
>>> tunes.deviceTypeId
u'mediaserver'
So, from a discovery perspective, the dir(obj) method will list all properties and methods for an object. The hasattr(obj, attr) will test an object to see if it has a specific attribute. The obj.class attribute will show you what class the object is. As you explore IOM objects, these methods will help you figure out how to use IOM objects effectively.
>>> dev = indigo.devices[123]
address :
batteryLevel : None
buttonGroupCount : 0
configured : True
description :
<'indigo.Device'>
>>> dev_dict = dict(dev)
<class 'dict'>
Name Base Description
FileNotFoundErrorException This is a useful exception if you handle files in any way. There is no built-in processing to catch such exceptions, it's just a useful exception to use.
IndigoJSONEncoderJSONEncoder Use this encoder class if you are encoding a python date, time, or datetime class into a JSON string. Very useful if you attempt to encode a device dictionary into JSON (json.dumps(dict(mydevice), cls=indigo.utils.IndigoJSONEncoder))
Return Static File
status No int the HTTP status code to return, defaults to 200
path_is_relative No boolean is the path a full path or relative to the plugin, defaults to True
content_type No string a string to return as the mime type of the content, returns the appropriate type based on the file extension if none is specified
    "status": 404,
    "headers": {
        "Content-Type": "text/html"
    "file_path": "/Library/Application Support/Perceptive Automation/Indigo 2022.2/Plugins/Example HTTP Responder.indigoPlugin/Contents/Resources/static/html/static_404.html"
Validate Email Address
indigo.utils.validate_email_address("[email protected]")
  • /www/perceptive/wiki/data/pages/indigo_2022.2_documentation/object_model_reference.txt
