Integration APIs
his article is about the two APIs in IWS that developers can use to integrate Indigo with external services:
- WebSocket API – (which the new Indigo Touch Web UI uses, and
NOTE:
Versioning
/v2/- this is the top level version number and will change as necessary
Python vs JavaScript
"key1": "value 1",
"key2": 2
| Python | JSON Equivalent |
| True | true |
| False | false |
| float | Number |
| int | Number |
| None | null |
| dict | Object |
| list | Array |
| tuple | Array |
| str | String |
WebSocket API
/v2/api/ws/device-feed- WebSocket to do all communication about devices/v2/api/ws/variable-feed- WebSocket to do all communication about variables/v2/api/ws/action-feed- WebSocket to do all communication about action groups/v2/api/ws/page-feed- WebSocket to do all communication about control pages/v2/api/ws/log-feed- WebSocket to do all communication about logs
WebSocket Lifecycle
- Setup:
Authentication
Note the protocol: wss. WebSockets actually begin their life as HTTP/HTTPS connections, which the WebSocket client then requests the server to upgrade to a WebSocket. In this respect, you can think of WSS as HTTPS (protected) and WS as HTTP (unprotected). When using WSS, such as when you are using your Indigo Reflector, then your API Key (in both instances) is protected by the TLS security used by the HTTPS protocol. You may use the API locally (or thorough your own router port forwarding), but those connections will be WS and will not be secure. It is highly recommended that you always use your Indigo Reflector because it provides a very simple and secure solution for accessing your system. IMPORTANT! Don't share your API keys with anyone who is not authorized to use them — especially in posts to the Indigo user forums.
Python Receiver Example
import asyncio import json from websockets import connect API_KEY = 'YOUR_API_KEY' # YOUR API KEY HERE DEVICE_ID = 12345678 # YOUR DEVICE ID HERE HEADERS = {"Authorization": f"Bearer {API_KEY}"} URI = "ws://127.0.0.1:8176/v2/api/ws/device-feed" # wss:// if using the reflector async def receiver(ws): try: print("Starting receiver task") # Ask for a refresh of device with ID 12345678 refresh_message = { "id": "initial-device-refresh", "message": "refresh", "objectType": "indigo.Device", "objectId": DEVICE_ID } await ws.send(json.dumps(refresh_message)) counter = 0 device = {} while counter < 20: # just keep looping waiting for a message to come log_string = "ignoring message" message_json = await ws.recv() message = json.loads(message_json) message_type = message['message'] if message_type == "refresh": # This is the response to the refresh message we sent above. It gets us a full copy of the device. device = message["objectDict"] log_string = f"receiver: device refresh message: '{device.get('name', 'unknown')}'" elif message_type == "patch": # There's been a change, so confirm it's the device we want then log the change if message["objectId"] == device["id"]: log_string = f"'receiver: device patch message: {device.get('name', 'unknown')}' update: \n{message_json}" print(f"receiver: loop count: {counter}") print(f"receiver: {log_string}") counter += 1 except Exception as exc: print(f"Exception:\n{exc}") async def sender(ws, count): try: print("Starting sender task") message = { "id": "initial-device-refresh", "message": "refresh", "objectType": "indigo.Device", "objectId": DEVICE_ID } for count in range(10): print(f"sender: loop count: {count}") msg = json.dumps(message) print(f"sender: sending message: {msg}") await ws.send(json.dumps(msg)) await asyncio.sleep(5) except Exception as exc: print(f"Exception:\n{exc}") async def main(): try: async with connect(URI, extra_headers=HEADERS) as websocket: await asyncio.gather(receiver(websocket), sender(websocket, 10)) except Exception as exc: print(f"Exception:\n{exc}") asyncio.run(main())
JavaScript Example
Device Feed
add device message
"message": "add",
objectDict": {
"address": "3B.04.7A",
"batteryLevel": null,
"blueLevel": null,
"brightness": 100,
"buttonConfiguredCount": 0,
"buttonGroupCount": 1,
"configured": true,
"defaultBrightness": 100,
"deviceTypeId": "",
"displayStateValRaw": 100,
"displayStateValUi": "100",
"enabled": true,
"energyAccumBaseTime": null,
"energyAccumTimeDelta": null,
"energyAccumTotal": null,
"energyCurLevel": null,
"errorState": "",
"folderId": 1552926800,
"globalProps": {
"emptyDict": {}
"greenLevel": null,
"id": 1508839119,
"ledStates": [],
"name": "Insteon Dimmer",
"onBrightensToLast": false,
"onState": true,
"ownerProps": {},
"pluginId": "",
"pluginProps": {},
"redLevel": null,
"remoteDisplay": false,
"sharedProps": {},
"states": {
"brightnessLevel": 100,
"onOffState": true
"subModel": "Plug-In",
"subType": "Plug-In",
"supportsAllOff": true,
"supportsColor": false,
"supportsOnState": true,
"supportsRGB": false,
"supportsWhite": false,
"version": 67,
"whiteLevel": null,
"whiteLevel2": null,
"whiteTemperature": null
update device message
"message": "patch",
"objectId": 1508839119,
"patch": [
"change",
"brightness",
[100, 0]
"change",
"displayStateImageSel",
"change",
"displayStateValRaw",
[100, 0]
"change",
"displayStateValUi",
["100", "0"]
"change",
"lastChanged",
"change",
"lastSuccessfulComm",
"change",
"onState",
[true, false]
"change",
"states.brightnessLevel",
[100, 0]
"change",
"states.onOffState",
[true, false]
device refresh messages
"list": []
"objectDict": {}
delete device message
"message": "delete",
"objectId": 123456789
Device messages to the server
device refresh requests
// Specify the object type
device command messages
"objectId": 123456789,
Variable Feed
"class": "indigo.Variable",
"description": "",
"folderId": 0,
"globalProps": {
"id": 345633244,
"name": "house_status",
"pluginProps": {},
"readOnly": false,
"remoteDisplay": true,
"sharedProps": {},
"value": "home"
add variable message
"message": "add",
update variable message
delete variable message
variable refresh messages
variable command messages
updateValue
"parameters": {
"value": "Some string value"
Action Group Feed
"description": "",
"folderId": 532526508,
"globalProps": {
"speakDelayTime": "5",
"id": 94914463,
"name": "Movie Night",
"pluginProps": {},
"sharedProps": {
add action group message
"message": "add",
update action group message
delete action group message
action group refresh messages
action group command messages
Control Page Feed
"backgroundImage": "",
"description": "",
"folderId": 0,
"globalProps": {},
"hideTabBar": true,
"id": 963336187,
"name": "Weather Images",
"pluginProps": {},
"sharedProps": {}
add control page message
"message": "add",
update control page message
delete control page message
Indigo Object Folders
"id": 617272302,
"class": "indigo.Folder",
"name": "My Device Folder",
refresh folder server message
Log Feed
"message": "add",
"objectDict": {
"message": "Stopping plugin \"Web Server 2023.1.0\" (pid 1020)",
"typeStr": "Application",
"typeVal": 0
HTTP API
HTTP API Endpoints
/v2/api/indigo.devices- endpoint to get a list of devices/v2/api/indigo.devices/123456789- endpoint to get a specific device instance (See Device Objects below)/v2/api/indigo.variables- endpoint to get a list of variables/v2/api/indigo.variables/123456789- endpoint to specific variable object (See Variable Objects below)/v2/api/indigo.actionGroups- endpoint to get a list of action groups/v2/api/indigo.actionGroups/123456789- endpoint to get a specific action group (See Action Group Objects below)/v2/api/command- endpoint to send Indigo a command (device control, variable update, action execution).
Authentication
Getting Device Objects
Getting All Device Objects
- Replace
- Replace
- Replace
- Replace
- Replace
- Replace
Controlling an Indigo Device
- Replace
- Replace
- Replace
- Replace
- Replace
- Replace
Getting Variable Objects
Getting All Variable Objects
- Replace
- Replace
- Replace
- Replace
- Replace
- Replace
Updating a Variable's Value
- Replace
- Replace
- Replace
Getting Action Group Objects
- Replace
- Replace
- Replace
Executing an Action Group
- Replace
- Replace
- Replace
API Messages
Device Messaging
Device Objects
Example device object
"blueLevel": null,
"brightness": 0,
"configured": true,
"deviceTypeId": "",
"displayStateValRaw": 0,
"displayStateValUi": "0",
"enabled": true,
"errorState": "",
"folder": {
"id": 1552926800,
"name": "Insteon",
"globalProps": {},
"greenLevel": null,
"id": 1508839119,
"ledStates": [],
"onState": false,
"ownerProps": {},
"pluginId": "",
"pluginProps": {},
"redLevel": null,
"sharedProps": {},
"states": {
"brightnessLevel": 0,
"onOffState": false
"version": 67,
"whiteLevel": null,
indigo.device
"parameters": {
"delay": 5,
"duration": 10
"parameters": {
"delay": 5,
"duration": 10
"parameters": {
"delay": 5,
"duration": 10
"parameters": {
"delay": 5,
"duration": 10
"parameters": {
"delay": 5,
"duration": 10
"parameters": {
"value": True,
indigo.dimmer
"parameters": {
"by": 5,
"delay": 10
"parameters": {
"by": 5,
"delay": 10
"parameters": {
"value": 50,
"delay": 10
indigo.iodevice
"parameters": {
"index": 5,
"value": true
indigo.sensor
"parameters": {
"value": true
indigo.speedcontrol
"parameters": {
"by": 2,
"delay": 5
"parameters": {
"by": 2,
"delay": 5
"parameters": {
"value": 2,
"delay": 5
set speed level indigo.speedcontrol.setSpeedLevel(123456789, value=50, value=True)
"parameters": {
"value": 50,
"delay": 5
indigo.sprinkler
"parameters": {
"schedule": [10,15,8, 0, 0, 0, 0, 0]
"parameters": {
"index": 2
indigo.thermostat
"parameters": {
"delta": 2
"parameters": {
"delta": 2
"parameters": {
"delta": 2
"parameters": {
"delta": 2
"parameters": {
"value": 76
"parameters": {
"parameters": {
"value": 76
"parameters": {
Variable Messaging
Variable Objects
"description": "",
"folderId": 0,
"folder": {},
"globalProps": {
"id": 345633244,
"pluginProps": {},
"readOnly": false,
"sharedProps": {},
"value": "home"
"parameters": {
Action Group Messaging
"description": "",
"folder": {
"id": 532526508,
"name": "Mood Scenes",
"globalProps": {
"id": 94914463,
"pluginProps": {},
"sharedProps": {
Log Messages
Example Log Message
"typeVal": 0
Error Messaging
Generic Error Message
"validationErrors": {
Example API Call
"parameters": {
"value": 1234.56
Resulting Error Message
message,objectId,parameters, andvalue
Invalid JSON
Example Invalid JSON Message
"error": "invalid JSON"
Web Server Warnings
| 400 | Bad Request | Indicates that the server cannot or will not process the request due to something that is perceived to be a client error (for example, malformed request syntax, invalid request message framing, or deceptive request routing) |
| 401 | Unauthorized | Indicates that the client request has not been completed because it lacks valid authentication credentials for the requested resource. |
