Beginning with Indigo 2023.1, an Advanced Web Server Settings…
menu item was added to the Indigo menu. The menu has three options:
Indigo 2023.1 contains special folders that are accessible to the Indigo Web Server which are located in:
/Library/Application Support/Perceptive Automation/Indigo 2023.1/Web Assets/
/Library/Application Support/Perceptive Automation/Indigo 2023.1/Web Assets/images /Library/Application Support/Perceptive Automation/Indigo 2023.1/Web Assets/plugins /Library/Application Support/Perceptive Automation/Indigo 2023.1/Web Assets/public /Library/Application Support/Perceptive Automation/Indigo 2023.1/Web Assets/static
As a convenience, you can access these folders under the Indigo Help menu: Help
–> Show Web Assets Folder
For example:
For example:
In addition to authentication via API Keys and the Indigo Reflector (recommended), users can create their own local secrets (another type of key) that don't require an internet connection to validate. Users can create a JSON list of their own “secrets” that will be loaded whenever the web server is restarted. The secrets file is located in the install folder's /Preferences
directory and is named secrets.json
. This feature was introduced with Indigo version 2023.1:
/Library/Application Support/Perceptive Automation/Indigo 2023.1/Preferences/secrets.json
[ "here-is-a-key", "this*is*another*key" ]
[ "here-is-a-key", "this*is*another*key", "do-not-use-api-keys" ]
[ "do-not-use-api-keys" ]
First, create your content. For example, web sites often contain a index.html
page. A simple index.html
page looks like this:
<!DOCTYPE html> <html lang="en"> <head> <meta charset="utf-8"> <title>Indigo Web Server</title> </head> <body style="height:100%; width:100%"> <div id="content" style="position:absolute; top:0px; left:0px; height:200px; right:0px;overflow:hidden;"> Hello world. </div> </body> </html>
Using a plain text editor, save this code as index.html
within the …/Web Assets/static
folder (to serve it with authentication) or within the …/Web Assets/public
folder (to serve it without authentication). You can refer to assets located in other folders by referencing them with the Web Assets
folder as the root.
