Apple's Shortcuts app* allows you to create custom workflows on macOS, iOS and iPadOS (you can't currently run shortcuts on tvOS). You can also use Apple Shortcuts with Indigo to call many functions and use Indigo events to fire Apple shortcuts. Using Indigo's HTTP API with Apple's Shortcuts app is easy and there are different methods to accomplish this (this document uses Indigo's v2 API which shipped with Indigo v2023.1).
* The shortcuts app for macOS is only available for Monterey (12.x) and newer versions. It has been available for iOS and iPadOS since version 12.
Add an API Key
.Add API Key
button.Building your shortcut in the Shortcuts app is largely the same whether you do it on macOS or iOS, and – depending on the type of activity you want to initiate – only takes a couple of steps. The information you'll need depends on what you want to do, but all the API events are constructed in the same way. For this example, we'll use the macOS Shortcuts App to build our shortcut (you can also do it on iOS and iPadOS). At first, this looks like a lot of steps, but there's actually only a few pieces of information required. All values below are entered without quotes. For our first example, we'll perform a simple Indigo Device Toggle.
You'll need:
https://MY-REFLECTOR-NAME.indigodomo.net/v2/api/command/
(replace MY-REFLECTOR-NAME
with the name of your active reflector,c2xr7q35-9385-10f9-3652-12z765j99vnv
(replace with your valid key. This one is fake.),indigo.device.toggle
,123456
, and+
at the top)URL
field and enter the base URL above. If using an external IP address or reflector make sure to use https:
and not just http:
.Post
.Authorization
.Bearer 2x7a35-9385-10f9-3652-12765:99vnv
. (The word Bearer
, one space and then your API key.)Request Body
is set to JSON
.message
(make sure the Type
is set to Text
.indigo.device.toggle
.objectId
.123456
(your device ID, make sure the Type
is set to Number
.)At the top of the Shortcut editor window, you can change “Get Contents of URL” to something descriptive like “Toggle Living Room Lamp”. Likewise, you can click on the icon to customize it to your taste. Finally, if you'd like, you can add the Shortcut to your dock (or home screen on iOS), a shortcuts widget, or simply fire them from within the shortcuts app.
There is currently only one API command for Action Groups – indigo.actionGroup.execute
– which requires two payload elements:
(Text)This example shows how to obtain a variable's value and do something with it – in this case, speak the value aloud. The action you take in your shortcut could be any number of things.
https://MY-REFLECTOR-NAME.indigodomo.net/v2/api/indigo.variables/MY-VAR-ID
where you replace MY-REFLECTOR-NAME
with your active reflector name and MY-VAR-ID
with your variable's ID.speak
action is to tell your shortcut what kind of data it is. To do this, click on Get Contents of URL
in the speak action, set the data type to Dictionary
, and set Get Value for Key
to value
(be sure to hit return or tab to get the setting value
to stick.)
There is currently only one API command for Variables – indigo.variable.updateValue
– which requires three payload elements:
(Text)key
: value,You can include conditions in your shortcuts and take action – or not – based on the condition. For example, turn on a light – but only if it's dark outside.
Get Contents of URL
action to get a variable's value – in this example, the built-in variable isDaylight
,isDaylight
variable in a Text
action,If
condition and, if the Text value is equal to false
(Indigo variable values are always strings/text) then run your next shortcut action. Alternatively, you could send another command directly to the Indigo server (which is essentially what your linked shortcut is doing).false
, the Otherwise
action will be executed.In most instances, it's recommended that you use Indigo's built in script actions, such as: Execute Script, Run Shell Script, and Run Apple Shortcut. In some instances, however, you might want to use a shortcut to run a script outside the Indigo environment. Luckily, this is easy using Apple's Shortcuts Run Shell Script action.
The example below prompts the user for text, passes the text to the script, receives the script's output, and sends that output to a MacOS notification. This very basic example is simply to show how to pass input to your script and pass the script's output on to other steps. Note the use of sys.argv[1]
. This statement is reading the second argument passed to the script (the first argument is its source–the shortcut itself–which we won't need). The second argument – sys.argv[1]
– is passed as a string, and that's the bit we need. You'll need to account for whatever format your inputs and outputs turn out to be. These are the two most important settings to this example:
Python 3
as arguments
The rest is up to you.
Location-based shortcuts are not currently available in macOS (so you'll need to set up the location control piece on iPhone or iPad). The Leave
and Arrive
shortcuts cannot be run automatically. They require confirmation each time they are run. There is currently no way to turn this requirement off.
Home
or Away
.Automations
from the tab at the bottom.+
at the top.Arrive
or Leave
.Choose
.Done
. You can also adjust the range of the trigger in the bottom map panel (the minimum range is about 100 meters or 328 feet).Next
.Shortcut
and select the shortcut you created in step 1. Add any next actions as needed (not covered in this example).Done
The easiest way to run a shortcut is via an Indigo Action (this feature was introduced with Indigo 2023.1). Create a new Action and select Server Actions
> Run Apple Script
. You can optionally add text as input to the shortcut if you wish; otherwise, leave the Shortcut Input field blank.
When calling a shortcut from the “Run Shell Script” action, it's best to use the full path to the target: /usr/bin/shortcuts
to make sure Indigo can find it.
Note the escaped double-quotes for the shortcut payload. These are important to ensure that payloads with embedded spaces are sent as an encapsulated string object. For more information on the os.system()
Python command, take a look at the official docs.
Apple Shortcut
When using the os.system()
command, the function returns a 16-bit value (0
on success / 256
on error) to let you know if the command was successful. If you'd like to get a value back to Indigo after running the shortcut, one way is to use the more robust subprocess.run()
function. This function supports a bytes object return for more elaborate scripting capabilities. Here is an example of a call using the subprocess.run()
function:
Notice that the input is also a bytes object and will need to be decoded to use it. With this command, the shortcut will receive b“Input Text”
as input, and anything returned by the shortcut will be stored in the result
variable. If the call is unsuccessful, subprocess will throw the relevant error trace.
This type of call would be useful for things like getting a list of upcoming appointments or reminders. For example, you could send the number of appointments you want in the subprocess
call and get the appointment details back in the result.
, select “Shortcut Input”.Text
Using a plain text editor, create a new file called script1.sh
(or whatever), enter the following text, and save it.
chmod +x script1.sh
and hit return. Now we can run our shell script from Indigo.
Run Shell Script
.Edit Action Settings
./Users/username/Temp/script1.sh “Hello world.”
replacing /Users/username/Temp/
with the path to your script.Save
, and then OK
.From within Indigo, execute your action. The custom message you sent (in this example, “Hello world.”) will be sent to the script and will appear in the resulting notification.
You probably want to send something more interesting than Hello world.
, for example the value of some variable. We can do this using Indigo's substitutions feature.
Of course, you can have Siri run your shortcut by saying the name of the shortcut you want to run. To run the Toggle Living Room Lamp
shortcut, say, “Hey Siri. Toggle Living Room Lamp”. However, once you begin to have a lot of shortcuts, it can be tough to remember the exact name of every shortcut in your collection. One thing that can help is to create multiple shortcuts with similar names that all point to the same “original” shortcut. That way, if you make a change to the original shortcut, you don't need to change the others (if you change the name of the original shortcut, the Shortcuts app will update the others).
Siri Phrase | Action taken |
“Party Time” | sets lights, temperature, tv, whatever |
“Let's Party” | Runs Party Time shortcut |
“It's Party Time” | Runs Party Time shortcut |
“I'm Having a Party” | Runs Party Time shortcut |
off
, a new toggle will appear that says, “Notify When Run”. If this is also set to off
, then notifications for this automation will not be sent. Presently, there is no global setting to turn off all automation notifications.localhost:8176
or 10.0.1.123:8176
make sure to use http://
and not https://
)Here are a few commands you can run from the command line with the Shortcuts App that may be useful:
Command | Result |
shortcuts run "My Shortcut" <<< '{"message":"indigo.device.toggle", "objectId":"123456", "Arg":"Arg Value"}' | Pass a dictionary to Indigo. |
shortcuts list -f Living\ Room | List all shortcuts in the “Living Room” folder. |
