Integration APIs
NOTE:
  "key1": "value 1",
  "key2": 2
PythonJSON Equivalent
True true
False false
float Number
int Number
None null
dict Object
list Array
tuple Array
str String
WebSocket Lifecycle
  1. Setup:
%%wss:YOUR-REFLECTOR-NAME.indigodomo.net/v2/api/ws/device-feed?api-key=YOUR-API-KEY%% Note the protocol: wss. WebSockets actually begin their life as HTTP/HTTPS connections, which the WebSocket client then requests the server to upgrade to a WebSocket. In this respect, you can think of WSS as HTTPS (protected) and WS as HTTP (unprotected). When using WSS, such as when you are using your Indigo Reflector, then your API Key (in both instances) is protected by the TLS security used by the HTTPS protocol. You may use the API locally (or thorough your own router port forwarding), but those connections will be WS and will not be secure. It is highly recommended that you always use your Indigo Reflector because it provides a very simple and secure solution for accessing your system. IMPORTANT! In order to use API Key authentication, you MUST have enabled Enable OAuth and API Key authentication in the Indigo "Start Local Server" dialog box. Don't share your API keys with anyone who isnot authorized to use them — especially in posts to the Indigo user forums. Note that disabling this feature disables both API Keys and secrets. ==== Examples ==== The WebSocket and HTTP APIs are designed to be familiar to those that have been using the legacy RESTful API. However, anyone with knowledge of Python, JavaScript or similar languages should be able to pick up the structure of the new APIs very quickly. To help those making the transition as well as those learning to use API calls for the first time, we've laid out several examples to show how API calls are made, as well as all the current API hooks available. Here's a simple Python script to open the device-feed and print out any messages it receives (you'll need to pip3 install websockets before running it). === Python Receiver Example === This example opens a websocket connection and prints all messages received to the console. It runs until you stop it. <code python> import asyncio import websockets import json API_KEY = 'YOUR-API-KEY' async def receiver(): try: headers = {“Authorization”: f“Bearer {API_KEY}”} async with websockets.connect(“ws:localhost:8176/v2/api/ws/device-feed”, extra_headers=headers) as websocket: while True: message = await websocket.recv() print(json.dumps(json.loads(message), indent=2)) except Exception as exc: print(f“Exception:\n{exc}”) asyncio.run(receiver()) </code> === Python Receiver/Sender Example === This example opens a websocket connection and shows how messages can be received and sent from the same websocket connection. It runs until the loop counters run out. <code python> import asyncio import json from websockets import connect API_KEY = 'YOUR_API_KEY' # YOUR API KEY HERE DEVICE_ID = 12345678 # YOUR DEVICE ID HERE HEADERS = {“Authorization”: f“Bearer {API_KEY}”} URI = “ws:127.0.0.1:8176/v2/api/ws/device-feed” # wss: if using the reflector async def receiver(ws): try: print(“Starting receiver task”) # Ask for a refresh of device with ID 12345678 refresh_message = { “id”: “initial-device-refresh”, “message”: “refresh”, “objectType”: “indigo.Device”, “objectId”: DEVICE_ID } await ws.send(json.dumps(refresh_message)) counter = 0 device = {} while counter < 20: # just keep looping waiting for a message to come log_string = “ignoring message” message_json = await ws.recv() message = json.loads(message_json) message_type = message['message'] if message_type == “refresh”: # This is the response to the refresh message we sent above. It gets us a full copy of the device. device = message[“objectDict”] log_string = f“receiver: device refresh message: '{device.get('name', 'unknown')}'” elif message_type == “patch”: # There's been a change, so confirm it's the device we want then log the change if message[“objectId”] == device[“id”]: log_string = f“'receiver: device patch message: {device.get('name', 'unknown')}' update: \n{message_json}” print(f“receiver: loop count: {counter}”) print(f“receiver: {log_string}”) counter += 1 except Exception as exc: print(f“Exception:\n{exc}”) async def sender(ws, count): try: print(“Starting sender task”) message = { “id”: “initial-device-refresh”, “message”: “refresh”, “objectType”: “indigo.Device”, “objectId”: DEVICE_ID } for count in range(10): print(f“sender: loop count: {count}”) msg = json.dumps(message) print(f“sender: sending message: {msg}”) await ws.send(json.dumps(msg)) await asyncio.sleep(5) except Exception as exc: print(f“Exception:\n{exc}”) async def main(): try: async with connect(URI, extra_headers=HEADERS) as websocket: await asyncio.gather(receiver(websocket), sender(websocket, 10)) except Exception as exc: print(f“Exception:\n{exc}”) asyncio.run(main()) </code> === JavaScript Example === Here's a simple nodejs JavaScript to open the device-feed and print out any messages it receives (you'll need to npm install websocket before running it). <code javascript> const APIKEY = “YOUR-API-KEY”; const W3CWebSocket = require(“websocket”).w3cwebsocket; console.log(“Creating websocket”); const client = new W3CWebSocket( `ws:localhost:8176/v2/api/ws/device-feed?api-key=${APIKEY}` ); client.onmessage = function (message) { console.log(message.data); }; client.onerror = function (err) { console.log(`Error: ${JSON.stringify(err)}`); }; </code> ==== Device Feed ==== This is the WebSocket you'll use for all device-related communication. You will receive the following messages from the Indigo server during the lifetime of the WebSocket. Here are the URLs you will use to connect to this feed. %%ws:localhost:8176/v2/api/ws/device-feed%%
%%wss:YOUR-REFLECTOR-NAME.indigodomo.net/v2/api/ws/device-feed%% === Device messages from the server === The following are examples of all the device messages that you will receive from the server. == add device message == <code json> { “message”: “add”, “objectType”: “indigo.Device”, objectDict“: { “class”: “indigo.DimmerDevice”, “address”: “3B.04.7A”, “batteryLevel”: null, “blueLevel”: null, “brightness”: 100, “buttonConfiguredCount”: 0, “buttonGroupCount”: 1, “configured”: true, “defaultBrightness”: 100, “description”: ”- sample device -“, “deviceTypeId”: ”“, “displayStateId”: “brightnessLevel”, “displayStateImageSel”: “indigo.kStateImageSel.DimmerOn”, “displayStateValRaw”: 100, “displayStateValUi”: “100”, “enabled”: true, “energyAccumBaseTime”: null, “energyAccumTimeDelta”: null, “energyAccumTotal”: null, “energyCurLevel”: null, “errorState”: ”“, “folderId”: 1552926800, “globalProps”: { “com.indigodomo.indigoserver”: {}, “emptyDict”: {} }, “greenLevel”: null, “id”: 1508839119, “lastChanged”: “2023-02-16T15:43:53”, “lastSuccessfulComm”: “2023-02-16T15:43:53”, “ledStates”: [], “model”: “LampLinc (dual-band)”, “name”: “Insteon Dimmer”, “onBrightensToDefaultToggle”: true, “onBrightensToLast”: false, “onState”: true, “ownerProps”: {}, “pluginId”: ”“, “pluginProps”: {}, “protocol”: “indigo.kProtocol.Insteon”, “redLevel”: null, “remoteDisplay”: false, “sharedProps”: {}, “states”: { “brightnessLevel”: 100, “onOffState”: true }, “subModel”: “Plug-In”, “subType”: “Plug-In”, “supportsAllLightsOnOff”: true, “supportsAllOff”: true, “supportsColor”: false, “supportsOnState”: true, “supportsRGB”: false, “supportsRGBandWhiteSimultaneously”: false, “supportsStatusRequest”: true, “supportsTwoWhiteLevels”: false, “supportsTwoWhiteLevelsSimultaneously”: false, “supportsWhite”: false, “supportsWhiteTemperature”: false, “version”: 67, “whiteLevel”: null, “whiteLevel2”: null, “whiteTemperature”: null } } </code> When a new device is added to the Indigo Server after you've opened the connection, you will receive this message. It contains a device object that you will want to add to your device list (since you'll want to patch it as it changes over time - see the next section). You'll also receive this message when a device's remote display property is changed from False to True. == update device message == <code json> { “message”: “patch”, “objectType”: “indigo.Device”, “objectId”: 1508839119, “patch”: [ [ “change”, “brightness”, [100, 0] ], [ “change”, “displayStateImageSel”, [“indigo.kStateImageSel.DimmerOn”, “indigo.kStateImageSel.DimmerOff”] ], [ “change”, “displayStateValRaw”, [100, 0] ], [ “change”, “displayStateValUi”, [“100”, “0”] ], [ “change”, “lastChanged”, [“2023-02-17T16:29:56”, “2023-02-17T16:30:54”] ], [ “change”, “lastSuccessfulComm”, [“2023-02-17T16:29:56”, “2023-02-17T16:30:54”] ], [ “change”, “onState”, [true, false] ], [ “change”, “states.brightnessLevel”, [100, 0] ], [ “change”, “states.onOffState”, [true, false] ] ] }</code> Patch objects are created via the dictdiffer python module, by comparing the device dictionary (%%dict(some_device)%%) for the old device with the one for the new dictionary as they are received in the %%device_updated()%% plugin method call. We've implemented a JavaScript library, dictdiffer-js, to patch JavaScript objects given the patch object created by the dictdiffer Python library. You can use it in your projects if you like. == device refresh messages == When you send a command that asks to refresh the entire list of devices, you'll receive the following message from the server: <code json> { “id”: “optional-custom-user-message”, “message”: “refresh”, “objectType”: “indigo.Device”, “list”: [] } </code> And if you requested just a single device refresh, you will receive the following message from the server: <code json> { “id”: “optional-custom-user-message”, “message”: “refresh”, “objectType”: “indigo.Device”, “objectDict”: {} } </code> Note that the first message includes a list of objectDict elements, and the second includes a single objectDict element. == delete device message == <code json> { “message”: “delete”, “objectType”: “indigo.Device”, “objectId”: 123456789 } </code> This is the simplest of the messages, as it just contains the Indigo ID of the device to delete from your collection. You'll receive this message when a device is deleted from the Indigo server and when a device's remote display property is set from True to False. === Device messages to the server === You have a variety of messages you can send to the server. == device refresh requests == To refresh either the full device list or a single device from the server, send the following message. <code json> { “id”: “optional-custom-user-message”, “message”: “refresh”, Specify the object type “objectType”: “indigo.Device”, “objectId”: 123456789 } </code> If you want the entire device list, simply omit the objectId key and the server will return the full list. The server will respond with the appropriate device refresh message shown above. == device command messages == To command devices to do something, you will be using the Device Command Messages described below. For instance, to toggle a lamp device, you would send the following message: <code json> { “id”: “optional-custom-user-message”, “message”: “indigo.device.toggle”, “objectId”: 123456789, } </code> You will receive a “patch” message as a result of this command. ==== Variable Feed ==== This is the WebSocket you'll use for all variable-related communication. You will receive the following messages from the Indigo server during the lifetime of the WebSocket. Here are the URLs you will use to connect to this feed. %%ws:localhost:8176/v2/api/ws/variable-feed%% %%wss:YOUR-REFLECTOR-NAME.indigodomo.net/v2/api/ws/variable-feed%% === Variable messages from the server === The following is an example of the variable message that you will receive from the server. == Example variable object (dictionary in Python) == <code json> { “class”: “indigo.Variable”, “description”: ”“, “folderId”: 0, “globalProps”: { “com.indigodomo.indigoserver”: {} }, “id”: 345633244, “name”: “house_status”, “pluginProps”: {}, “readOnly”: false, “remoteDisplay”: true, “sharedProps”: {}, “value”: “home” } </code> Here are some examples of the server messages that clients will receive on the variable feed. == add variable message == <code json> { “message”: “add”, “objectType”: “indigo.Variable”, “objectDict”: {} Variable object as outlined above } </code> When a new variable is added to the Indigo Server after you've opened the connection, you will receive this message. It contains a variable object that you will want to add to your variable list (since you'll want to patch it as it changes over time - see the next section). You'll also receive this message when a variable's remote display property is changed from False to True. == update variable message == <code json> { “message”: “patch”, we use a patch rather than send the entire updated device “objectType”: “indigo.Variable”, “patch”: {} A patch object - see the Object Patches below for details } </code> Variable patch objects are created via the dictdiffer python module by comparing the variable dictionary (%%dict(some_variable)%%) for the old variable with the one for the new dictionary as they are received in the %%variable_updated()%% Plugin method call. == delete variable message == <code json> { “message”: “delete”, “objectType”: “indigo.Variable”, “objectId”: 123456789 } </code> This is the simplest of the messages, as it just contains the Indigo ID of the variable to delete from your collection. You'll receive this message when a variable is deleted from the Indigo server and when a variable's remote display property is set from True to False. === Variable messages to the server === There are a few messages you can send to the server. == variable refresh messages == <code json> { “id”: “optional-custom-user-message”, “message”: “refresh”, “objectType”: “indigo.Variable”, “objectDict”: {} Variable object as outlined above } </code> == Example refresh all variables message == <code json> { “id”: “optional-custom-user-message”, “message”: “refresh”, “objectType”: “indigo.Variable”, “list”: [] a list of Variable objects as outlined above } </code> === variable command messages === The updateValue command is currently the only command message you can send to the variable feed. It closely mirrors the Python-based IOM command for updating variables. This was completely intentional to make learning one API a stepping stone to another. The HTTP API messages and the Websocket API messages are identical, and are very clearly a JSON-rendered version of the associated IOM command. == updateValue == <code json> { Note, values passed in the parameter dictionary must be strings. You can pass in an empty string (”“) to clear the variable value. “id”: “optional-custom-user-message”, “message”: “indigo.variable.updateValue”, “objectId”: 123456789, the variable id to update “parameters”: { “value”: “Some string value” } } </code> ==== Action Group Feed ==== This is the WebSocket you'll use for all action group-related communication. You will receive the following messages from the Indigo server during the lifetime of the WebSocket. Here are the URLs you will use to connect to this feed. %%ws:localhost:8176/v2/api/ws/action-feed%% %%wss:YOUR-REFLECTOR-NAME.indigodomo.net/v2/api/ws/action-feed%% === Action Group messages from the server === The following are examples of all the action group messages that you will receive from the server. == Example action group object (dictionary in Python) == <code json> { “class”: “indigo.ActionGroup”, “description”: ”“, “folderId”: 532526508, “globalProps”: { “com.indigodomo.indigoserver”: { “speakDelayTime”: “5”, “speakTextVariable”: “speech_string” } }, “id”: 94914463, “name”: “Movie Night”, “pluginProps”: {}, “remoteDisplay”: true, “sharedProps”: { “speakDelayTime”: “5”, “speakTextVariable”: “speech_string” } } </code> Here are some examples of the server messages that clients will receive on the action feed. == add action group message == <code json> { “message”: “add”, “objectType”: “indigo.ActionGroup”, “objectDict”: {} ActionGroup object as outlined above } </code> When a new action group is added to the Indigo Server after you've opened the connection, you will receive this message. It contains an action group object object that you will want to add to your action group list (since you'll want to patch it as it changes over time - see the next section). You'll also receive this message when an action group's remote display property is changed from False to True. == update action group message == The update action group message is received when an action group has been updated on the Indigo server. It doesn't allow users to update action groups via the WebSocket API. <code json> { “message”: “patch”, we use a patch rather than send the entire updated device “objectType”: “indigo.ActionGroup”, “patch”: {} A patch object - see the Object Patches below for details } </code> Action group patch objects are created via the dictdiffer python module, by comparing the action dictionary (%%dict(some_action_group)%%) for the old action with the one for the new dictionary as they are received in the %%action_group_updated()%% Plugin method call. == delete action group message == <code json> { “message”: “delete”, “objectType”: “indigo.ActionGroup”, “objectId”: 123456789 } </code> This is the simplest of the messages, as it just contains the Indigo ID of the action group to delete from your collection. You'll receive this message when an action group is deleted from the Indigo server and when a action group's remote display property is set from True to False. === Action Group messages to the server === The following are examples of the action group messages that you can send to the server. == action group refresh messages == <code json> { “id”: “optional-custom-user-message”, “message”: “refresh”, “objectType”: “indigo.ActionGroup”, “objectDict”: {} ActionGroup object as outlined above } </code> == Example refresh all action groups message == <code json> { “id”: “optional-custom-user-message”, “message”: “refresh”, “objectType”: “indigo.ActionGroup”, “list”: [] a list of ActionGroup objects as outlined above } </code> === action group command messages === The execute command is currently the only command message you can send to the action group feed. It closely mirrors the Python-based IOM command for executing action groups. This was completely intentional to make learning one API a stepping stone to another. The HTTP API messages and the Websocket API messages are identical, and are very clearly a JSON-rendered version of the associated IOM command. == Execute == <code json> { “id”: “optional-custom-user-message”, “message”: “indigo.actionGroup.execute”, “objectId”: 123456789 the action group id to execute } </code> ==== Control Page Feed ==== This is the WebSocket you'll use for all control page-related communication. You will receive the following messages from the Indigo server during the lifetime of the WebSocket. The control page feed has no command messages you can send to the server; rather, it's purpose is to use incoming messages to manage a list of the available control pages which (presumably) the user would select to open that page. Here are the URLs you will use to connect to this feed. %%ws:localhost:8176/v2/api/ws/page-feed%% %%wss:YOUR-REFLECTOR-NAME.indigodomo.net/v2/api/ws/page-feed%% === Control Page messages from the server === The following are examples of the control page messages that you will receive from the server. == Example variable object (dictionary in Python) == <code json> { “class”: “indigo.ControlPage”, “backgroundImage”: ”“, “description”: ”“, “folderId”: 0, “globalProps”: {}, “hideTabBar”: true, “id”: 963336187, “name”: “Weather Images”, “pluginProps”: {}, “remoteDisplay”: true, “sharedProps”: {} } </code> Here are some examples of the server messages that clients will receive on the control page feed. == add control page message == <code json> { “message”: “add”, “objectType”: “indigo.ControlPage”, “objectDict”: {} ControlPage object as outlined above } </code> When a new control page is added to the Indigo Server after you've opened the connection, you will receive this message. It contains a control page that you will want to add to your control page list (since you'll want to patch it as it changes over time - see the next section). You'll also receive this message when a control page's remote display property is changed from False to True. == update control page message == The update control page message is received when a control page has been updated on the Indigo server. It doesn't allow users to update control pages via the WebSocket API. <code json> { “message”: “patch”, we use a patch rather than send the entire updated control page “objectType”: “indigo.ControlPage”, “patch”: {} A patch object - see the Object Patches below for details } </code> Page patch objects are created via the dictdiffer python module, by comparing the device dictionary (%%dict(some_page)%%) for the old page with the one for the new dictionary as they are received in the %%control_page_updated()%% Plugin method call. == delete control page message == <code json> { “message”: “delete”, “objectType”: “indigo.ControlPage”, “objectId”: 123456789 } </code> This is the simplest of the messages, as it just contains the Indigo ID of the control page to delete from your collection. You'll receive this message when a control page is deleted from the Indigo server and when a control page's remote display property is set from True to False. ==== Indigo Object Folders ==== Each object type above may have folders. Since those folders are specific to the type, you will use the same feed (i.e. device-feed, etc.) to get all of the available folders for that type. This is an example of a folder object. It is the same for any folder in any feed - children is the generic name for the indigo objects contained in the folder (device, variable, etc). <code> { “id”: 617272302, “class”: “indigo.Folder”, “name”: “My Device Folder”, “remoteDisplay”: true } </code> === refresh folder server message === To get the full folder list from the server, send the following message. <code> { “message”: “refresh”, “id”: “optional-custom-user-message”, “objectType”: “indigo.Device.Folder”, } </code> You will then receive the following message with all of the folders for that Indigo object type. <code> { “message”: “refresh”, “id”: “optional-custom-user-message”, “objectType”: “indigo.Device.Folder”, or indigo.Variable.Folder, etc “list”: [] A list of folder objects defined above } </code> As of this release, this is the only way to get the current state of folders (there are not add/update/delete messages). If you think you need to refresh your folder list, then send the refresh message. Since folders are generally static, there really isn't much need to continually get the folder list. ==== Log Feed ==== Use this feed to catch all log messages as they happen in the Indigo Server. When you first open the log-feed WebSocket, you will receive the last 25 log messages from the server in chronological order. After that, the messages come through the socket as they are generated (chronological order). See the Log Messages section below for a description of a log message object. Here are the URLs you will use to connect to this feed: <code> ws:localhost:8176/v2/api/ws/log-feed wss:YOUR-REFLECTOR-NAME.indigodomo.net/v2/api/ws/log-feed </code> You won't be able to send the server any messages on the log-feed, and the only message you get will be an add message for every new log entry: <code json> { “message”: “add”, “objectType”: “indigo.LogEvent”, “objectDict”: { “message”: “Stopping plugin \”Web Server 2023.2.0\” (pid 1020)“, “timeStamp”: “2022-12-01T12:03:27.759000”, “typeStr”: “Application”, “typeVal”: 0 “objectType”: “indigo.LogEvent” } } </code> ===== HTTP API ===== This API is meant for use with standard HTTP as the communication mechanism. HTTP GET requests to get Indigo object instances in JSON format, and POST requests to send commands to the Indigo Server. ==== HTTP API Endpoints ==== The following is a summary of endpoints (URLs that you will need to use the API) that are available in this release (detail on each is further down): * %%/v2/api/indigo.devices%% - endpoint to get a list of devices * %%/v2/api/indigo.devices/123456789%% - endpoint to get a specific device instance (See Device Objects below) * %%/v2/api/indigo.variables%% - endpoint to get a list of variables * %%/v2/api/indigo.variables/123456789%% - endpoint to specific variable object (See Variable Objects below) * %%/v2/api/indigo.actionGroups%% - endpoint to get a list of action groups * %%/v2/api/indigo.actionGroups/123456789%% - endpoint to get a specific action group (See Action Group Objects below) * %%/v2/api/command%% - endpoint to send Indigo a command (device control, variable update, action execution). You’ll receive full JSON objects which represent either a list of all instances of the object type requested (for example, a list of all action groups) or an individual Indigo object instance (a single device, variable, etc.) Each individual object will be different based on the object type, class and its definition (a custom device, for example). See the Indigo Object Model docs for details about each object type. ==== Authentication ==== HTTP API requests must be authenticated using an API Key. You can manage API Keys in the Authorizations section of your Indigo Account. Using keys instead of your Indigo Server username/password has several advantages: you can, at any time, revoke an API key, and it will immediately cause anything using it to fail. This will not affect anything else using your username/password or another API key, so your server protections against intrusions are much more granular. Also, if someone does manage to get your API Key, they can control devices, but they cannot modify your database (add/delete devices, etc) - that is reserved for Indigo clients using the username/password. The best way to use an API Key is to include it in an Authorization header on your HTTP request. All the examples below show this approach. If you are using a system which does not allow you to set headers for your HTTP request, you can include the API Key as a query argument with the URL: %%https://YOUR-REFLECTOR-NAME.indigodomo.net/v2/api/indigo.devices/123456789?api-key=YOUR-API-KEY%% When using HTTPS, such as when you are using your Indigo Reflector, then your API Key (in both instances) is protected by the TLS security used by the HTTPS protocol. You may use the API locally (or thorough your own router port forwarding), but those connections will be HTTP and will not be secure. It is highly recommended that you always use your Indigo Reflector because it provides a very simple and secure solution for accessing your system. IMPORTANT! Don't share your API keys with anyone who is not authorized to use them — especially in posts to the user forums. ==== Getting Device Objects ==== The HTTP API includes a couple of methods for getting device instances as JSON objects. === Getting All Device Objects === Device Objects are JSON representations of an Indigo device instance. This JSON object will contain all information about the object, which you can use in your solutions. By using the endpoint without specifying a specific device id, you can get the complete list of all devices in your Indigo database: %%/v2/api/indigo.devices%% Here are some examples in different languages/technologies that illustrate how to get all devices. == Pure Python 3 (no additional libraries) == * Replace YOUR-API-KEY with a valid key from your Indigo account. * Replace YOUR-REFLECTOR-NAME with the reflector name for your Indigo server. <code python> # This is a pure python example - no additional libraries needed from urllib.request import Request, urlopen import json REFLECTORNAME = “YOUR-REFLECTOR-NAME” APIKEY = “YOUR-API-KEY” req = Request(f”https:{REFLECTORNAME}.indigodomo.net/v2/api/indigo.devices“) req.add_header('Authorization', f”Bearer {APIKEY}“) with urlopen(req) as request: device_list = json.load(request) print(device_list) </code> == JavaScript run from nodejs (no additional libraries) == * Replace YOUR-API-KEY with a valid key from your Indigo account. * Replace YOUR-REFLECTOR-NAME with the reflector name for your Indigo server. <code javascript> Things that are specific to your environment const REFLECTORNAME = “YOUR-REFLECTOR-NAME” const APIKEY = “YOUR-API-KEY” Get the http module, and tell it that you're using HTTPS const http = require(“https”) These are options that you'll pass to the get call const options = { hostname: `${REFLECTORNAME}.indigodomo.net`, path: `/v2/api/indigo.devices`, headers: { Authorization: `Bearer ${APIKEY}` } } Get the device JSON from Indigo, parse it into an object, and log it to the console http.get(options, (response) ⇒ { let result = ”“ response.on(“data”, chunk ⇒ { result += chunk; }) response.on(“end”, () ⇒ { const deviceList = JSON.parse(result); console.log(deviceList); }) }) </code> == Using curl from the command line == * Replace YOUR-API-KEY with a valid key from your Indigo account. * Replace YOUR-REFLECTOR-NAME with the reflector name for your Indigo server. <code bash> curl -H “Authorization: Bearer YOUR-API-KEY” https://YOUR-REFLECTOR-NAME.indigodomo.net/v2/api/indigo.devices </code> === Getting a Single Device Object === Here are a few examples in different languages that illustrate how to get device objects. == Pure Python 3 (no additional libraries) == * Replace YOUR-API-KEY with a valid key from your Indigo account. * Replace YOUR-REFLECTOR-NAME with the reflector name for your Indigo server. * Replace 123456789 with a valid Indigo device ID. <code python> # This is a pure python example - no additional libraries needed from urllib.request import Request, urlopen import json REFLECTORNAME = “YOUR-REFLECTOR-NAME” APIKEY = “YOUR-API-KEY” DEVICEID = 123456789 req = Request(f”https:{REFLECTORNAME}.indigodomo.net/v2/api/indigo.devices/{DEVICEID}“) req.add_header('Authorization', f”Bearer {APIKEY}“) with urlopen(req) as request: device_instance = json.load(request) print(device_instance) </code> == JavaScript run from nodejs (no additional libraries) == * Replace YOUR-API-KEY with a valid key from your Indigo account. * Replace YOUR-REFLECTOR-NAME with the reflector name for your Indigo server. * Replace 123456789 with a valid Indigo device ID. <code javascript> Things that are specific to your environment const REFLECTORNAME = “YOUR-REFLECTOR-NAME” const APIKEY = “YOUR-API-KEY” const DEVICEID = 123456789 Get the http module, and tell it that you're using HTTPS const http = require(“https”) These are options that you'll pass to the get call const options = { hostname: `${REFLECTORNAME}.indigodomo.net`, path: `/v2/api/indigo.devices/${DEVICEID}`, headers: { Authorization: `Bearer ${APIKEY}` } } Get the device JSON from Indigo, parse it into an object, and log it to the console http.get(options, (response) ⇒ { let result = ”“ response.on(“data”, chunk ⇒ { result += chunk; }) response.on(“end”, () ⇒ { const deviceInstance = JSON.parse(result); console.log(deviceInstance); }) }) </code> == Using curl from the command line == * Replace YOUR-API-KEY with a valid key from your Indigo account. * Replace YOUR-REFLECTOR-NAME with the reflector name for your Indigo server. <code bash> curl -H “Authorization: Bearer YOUR-API-KEY” https://YOUR-REFLECTOR-NAME.indigodomo.net/v2/api/indigo.devices/123456789 </code> === Controlling an Indigo Device === You can control Indigo devices by sending commands through the API that instruct Indigo how to control the device. Indigo devices come in a variety of types, and each type has its own command set. See the Device Command Messages below for a description of all messages. For now, here are some simple examples to toggle devices: == Pure Python 3 (no additional libraries) == * Replace YOUR-API-KEY with a valid key from your Indigo account. * Replace YOUR-REFLECTOR-NAME with the reflector name for your Indigo server. * Replace 123456789 with a valid Indigo device ID. <code python> # This is a pure python example - no additional libraries needed from urllib.request import Request, urlopen import json REFLECTORNAME = “YOUR-REFLECTOR-NAME” APIKEY = “YOUR-API-KEY” DEVICEID = 123456789 # The message to send to the Indigo Server message = json.dumps({ “id”: “optional-custom-user-message”, “message”: “indigo.device.toggle”, “objectId”: DEVICEID }).encode(“utf8”) req = Request(f”https:{REFLECTORNAME}.indigodomo.net/v2/api/command“, data=message) req.add_header('Authorization', f”Bearer {APIKEY}“) with urlopen(req) as request: reply = json.load(request) print(reply) </code> == JavaScript toggle from nodejs (no additional libraries) == * Replace YOUR-API-KEY with a valid key from your Indigo account. * Replace YOUR-REFLECTOR-NAME with the reflector name for your Indigo server. * Replace 123456789 with a valid Indigo device ID. <code javascript> Things that are specific to your environment const REFLECTORNAME = “YOUR-REFLECTOR-NAME” const APIKEY = “YOUR-API-KEY” const DEVICEID = 123456789 Get the http module, and tell it that you're using HTTPS const http = require(“https”) The message to send to the Indigo Server const message = JSON.stringify({ “id”: “optional-custom-user-message”, “message”: “indigo.device.toggle”, “objectId”: DEVICEID }) These are options that you'll pass to the get call const options = { hostname: `${REFLECTORNAME}.indigodomo.net`, path: ”/v2/api/command“, method: “POST”, headers: { Authorization: `Bearer ${APIKEY}`, “Content-Length”: message.length } } Get the device JSON from Indigo, parse it into an object, and log it to the console const req = http.request(options, (response) ⇒ { let result = ”“ response.on(“data”, chunk ⇒ { result += chunk; }) response.on(“end”, () ⇒ { const deviceInstance = JSON.parse(result); console.log(deviceInstance); }) }) req.write(message) req.end()</code> == Using curl from the command line == * Replace YOUR-API-KEY with a valid key from your Indigo account. * Replace YOUR-REFLECTOR-NAME with the reflector name for your Indigo server. * Replace 123456789 with a valid Indigo device ID. <code bash> curl -X POST -H “Authorization: Bearer YOUR-API-KEY” -d '{“message”: “indigo.device.toggle”, “objectId”: 123456789}' https://YOUR-REFLECTOR-NAME.indigodomo.net/v2/api/command </code> Using these examples, you can now construct any command listed below for any device type. === Controlling an Indigo Device with Parameters === As noted above, Indigo devices come in a variety of types, and each type has its own command set. As a part of this command set, some devices require specific parameters in order for Indigo to be able to execute them (some devices accept optional parameters, and others do not require any parameters at all). See the Device Command Messages below for a description of all messages. The following examples use the indigo.dimmer.setBrightness command and demonstrate how to include parameters. == Pure Python 3 (no additional libraries) == * Replace YOUR-API-KEY with a valid key from your Indigo account. * Replace YOUR-REFLECTOR-NAME with the reflector name for your Indigo server. * Replace 123456789 with a valid Indigo device ID. <code python> # This is a pure python example - no additional libraries needed from urllib.request import Request, urlopen import json REFLECTORNAME = “YOUR-REFLECTOR-NAME” APIKEY = “YOUR-API-KEY” DEVICEID = 123456789 # The message to send to the Indigo Server message = json.dumps({ “id”: “optional-custom-user-message”, “message”: “indigo.dimmer.setBrightness”, “objectId”: DEVICEID, “parameters”: { “value”: 50, “delay”: 10 } }).encode(“utf8”) req = Request(f”https:{REFLECTORNAME}.indigodomo.net/v2/api/command“, data=message) req.add_header('Authorization', f”Bearer {APIKEY}“) with urlopen(req) as request: reply = json.load(request) print(reply) </code> == JavaScript run from nodejs (no additional libraries) == * Replace YOUR-API-KEY with a valid key from your Indigo account. * Replace YOUR-REFLECTOR-NAME with the reflector name for your Indigo server. * Replace 123456789 with a valid Indigo device ID. <code javascript> Things that are specific to your environment const REFLECTORNAME = “YOUR-REFLECTOR-NAME” const APIKEY = “YOUR-API-KEY” const DEVICEID = 123456789 Get the http module, and tell it that you're using HTTPS const http = require(“https”) The message to send to the Indigo Server const message = JSON.stringify({ “id”: “optional-custom-user-message”, “message”: “indigo.dimmer.setBrightness”, “objectId”: DEVICEID, “parameters”: { “value”: 50, “delay”: 10 } }) These are options that you'll pass to the get call const options = { hostname: `${REFLECTORNAME}.indigodomo.net`, path: ”/v2/api/command“, method: “POST”, headers: { Authorization: `Bearer ${APIKEY}`, “Content-Length”: message.length } } Get the device JSON from Indigo, parse it into an object, and log it to the console const req = http.request(options, (response) ⇒ { let result = ”“ response.on(“data”, chunk ⇒ { result += chunk; }) response.on(“end”, () ⇒ { const deviceInstance = JSON.parse(result); console.log(deviceInstance); }) }) req.write(message) req.end()</code> == Using curl from the command line == * Replace YOUR-API-KEY with a valid key from your Indigo account. * Replace YOUR-REFLECTOR-NAME with the reflector name for your Indigo server. * Replace 123456789 with a valid Indigo device ID. <code bash> curl -X POST -H “Authorization: Bearer YOUR-API-KEY” -d '{“message”: “indigo.dimmer.setBrightness”, “objectId”: 123456789, “parameters”: {“value”: 50, “delay”: 10}}' https://YOUR-REFLECTOR-NAME.indigodomo.net/v2/api/command </code> Using these examples, you can now construct any command listed below for any device type. ==== Getting Variable Objects ==== === Getting All Variable Objects === Variable Objects are JSON representations of an Indigo variable instance. This JSON object will contain all information about the object, which you can use in your solutions. By using the endpoint without specifying a specific variable id, you can get the complete list of all variables in your Indigo database: %%/v2/api/indigo.variables%% Here are some examples in different languages/technologies that illustrate how to get all variables. == Pure Python 3 (no additional libraries) == * Replace YOUR-API-KEY with a valid key from your Indigo account. * Replace YOUR-REFLECTOR-NAME with the reflector name for your Indigo server. <code python> # This is a pure python example - no additional libraries needed from urllib.request import Request, urlopen import json REFLECTORNAME = “YOUR-REFLECTOR-NAME” APIKEY = “YOUR-API-KEY” req = Request(f”https:{REFLECTORNAME}.indigodomo.net/v2/api/indigo.variables“) req.add_header('Authorization', f”Bearer {APIKEY}“) with urlopen(req) as request: variable_list = json.load(request) print(variable_list) </code> == JavaScript run from nodejs (no additional libraries) == * Replace YOUR-API-KEY with a valid key from your Indigo account. * Replace YOUR-REFLECTOR-NAME with the reflector name for your Indigo server. <code javascript> Things that are specific to your environment const REFLECTORNAME = “YOUR-REFLECTOR-NAME” const APIKEY = “YOUR-API-KEY” Get the http module, and tell it that you're using HTTPS const http = require(“https”) These are options that you'll pass to the get call const options = { hostname: `${REFLECTORNAME}.indigodomo.net`, path: `/v2/api/indigo.variables`, headers: { Authorization: `Bearer ${APIKEY}` } } Get the variable JSON from Indigo, parse it into an object, and log it to the console http.get(options, (response) ⇒ { let result = ”“ response.on(“data”, chunk ⇒ { result += chunk; }) response.on(“end”, () ⇒ { const VariableList = JSON.parse(result); console.log(VariableList); }) }) </code> == Using curl from the command line == * Replace YOUR-API-KEY with a valid key from your Indigo account. * Replace YOUR-REFLECTOR-NAME with the reflector name for your Indigo server. <code bash> curl -H “Authorization: Bearer YOUR-API-KEY” https://YOUR-REFLECTOR-NAME.indigodomo.net/v2/api/indigo.variables </code> === Getting a Single Variable Object === Here are a few examples in different languages that illustrate how to get variable objects. == Pure Python 3 (no additional libraries) == * Replace YOUR-API-KEY with a valid key from your Indigo account. * Replace YOUR-REFLECTOR-NAME with the reflector name for your Indigo server. * Replace 123456789 with a valid Indigo variable ID. <code python> # This is a pure python example - no additional libraries needed from urllib.request import Request, urlopen import json REFLECTORNAME = “YOUR-REFLECTOR-NAME” APIKEY = “YOUR-API-KEY” VARID = 123456789 # Indigo variable object id req = Request(f”https:{REFLECTORNAME}.indigodomo.net/v2/api/indigo.variables/{VARID}“) req.add_header('Authorization', f”Bearer {APIKEY}“) with urlopen(req) as request: var_instance = json.load(request) print(var_instance) </code> == JavaScript run from nodejs (no additional libraries) == * Replace YOUR-API-KEY with a valid key from your Indigo account. * Replace YOUR-REFLECTOR-NAME with the reflector name for your Indigo server. * Replace 123456789 with a valid Indigo variable ID. <code javascript> Things that are specific to your environment const REFLECTORNAME = “YOUR-REFLECTOR-NAME” const APIKEY = “YOUR-API-KEY” const VARID = 123456789 Get the http module, and tell it that you're using HTTPS const http = require(“https”) These are options that you'll pass to the get call const options = { hostname: `${REFLECTORNAME}.indigodomo.net`, path: `/v2/api/indigo.variables/${VARID}`, headers: { Authorization: `Bearer ${APIKEY}` } } Get the variable object JSON from Indigo, parse it into an object, and log it to the console http.get(options, (response) ⇒ { let result = ”“ response.on(“data”, chunk ⇒ { result += chunk; }) response.on(“end”, () ⇒ { const varInstance = JSON.parse(result); console.log(varInstance); }) }) </code> == Using curl from the command line == * Replace YOUR-API-KEY with a valid key from your Indigo account. * Replace YOUR-REFLECTOR-NAME with the reflector name for your Indigo server. * Replace 123456789 with a valid Indigo variable ID. <code bash> curl -H “Authorization: Bearer YOUR-API-KEY” https://YOUR-REFLECTOR-NAME.indigodomo.net/v2/api/indigo.variables/123456789 </code> === Updating a Variable's Value === You can interact with Indigo variables by sending commands through the API that instruct Indigo what to do. There is only one type of Indigo variable, and the variable type has its own command set. See the Variable Command Messages below for a description of all messages. For now, here is an example of how to set the value of a variable: == Pure Python 3 (no additional libraries) == * Replace YOUR-API-KEY with a valid key from your Indigo account. * Replace YOUR-REFLECTOR-NAME with the reflector name for your Indigo server. * Replace 123456789 with a valid Indigo variable ID. <code python> # This is a pure python example - no additional libraries needed from urllib.request import Request, urlopen import json REFLECTORNAME = “YOUR-REFLECTOR-NAME” APIKEY = “YOUR-API-KEY” VARIABLEID = 123456789 # The message to send to the Indigo Server message = json.dumps({ “id”: “optional-custom-user-message”, “message”: “indigo.variable.updateValue”, “objectId”: VARIABLEID, “parameters”: { “value”: “Some string value” } }).encode(“utf8”) req = Request(f”https:{REFLECTORNAME}.indigodomo.net/v2/api/command“, data=message) req.add_header('Authorization', f”Bearer {APIKEY}“) with urlopen(req) as request: reply = json.load(request) print(reply) </code> == JavaScript run from nodejs (no additional libraries) == * Replace YOUR-API-KEY with a valid key from your Indigo account. * Replace YOUR-REFLECTOR-NAME with the reflector name for your Indigo server. * Replace 123456789 with a valid Indigo variable ID. <code javascript> Things that are specific to your environment const REFLECTORNAME = “YOUR-REFLECTOR-NAME” const APIKEY = “YOUR-API-KEY” const VARIABLEID = 123456789 Get the http module, and tell it that you're using HTTPS const http = require(“https”) The message to send to the Indigo Server const message = JSON.stringify({ “id”: “optional-custom-user-message”, “message”: “indigo.variable.updateValue”, “objectId”: VARIABLEID, “parameters”: { “value”: “Some string value” } }) These are options that you'll pass to the get call const options = { hostname: `${REFLECTORNAME}.indigodomo.net`, path: ”/v2/api/command“, method: “POST”, headers: { Authorization: `Bearer ${APIKEY}`, “Content-Length”: message.length } } Get the variable JSON from Indigo, parse it into an object, and log it to the console const req = http.request(options, (response) ⇒ { let result = ”“ response.on(“data”, chunk ⇒ { result += chunk; }) response.on(“end”, () ⇒ { const VariableInstance = JSON.parse(result); console.log(VariableInstance); }) }) req.write(message) req.end()</code> == Using curl from the command line == * Replace YOUR-API-KEY with a valid key from your Indigo account. * Replace YOUR-REFLECTOR-NAME with the reflector name for your Indigo server. * Replace 123456789 with a valid Indigo variable ID. <code bash> curl -X POST -H “Authorization: Bearer YOUR-API-KEY” -d '{“message”: “indigo.variable.updateValue”, “objectId”: 123456789, “parameters”: {“value”: “Some string value”}}' https://YOUR-REFLECTOR-NAME.indigodomo.net/v2/api/command </code> Using these examples, you can now construct any command listed below for any variable type. ==== Getting Action Group Objects ==== === Getting All Action Group Objects === Action Group Objects are JSON representations of an Indigo action group instance. This JSON object will contain all information about the object, which you can use in your solutions. By using the endpoint without specifying a specific action group id, you can get the complete list of all action groups in your Indigo database: %%/v2/api/indigo.actionGroups%% Here are some examples in different languages/technologies that illustrate how to get all action groups. == Pure Python 3 (no additional libraries) == * Replace YOUR-API-KEY with a valid key from your Indigo account. * Replace YOUR-REFLECTOR-NAME with the reflector name for your Indigo server. <code python> # This is a pure python example - no additional libraries needed from urllib.request import Request, urlopen import json REFLECTORNAME = “YOUR-REFLECTOR-NAME” APIKEY = “YOUR-API-KEY” req = Request(f”https:{REFLECTORNAME}.indigodomo.net/v2/api/indigo.actionGroups“) req.add_header('Authorization', f”Bearer {APIKEY}“) with urlopen(req) as request: action_group_list = json.load(request) print(action_group_list) </code> == JavaScript run from nodejs (no additional libraries) == * Replace YOUR-API-KEY with a valid key from your Indigo account. * Replace YOUR-REFLECTOR-NAME with the reflector name for your Indigo server. <code javascript> Things that are specific to your environment const REFLECTORNAME = “YOUR-REFLECTOR-NAME” const APIKEY = “YOUR-API-KEY” Get the http module, and tell it that you're using HTTPS const http = require(“https”) These are options that you'll pass to the get call const options = { hostname: `${REFLECTORNAME}.indigodomo.net`, path: `/v2/api/indigo.actionGroups`, headers: { Authorization: `Bearer ${APIKEY}` } } Get the action group JSON from Indigo, parse it into an object, and log it to the console http.get(options, (response) ⇒ { let result = ”“ response.on(“data”, chunk ⇒ { result += chunk; }) response.on(“end”, () ⇒ { const actionGroupList = JSON.parse(result); console.log(actionGroupList); }) }) </code> == Using curl from the command line == * Replace YOUR-API-KEY with a valid key from your Indigo account. * Replace YOUR-REFLECTOR-NAME with the reflector name for your Indigo server. <code bash> curl -H “Authorization: Bearer YOUR-API-KEY” https://YOUR-REFLECTOR-NAME.indigodomo.net/v2/api/indigo.actionGroups </code> === Executing an Action Group === You can control Indigo action groups by sending commands through the API that instruct Indigo how to execute the action group. There is only one type of Indigo action group, and the action group type has its own command set. See the Action Group Command Messages below for a description of all messages. For now, here is a simple example of how to execute an action group: == Pure Python 3 (no additional libraries) == * Replace YOUR-API-KEY with a valid key from your Indigo account. * Replace YOUR-REFLECTOR-NAME with the reflector name for your Indigo server. * Replace 123456789 with a valid Indigo action group ID. <code python> # This is a pure python example - no additional libraries needed from urllib.request import Request, urlopen import json REFLECTORNAME = “YOUR-REFLECTOR-NAME” APIKEY = “YOUR-API-KEY” ACTIONGROUPID = 123456789 # The message to send to the Indigo Server message = json.dumps({ “id”: “optional-custom-user-message”, “message”: “indigo.actionGroup.execute”, “objectId”: ACTIONGROUPID }).encode(“utf8”) req = Request(f”https:{REFLECTORNAME}.indigodomo.net/v2/api/command“, data=message) req.add_header('Authorization', f”Bearer {APIKEY}“) with urlopen(req) as request: reply = json.load(request) print(reply) </code> == JavaScript run from nodejs (no additional libraries) == * Replace YOUR-API-KEY with a valid key from your Indigo account. * Replace YOUR-REFLECTOR-NAME with the reflector name for your Indigo server. * Replace 123456789 with a valid Indigo action group ID. <code javascript> Things that are specific to your environment const REFLECTORNAME = “YOUR-REFLECTOR-NAME” const APIKEY = “YOUR-API-KEY” const ACTIONGROUPID = 123456789 Get the http module, and tell it that you're using HTTPS const http = require(“https”) The message to send to the Indigo Server const message = JSON.stringify({ “id”: “optional-custom-user-message”, “message”: “indigo.actionGroup.execute”, “objectId”: ACTIONGROUPID }) These are options that you'll pass to the get call const options = { hostname: `${REFLECTORNAME}.indigodomo.net`, path: ”/v2/api/command“, method: “POST”, headers: { Authorization: `Bearer ${APIKEY}`, “Content-Length”: message.length } } Get the action group JSON from Indigo, parse it into an object, and log it to the console const req = http.request(options, (response) ⇒ { let result = ”“ response.on(“data”, chunk ⇒ { result += chunk; }) response.on(“end”, () ⇒ { const actionGroupInstance = JSON.parse(result); console.log(actionGroupInstance); }) }) req.write(message) req.end()</code> == Using curl from the command line == * Replace YOUR-API-KEY with a valid key from your Indigo account. * Replace YOUR-REFLECTOR-NAME with the reflector name for your Indigo server. * Replace 123456789 with a valid Indigo action group ID. <code bash> curl -X POST -H “Authorization: Bearer YOUR-API-KEY” -d '{“message”: “indigo.actionGroup.execute”, “objectId”: 123456789}' https://YOUR-REFLECTOR-NAME.indigodomo.net/v2/api/command </code> Using these examples, you can now construct any command listed below for any action group type. ===== API Messages ===== As mentioned earlier, both the WebSocket and HTTP APIs use JSON as the message format. We have exposed JSON versions of main Indigo objects: devices, variables, action groups, and control pages. We are also exposing command messages, which parallel the IOM command namespaces (where appropriate) for each of these object types (i.e. indigo.device, indigo.variable, etc), which will allow you to command devices, set variable values, execute action groups, etc. There are also two other message types: event log messages, which represent each message that flow into the Event Log window, and error messages, which is a standardized way to communicate error conditions with each API. In this section, we will give examples of each message type and describe their use. If you are new to JSON, you might want to use the JSON Validator website to validate that your JSON messages are valid JSON. ==== Device Messaging ==== This section describes the messages that you'll use when implementing either the WebSocket or HTTP APIs. They fall into two categories: device objects and device commands. === Device Objects === You’ll receive full device JSON objects which represent an Indigo device instance. Each device will be slightly different based on the device class and the definition (if a custom device). See the Indigo Object Model docs for device details. == Example device object == This is an example of an Indigo device as a JSON object. Of course, to accommodate the wide variety of supported device types, each one will be somewhat different. This one represents an Insteon Dimmer. <code json> { “class”: “indigo.DimmerDevice”, “address”: “3B.04.7A”, “batteryLevel”: null, “blueLevel”: null, “brightness”: 0, “buttonConfiguredCount”: 0, “buttonGroupCount”: 1, “configured”: true, “defaultBrightness”: 100, “description”: ”- sample device -“, “deviceTypeId”: ”“, “displayStateId”: “brightnessLevel”, “displayStateImageSel”: “indigo.kStateImageSel.DimmerOff”, “displayStateValRaw”: 0, “displayStateValUi”: “0”, “enabled”: true, “energyAccumBaseTime”: null, “energyAccumTimeDelta”: null, “energyAccumTotal”: null, “energyCurLevel”: null, “errorState”: ”“, “folderId”: 1552926800, “folder”: { “class”: “indigo.Folder”, “id”: 1552926800, “name”: “Insteon”, “remoteDisplay”: true }, “globalProps”: {}, “greenLevel”: null, “id”: 1508839119, “lastChanged”: “2023-02-01T11:39:58”, “lastSuccessfulComm”: “2023-02-01T11:39:58”, “ledStates”: [], “model”: “LampLinc (dual-band)”, “name”: “Insteon Dimmer”, “onBrightensToDefaultToggle”: true, “onBrightensToLast”: false, “onState”: false, “ownerProps”: {}, “pluginId”: ”“, “pluginProps”: {}, “protocol”: “indigo.kProtocol.Insteon”, “redLevel”: null, “remoteDisplay”: false, “sharedProps”: {}, “states”: { “brightnessLevel”: 0, “onOffState”: false }, “subModel”: “Plug-In”, “subType”: “Plug-In”, “supportsAllLightsOnOff”: true, “supportsAllOff”: true, “supportsColor”: false, “supportsOnState”: true, “supportsRGB”: false, “supportsRGBandWhiteSimultaneously”: false, “supportsStatusRequest”: true, “supportsTwoWhiteLevels”: false, “supportsTwoWhiteLevelsSimultaneously”: false, “supportsWhite”: false, “supportsWhiteTemperature”: false, “version”: 67, “whiteLevel”: null, “whiteLevel2”: null, “whiteTemperature”: null } </code> Message that contain device objects generate those objects by first converting the device to a python dictionary and then converting the python dictionary to JSON. See the Generating a Dictionary for a device section of the IOM Reference for details. <html><span style=“color: #3B6C35; background: rgba(92, 142, 55, .4); border: #5C8E37 solid 1px; border-radius: 4px; display: inline-block; width: 80px; text-align: center;”>HTTP</span></html> The folder element is only available in the HTTP API. Folders are handled differently in the WebSocket API. === Device Command Messages === One thing you will notice as you are looking through these examples, is that they closely mirror the Python-based IOM commands for controlling devices. This was intentional to make learning one API a stepping stone to another. The HTTP API messages and the WebSocket API messages are identical, and are very clearly a JSON-rendered version of the associated IOM command. The id key is optional, but may contain a user generated ID that will be logged and returned to help match up with message requests. Custom id values should be strings. === indigo.device === indigo.device command messages can be used for several Indigo device types - indigo.RelayDevice, indigo.DimmerDevice, indigo.SpeedControl (fans), and some indigo.SensorDevice instances. status request indigo.device.statusRequest(123456789) <code json> { “id”: “optional-custom-user-message”, “message”: “indigo.device.statusRequest”, “objectId”: 123456789 } </code> Note: This message will work on any Indigo device type, though the device that it targets may not respond to status request messages in which case it will do nothing. <html><span style=“color: #4F00B7; background: #bcb8e0; border: #9542FF solid 1px; border-radius: 4px; display: inline-block; width: 80px; text-align: center;”>WebSocket</span></html> This won't necessarily cause a device update message - if the device didn't have any changes after the status request, there will be no updates to the device in the server, so no update message will be sent out the websocket. toggle indigo.device.toggle(123456789, delay=5, duration=10) <code json> { “id”: “optional-custom-user-message”, “message”: “indigo.device.toggle”, “objectId”: 123456789, “parameters”: { “delay”: 5, “duration”: 10 } } </code> objectId is the id of the device. The parameters dictionary is optional. turn off indigo.device.turnOff(123456789, delay=5, duration=10) <code json> { “id”: “optional-custom-user-message”, “message”: “indigo.device.turnOff”, “objectId”: 123456789, “parameters”: { “delay”: 5, “duration”: 10 } } </code> objectId is the id of the device. The parameters dictionary is optional. turn on indigo.device.turnOn(123456789, delay=5, duration=10) <code json> { “id”: “optional-custom-user-message”, “message”: “indigo.device.turnOn”, “objectId”: 123456789, “parameters”: { “delay”: 5, “duration”: 10 } } </code> objectId is the id of the device. The parameters dictionary is optional. lock indigo.device.lock(123456789, delay=5, duration=10) <code json> { “id”: “optional-custom-user-message”, “message”: “indigo.device.lock”, “objectId”: 123456789, “parameters”: { “delay”: 5, “duration”: 10 } } </code> objectId is the id of the device. The parameters dictionary is optional. unlock indigo.device.unlock(123456789, delay=5, duration=10) <code json> { “id”: “optional-custom-user-message”, “message”: “indigo.device.unlock”, “objectId”: 123456789, “parameters”: { “delay”: 5, “duration”: 10 } } </code> objectId is the id of the device. The parameters dictionary is optional. enable/disable indigo.device.enable(123456789, value=True) <code json> { “id”: “optional-custom-user-message”, “message”: “indigo.device.enable”, “objectId”: 123456789, “parameters”: { “value”: True, } } </code> objectId is the id of the device. The value parameter is optional (True to enable, False to disable). === indigo.dimmer === indigo.dimmer command messages can be used for indigo.DimmerDevice instances. brighten indigo.dimmer.brighten(123456789, delay=5, duration=10) <code json> { “id”: “optional-custom-user-message”, “message”: “indigo.dimmer.brighten”, “objectId”: 123456789, “parameters”: { “by”: 5, “delay”: 10 } } </code> objectId is the id of the device. The parameters dictionary is optional. dim indigo.dimmer.dim(123456789, delay=5, duration=10) <code json> { “id”: “optional-custom-user-message”, “message”: “indigo.dimmer.dim”, “objectId”: 123456789, “parameters”: { “by”: 5, “delay”: 10 } } </code> objectId is the id of the device. The parameters dictionary is optional. set brightness indigo.dimmer.setBrightness(123456789, value=50, delay=5) <code json> { “id”: “optional-custom-user-message”, “message”: “indigo.dimmer.setBrightness”, “objectId”: 123456789, “parameters”: { “value”: 50, “delay”: 10 } } </code> objectId is the id of the device. The value parameter is required and the delay parameter is optional. === indigo.iodevice === indigo.iodevice command messages can be used for indigo.MultiIODevice instances. set binary output indigo.iodevice.setBinaryOutput(123456789, index=2, value=True) <code json> { “id”: “optional-custom-user-message”, “message”: “indigo.iodevice.setBinaryOutput”, “objectId”: 123456789, “parameters”: { “index”: 5, “value”: true } } </code> objectId is the id of the device. The index and value parameters are required. === indigo.sensor === indigo.sensor command messages can be used for indigo.sensorDevice instances. set on state indigo.sensor.setOnState(123456789, value=True) <code json> { “id”: “optional-custom-user-message”, “message”: “indigo.sensor.setOnState”, “objectId”: 123456789, “parameters”: { “value”: true } } </code> objectId is the id of the device. The value parameter is required. === indigo.speedcontrol === indigo.speedcontrol command messages can be used for indigo.speedcontrol instances. decrease speed index indigo.speedcontrol.decreaseSpeedIndex(123456789, by=2, delay=5) <code json> { “id”: “optional-custom-user-message”, “message”: “indigo.speedcontrol.decreaseSpeedIndex”, “objectId”: 123456789, “parameters”: { “by”: 2, “delay”: 5 } } </code> objectId is the id of the device. The by and delay parameters are optional. increase speed index indigo.speedcontrol.increaseSpeedIndex(123456789, by=2, delay=5) <code json> { “id”: “optional-custom-user-message”, “message”: “indigo.speedcontrol.increaseSpeedIndex”, “objectId”: 123456789, “parameters”: { “by”: 2, “delay”: 5 } } </code> objectId is the id of the device. The by and delay parameters are optional. set speed index indigo.speedcontrol.setSpeedIndex(123456789, value=2, delay=5) <code json> { “id”: “optional-custom-user-message”, “message”: “indigo.speedcontrol.setSpeedIndex”, “objectId”: 123456789, “parameters”: { “value”: 2, “delay”: 5 } } </code> objectId is the id of the device. The value parameter is required and the delay parameter is optional. set speed level indigo.speedcontrol.setSpeedLevel(123456789, value=50, delay=5) <code json> { “id”: “optional-custom-user-message”, “message”: “indigo.speedcontrol.setSpeedLevel”, “objectId”: 123456789, “parameters”: { “value”: 50, “delay”: 5 } } </code> objectId is the id of the device. The value parameter is required and the delay parameter is optional. === indigo.sprinkler === indigo.sprinkler command messages can be used for indigo.sprinkler instances. next zone indigo.sprinkler.nextZone(123456789) <code json> { “id”: “optional-custom-user-message”, “message”: “indigo.sprinkler.nextZone”, “objectId”: 123456789 } </code> objectId is the id of the device. The next zone command does not have any additional parameters. pause schedule indigo.sprinkler.pause(123456789) <code json> { “id”: “optional-custom-user-message”, “message”: “indigo.sprinkler.pause”, “objectId”: 123456789 } </code> objectId is the id of the device. The next zone command does not have any additional parameters. previous zone indigo.sprinkler.previousZone(123456789) <code json> { “id”: “optional-custom-user-message”, “message”: “indigo.sprinkler.previousZone”, “objectId”: 123456789 } </code> objectId is the id of the device. The previous zone command does not have any additional parameters. resume schedule indigo.sprinkler.resume(123456789) <code json> { “id”: “optional-custom-user-message”, “message”: “indigo.sprinkler.resume”, “objectId”: 123456789 } </code> objectId is the id of the device. The resume schedule command does not have any additional parameters. run schedule indigo.sprinkler.run(123456789, schedule=[10, 15, 8, 0, 0, 0, 0, 0]) <code json> { “id”: “optional-custom-user-message”, “message”: “indigo.sprinkler.run”, “objectId”: 123456789, “parameters”: { “schedule”: [10, 15, 8, 0, 0, 0, 0, 0] } } </code> objectId is the id of the device. The schedule parameter is required. stop schedule indigo.sprinkler.stop(123456789) <code json> { “id”: “optional-custom-user-message”, “message”: “indigo.sprinkler.stop”, “objectId”: 123456789 } </code> objectId is the id of the device. The resume schedule command does not have any additional parameters. set active zone indigo.sprinkler.setActiveZone(123456789, index=2) <code json> { “id”: “optional-custom-user-message”, “message”: “indigo.sprinkler.setActiveZone”, “objectId”: 123456789, “parameters”: { “index”: 2 } } </code> objectId is the id of the device. The index parameter is required. === indigo.thermostat === indigo.thermostatdevice command messages can be used for indigo.thermostat instances. decrease cool setpoint indigo.thermostat.decreaseCoolSetpoint(123456789, delta=2) <code json> { “id”: “optional-custom-user-message”, “message”: “indigo.thermostat.decreaseCoolSetpoint”, “objectId”: 123456789, “parameters”: { “delta”: 2 } } </code> objectId is the id of the device. The value parameter is optional. decrease heat setpoint indigo.thermostat.decreaseHeatSetpoint(123456789, delta=2) <code json> { “id”: “optional-custom-user-message”, “message”: “indigo.thermostat.decreaseHeatSetpoint”, “objectId”: 123456789, “parameters”: { “delta”: 2 } } </code> objectId is the id of the device. The value parameter is optional. increase cool setpoint indigo.thermostat.increaseCoolSetpoint(123456789, delta=2) <code json> { “id”: “optional-custom-user-message”, “message”: “indigo.thermostat.increaseCoolSetpoint”, “objectId”: 123456789, “parameters”: { “delta”: 2 } } </code> objectId is the id of the device. The value parameter is optional. increase heat setpoint indigo.thermostat.increaseHeatSetpoint(123456789, delta=2) <code json> { “id”: “optional-custom-user-message”, “message”: “indigo.thermostat.increaseHeatSetpoint”, “objectId”: 123456789, “parameters”: { “delta”: 2 } } </code> objectId is the id of the device. The value parameter is optional. set cool setpoint indigo.thermostat.setCoolSetpoint(123456789, value=76) <code json> { “id”: “optional-custom-user-message”, “message”: “indigo.thermostat.setCoolSetpoint”, “objectId”: 123456789, “parameters”: { “value”: 76 } } </code> objectId is the id of the device. The value parameters is required. set fan mode indigo.thermostat.setFanMode(123456789, value=indigo.kFanMode.AlwaysOn) <code json> { “id”: “optional-custom-user-message”, “message”: “indigo.thermostat.setFanMode”, “objectId”: 123456789, “parameters”: { “value”: “indigo.kFanMode.AlwaysOn” } } </code> objectId is the id of the device. The value parameter is required. set heat setpoint indigo.thermostat.setHeatSetpoint(123456789, value=76) <code json> { “id”: “optional-custom-user-message”, “message”: “indigo.thermostat.setHeatSetpoint”, “objectId”: 123456789, “parameters”: { “value”: 76 } } </code> objectId is the id of the device. The value parameter is required. set hvac mode indigo.thermostat.setHvacMode(123456789, value=indigo.kHvacMode.HeatCool) <code json> { “id”: “optional-custom-user-message”, “message”: “indigo.thermostat.setHvacMode”, “objectId”: 123456789, “parameters”: { “value”: “indigo.kHvacMode.HeatCool” } } </code> objectId is the id of the device. The value parameter is required. ==== Variable Messaging ==== This section describes the messages that you'll use when implementing either the WebSocket or HTTP APIs when dealing with Indigo devices. They fall into two categories: device objects and device command messages. === Variable Objects === You’ll receive full variable JSON objects which represent an Indigo variable instance. See the Indigo Object Model docs for device details. == Example variable object == <code json> { “class”: “indigo.Variable”, “description”: ”“, “folderId”: 0, “folder”: {}, “globalProps”: { “com.indigodomo.indigoserver”: {} }, “id”: 345633244, “name”: “house_status”, “pluginProps”: {}, “readOnly”: false, “remoteDisplay”: true, “sharedProps”: {}, “value”: “home” } </code> Messages that contain variable objects generate those objects by first converting the variable to a python dictionary and then converting the python dictionary to JSON. See the Generating a Dictionary for a variable section of the IOM Reference for details. <html><span style=“color: #3B6C35; background: rgba(92, 142, 55, .4); border: #5C8E37 solid 1px; border-radius: 4px; display: inline-block; width: 80px; text-align: center;”>HTTP</span></html> The folder element is only available in the HTTP API. Folders are handled differently in the WebSocket API. === Variable Command Messages === The only action that can currently be performed on a variable is to update the value. The id key is optional, but may contain a user generated ID that will be logged and returned to help match up with message requests. Custom id values should be strings. updateValue indigo.variable.updateValue(123456789, value="Some string value") <code json> { “id”: “optional-custom-user-message”, “message”: “indigo.variable.updateValue”, “objectId”: 123456789, “parameters”: { “value”: “Some string value” } } </code> objectId is the id of the variable. The value parameter is required and must be a string. Pass an empty string (”“) to clear the variable value. ==== Action Group Messaging ==== === Action Group Objects === You’ll receive full variable JSON objects which represent an Indigo action group instance. See the Indigo Object Model docs for action group details. == Example action group object == <code json> { “class”: “indigo.ActionGroup”, “description”: ”“, “folderId”: 532526508, “folder”: { “class”: “indigo.Folder”, “id”: 532526508, “name”: “Mood Scenes”, “remoteDisplay”: true }, “globalProps”: { “com.indigodomo.indigoserver”: { “speakDelayTime”: “5”, “speakTextVariable”: “speech_string” } }, “id”: 94914463, “name”: “Movie Night”, “pluginProps”: {}, “remoteDisplay”: true, “sharedProps”: { “speakDelayTime”: “5”, “speakTextVariable”: “speech_string” } } </code> <html><span style=“color: #3B6C35; background: rgba(92, 142, 55, .4); border: #5C8E37 solid 1px; border-radius: 4px; display: inline-block; width: 80px; text-align: center;”>HTTP</span></html> The folder element is only available in the HTTP API. Folders are handled differently in the WebSocket API. === Action Group Command Messages === There is only a single action group command, and that's to execute it. The id key is optional, but may contain a user generated ID that will be logged and returned to help match up with message requests. Custom id values should be strings. execute indigo.actionGroup.execute(123456789) <code json> { “id”: “optional-custom-user-message”, “message”: “indigo.actionGroup.execute”, “objectId”: 123456789 } </code> objectId is the id of the action group. ==== Log Messages ==== We convert the event Indigo dictionary into a python dictionary in the %%event_log_line_received%% plugin method. === Example Log Message === <code json> { “message”: “Stopping plugin \”Web Server 2023.2.0\” (pid 1020)“, “timeStamp”: “2022-12-01T12:03:27.759000”, “typeStr”: “Application”, “typeVal”: 0 “objectType”: “indigo.LogEvent” } </code> Note that %%typeVal%% will be one of the following values: <code python> EVENT_TYPES = { Application = 0, Error = 1, Error_Client = 2, Warning = 3, Warning_Client = 4, Debug_Server = 5, Debug_Client = 6, Debug_Plugin = 7, Custom = 8, } </code> You can use the values above to help determine any kind of decoration you want to use when displaying or otherwise interpreting the log event. === Log Command Message === In some situations, you might want to send a log message to the server and have that message appear in the Indigo Event Log. This is done using the indigo.server.log command namespace and the command API endpoint. Here is full python example with a log message payload: <code> import requests REFLECTOR = “MY_REFLECTOR_NAME” API_KEY = “MY_API_KEY” url = f”https:{REFLECTOR}.indigodomo.net/v2/api/command“ headers = {'Authorization': f'Bearer {API_KEY}'} message = { “id”: “optional-user-generated-id”, “messageText”: “Some important log message goes here.”, “message”: “indigo.server.log”, } response = requests.post(url, headers=headers, json=message) if response.status_code == 200: device_list = response.json() print(device_list) else: print(f”Failed to fetch data. Status code: {response.status_code} - {response.text}“) </code> ===== Error Messaging ===== Error messages will be returned to API clients in the event that something didn’t go as planned. The structure of messages returned will depend on what went wrong and how the message was sent. Note that folder messages are added to the feed by the server; there are no folder endpoints to manage folders from a client at this time. A generic example message is provided in JSON format: == Generic Error Message == <code json> { “error”: “Some error description”, “id”: “the id sent from the client in the message, or null if there wasn't one”, “validationErrors”: { “field1”: “some error that occurred in the message with the key field1” } } </code> where the value of the JSON name (or key) %%validationErrors%% is a dictionary with a field name and a description of the error in that field that came from the client. For instance, if you pass a float %%value%% to the %%indigo.variable.updateValue%% message: == Example API Call == <code json> { “id”: “a-random-id-for-this-message”, “message”: “indigo.variable.updateValue”, “objectId”: 123456789, “parameters”: { “value”: 1234.56 } } </code> You will receive the following error response: == Resulting Error Message == <code json> { “validationErrors”: { “value”: “variable values must be strings” }, “error”: “invalid command payload received, id: my-set-var-command”, “id”: “a-random-id-for-this-message” } </code> The %%error%% key is the indicator that the response is some kind of error. %%validationErrors%% is a dict which contains all the validation errors for the message, in this case the %%value%% that was passed in was not a string (it was the float %%1234.56%%). The possible keys in the error message reply %%validationErrors%% could be: - %%message%%, - %%objectId%%, - %%parameters%%, and - %%value%% based on the %%indigo.variable.updateValue%% message format (we do no validation on the %%id%% value passed in, we pass it through, and if your message doesn’t contain one then the value will be %%null%%). Only the keys from your message that have errors will be returned. So in the example error above, only the %%value%% key had a validation error (because we passed in a float) so that was the only key returned. id is the ID you (may have) passed in when you sent the command message. === Invalid JSON === One other type of error that you may receive would be if you POST a string (or something else, like XML, etc.) that’s not JSON. This will result in the following message return: == Example Invalid JSON Message == <code json> { “request_body”: “this is not valid JSON”, “error”: “invalid JSON” } </code> We will return the entire request body since it isn’t valid JSON, and we don’t know what else to do with it. === Web Server Warnings === Occasionally, you might see a warning from the Web Server written to the Indigo Event Log that might look something like this: Web Server Warning HTTP 400 error for request /v2/api/command/ from 123.45.678.90 The codes are standard HTTP response codes and may help you to determine what happened. The most common codes you might encounter are: ^ Code ^ Condition ^ Description ^ | 200 | OK or Success |Indicates that the request has succeeded. | | 400 | Bad Request |Indicates that the server cannot or will not process the request due to something that is perceived to be a client error <HTML><BR></HTML>(for example, malformed request syntax, invalid request message framing, or deceptive request routing) | | 401 | Unauthorized |Indicates that the client request has not been completed because it lacks valid authentication credentials for the <HTML><BR></HTML>requested resource. | | 404 | Not Found |Indicates that the server cannot find the requested resource. | | 405 | Method Not Allowed |Indicates the server has received your request, but the resource you are requesting doesn't support the request method. For example, using a POST when a GET is expected. | | 500 | Internal Server Error |Indicates that the server encountered an unexpected condition that prevented it from fulfilling the request. | You might see another code from time to time, and a complete list of codes and their meanings can be found on the Mozilla web docs site under “HTTP response status codes”. === Other Errors and Warnings ===
  • /www/perceptive/wiki/data/attic/indigo_2023.2_documentation/api.1727129943.txt.gz
  • Last modified: 2024/09/23 22:19
