Managing Your Z-Wave® Network
Connecting Z-Wave Interfaces
- Choose the
Interfaces→Z-Wave→Enable
menu item. This should cause theConfigure Z-Wave
dialog to open automatically (but only the first time you enable Z-Wave - you can select theInterfaces→Z-Wave→Configure…
menu item to get back to the configuration dialog later): - The default
Connection Type
ofLocal (physical)
is correct (assuming you've plugged your Z-Stick directly into your Mac). - On the
Serial Port
popup, you should select the serial port titledSLAB_USBtoUART
(for Z-Stick Series 2) or one that starts withusbmodem
(for Z-Stick Gen5), depending on which Z-Stick version you have. If you have two serial ports that start withSLAB_USBtoUART
that means that you have multiple devices that use the Silicon Labs VCP driver - you'll just need to try each one to determine which is the correct port if you don't know beforehand. Unfortunately, that driver doesn't handle multiple devices using the Silicon Labs chip very well, and that number may change when you reboot. - Unless instructed by Perceptive Automation support, you should leave the
Show debug logging of interface communication
checkbox unchecked. - Save the
Configure Z-Wave
dialog.
Choose the Interfaces→Z-Wave→Disable
(or Enable
Adding a Z-Wave Device
- Select
DEVICES
in the Main Window outline view or select one of the sub-folders. - Click the
New…
button. You'll see theCreate New Device
dialog. - Select
Z-Wave
from the Type popup menu. - Click the
Define and Sync…
button. - You'll see the
Synchronize Z-Wave Device
dialog. - Follow the directions on the dialog to complete setting up the device.
Using Encryption
If you added a device to the network (Z-Wave Controller) without encryption enabled and then wish to enable encryption you must first remove it from the network. This is because the encryption key exchange can only occur with Indigo if the device has just been added to the network (within a few seconds), and before a device can be added to the network it must not be included in any networks. To do this you can use the Interfaces->Z-Wave->Start Controller Exclusion Mode
menu item to put the Z-Wave Controller into exclusion mode, then follow the steps from the device's manual to have it exclude itself from the network. Once excluded (you can see the progress in the Event Log window
), you can then use the New with Encryption Enabled
button inside the Syncrhonize Z-Wave Device dialog to re-add it to the network with encryption.
If you have a Z-Wave lock currently included with another controller, you must first exclude the lock from the network before adding it to Indigo with encryption enabled. To do this you can use the Interfaces->Z-Wave->Start Controller Exclusion Mode
menu item to put the Z-Wave Controller into exclusion mode, then follow the steps from the device's manual to have it exclude itself from the network. Note you do not have to use the original controller to perform the exclusion – you can use Indigo's exclusion process. Once excluded (you can see the progress in the Event Log window
button inside the Syncrhonize Z-Wave Device dialog to add it to Indigo's Z-Wave network with encryption. Follow the instructions from the lock's manual for the inclusion steps required. Note that either the Z-Wave Controller used by your Mac or a device that supports Z-Wave beaming will need to be within close proximity to the lock for the communication to succeed.
- Select
DEVICES
in the Main Window outline view or select one of the sub-folders. - Find the device in the device table and double-click it (or select it an click the
Edit…
button) - You'll see the standard
Edit Device
dialog - Click on the
Edit Device Settings…
button and you'll see the configuration dialog:
, is a great optimization - some devices send out a message whenever they change - they don't actually send the necessary information for Indigo to automatically update state, but it is enough to bump the device to the top of the poll list so that the status update will occur much more quickly. And it keeps us from having to poll the device at regular intervals because we can just poll it when we see this specific message. How do you know to select this option? You can try the setting out: just select Only When Activity Detected
- we'll poll the device as frequently as we can given the conditions of the z-wave network.
Also shown in the settings dialog are any configuration parameters specific to that device (in this example the temperature units and display contrast). Indigo only shows settings if there is a custom device profile for a particular device. However, if no settings are shown you can still modify any configuration parameters by using the Interfaces->Z-Wave->Modify Configuration Parameter...
menu item.
If a Submit Device Information
button is visible, then you can use it to help us learn more about the device. When pressed a page will open in your browser asking for some more information that will help us and other users more effectively use the device. Please take time to accurately fill out the form as much as possible. The more information we have the more likely we will be able to add a custom device profile to fully support the device.
- Select
DEVICES
in the Main Window outline view or select one of the sub-folders. - Find the device in the device table and double click it (or select it and click the
Edit…
button). - Click the
Define and Sync…
button. - Click on the
Sync
button. - When the
dialog disappears, just close theEdit Device
dialog.
- Select
DEVICES
Edit…
Define and Sync…
button. - Follow the instructions on the dialog to use your interface to include the device into your network if you haven't already.
Sync using node
popup - Click on the “Sync” button.
- When the
dialog.
Note that not all devices can be replaced. Specifically, if a device has multiple personalities (like, for instance, a multi-sensor that has a motion sensor, temp sensor, humidity sensor, etc) and any of those dependent devices are used in Triggers, Conditions, Actions, or Control Pages, then you'll get an error message in the Event Log window
saying that you need to manually resolve those conflicts (or manually delete the device). Indigo helps with this process - see Deletion Dependencies for details.
Deleting a Z-Wave Device
- Select
DEVICES
in the Main Window outline view or select one of the sub-folders. - Find the device in the device table and select it.
- Click the
Delete…
button (or press the Delete key on the keyboard).
The last thing you'll want to do is to exclude the device from your network if it's still functional. To do this you can use the Interfaces->Z-Wave->Start Controller Exclusion Mode
Replacing a Z-Wave Controller
- Select the
Interfaces→Start Controller Exclusion Mode
. Note you can exclude from any controller, not just the one it was included with. - Go to the Z-Wave device closest to your Mac that’s not battery powered (also skip any that require encryption) and perform its exclusion process.
Define and Sync
button and press theNew with Encryption Disabled
(only select Enabled if you're including a device which requires encryption to work correctly, such as a lock). - Go back to your device and perform its inclusion process (press its LINK button, etc.).
Inclusion into network successful
in green just under theAdd to network
buttons), confirm that the new node shows up in the popup at the bottom, and then pressSync
. - Repeat steps 3-7 for each non-battery powered device from the closest to your Mac to the furthest.
- Finally, select the
Interfaces→Z-Wave→Optimize Z-Wave Network…
menu item and clickStart Optimization
- you can do this at night just before going to bed when the network is likely to be the least busy.
Define and Sync
button. - Select the new node number from the popup at the bottom and
Sync
Z-Wave Menu Options
The Interfaces→Z-Wave
Manage Associations
Send Raw Z-Wave Command
This menu selection puts the Z-Wave Controller into inclusion mode. You can then follow the steps from the device's manual to have it include itself from the network. Open and watch the Event Log window
for progress as it is included. This menu item is functionality the same as using the New with Encryption Disabled
button inside the Synchronize Z-Wave Device
dialog.
This menu selection puts the Z-Wave Controller into inclusion mode with encryption enabled. You can then follow the steps from the device's manual to have it include itself from the network. Open and watch the Event Log window
for progress as it is included. This menu item is functionality the same as using the New with Encryption Enabled
dialog.
This menu selection puts the Z-Wave Controller into exclusion mode. You can then follow the steps from the device's manual to have it exclude itself from the network. Open and watch the Event Log window
for progress as it is excluded. Note Indigo is able to exclude device s from any Z-Wave network.
Stop Inclusion / Exclusion
Reset Z-Wave Interface
