Getting Started Guide
Welcome to Indigo 2023.2!
- Mac OS X 10.12 or higher
Z-Wave
- Thermostats, and
- Locks.
INSTEON
X10
Other Devices
Other Sources for Help
Installing Indigo
The Indigo 2023.2 application can be found here:
/Applications/Indigo 2023.2.app
/Library/Application Support/Perceptive Automation/Indigo 2023.2/
By default, database files are stored in the Databases
folder in that folder.
Backing Up Indigo
Time Machine will do this by default. To recover, just recover that directory and then run the Indigo 2023.2 installer again (which will repair any permission issues that Time Machine may have introduced).
Server Folder Change
Web Assets Folder Change
If you have any existing Python modules/libraries in the old Python2-includes
folder you should copy them to the new folder and make sure they are Python 3 compatible.
Indigo 202x.y→Stop Server
menu item in the Mac client. This will shutdown the Indigo Server regardless of which version is running. - Quit the Mac client via the
Indigo 202x.y→Quit Indigo
menu item. - Open the
/Applications
Indigo plugins can now run under Python 3. Check the Plugin Store and Plugin user forum for updates to the 3rd party plugins you are using.
Indigo 2023.2→License Details…
menu item and clicking theDeactivate License
button. Do this while the Indigo Server is still running (do not shutdown the Indigo Server first) - Copy this folder over to the new Mac:
(if restoring from a backup, you'll need to locate this folder in whatever backup system you use) - Install Indigo 2023.2 on the new Mac (download and run the installer - you must be logged in to your Indigo Account to see all the installers available to you)
- manually remove the
directory, and - run the Indigo installer again to reinstall Python.
Uninstalling Indigo
Uninstalling the Server
To uninstall the Indigo Server and all of its data and configuration files, first deactivate Indigo on your Mac by selecting the Indigo 2023.2→License Details…
from the Indigo 2023.2
- Optional : If you don't use Python 3.11 for anything (other than Indigo 2023.2), you can delete this folder:
/Library/Frameworks/Python.framework/Versions/3.11
and this file:/Library/Frameworks/Python.framework/Versions/Current
Note: this will leave any other version of Python alone including any previous versions that older Indigo installs may have installed (if you plan on reverting to an older version). To completely remove all Python installations that any version of Indigo may have installed, just delete the entire Python framework:/Library/Frameworks/Python.framework
Uninstalling the Mac Client
~(your user folder)/Library/Preferences/com.perceptiveautomation.indigo-2023-2.plist
~(your user folder)/Library/Preferences/Indigo 2023.2 Client Prefs.indiPref
~(your user folder)/Library/Preferences/Indigo 2023.2 Client Settings.indiPref
To uninstall older versions but leave 2023.2 installed correctly, delete these:
- Indigo 2023.1:
/Library/Application Support/Perceptive Automation/Indigo 2023.1/
/Applications/Indigo 2023.1.app
- Indigo 2022.2:
/Library/Application Support/Perceptive Automation/Indigo 2022.2/
/Applications/Indigo 2022.2.app
- Indigo 2022.1:
- Indigo 2021.2:
/Library/Application Support/Perceptive Automation/Indigo 2021.2/
/Applications/Indigo 2021.2.app
- Indigo 2021.1:
/Library/Application Support/Perceptive Automation/Indigo 2021.1/
/Applications/Indigo 2021.1.app
- Indigo 7.5:
/Library/Application Support/Perceptive Automation/Indigo 7.5/
/Applications/Indigo 7.5.app
- Indigo 7.4:
/Library/Application Support/Perceptive Automation/Indigo 7.4/
/Applications/Indigo 7.4.app
- Indigo 7.3:
/Applications/Indigo 7.3.app
- Indigo 7.2:
/Library/Application Support/Perceptive Automation/Indigo 7.2/
/Applications/Indigo 7.2.app
- Indigo 7.0 and 7.1:
/Applications/Indigo 7.app
/Library/Application Support/Perceptive Automation/Indigo 6/
/Applications/Indigo 6.app
Starting Indigo Server
- Double click the
Indigo 2023.2
application (/Applications/Indigo 2023.2.app
). - If this is the first time to run
Indigo 2023.2
on this Mac, then press theStart Local Server…
button in the connection status window. - If you want to reconfigure the Indigo Server on a Mac already running Indigo, then select the
Indigo 2023.2→Start Local Server…
menu item.
Standard startup mode
Choose the Standard Indigo Startup
Use the Allow remote access
checkbox to enable remote access from other Macs and Web browsers. You must enter a username and password if you enable remote access.
Use the Override Web server port number:
Use the Enable secure internet access via Indigo Reflector
Use the Enable OAuth and API Key authentication
checkbox to enable 3rd party services like Alexa. It also will allow REST API calls to use an API key for authentication rather than a username/password. This is more secure since you can revoke a key if it gets compromised without having to change passwords in wherever you may need to use them.
checkbox to allow remote Indigo Clients on other Macs to connect to the Indigo Server. Note that this only works on your local network - the Indigo Reflector service is only for Indigo Touch and other web access, not for configuration client connections.
Custom single app startup
Starting the Server
Press the Start Server
button, or the Restart Server
button.
Remote Indigo Access
Modifying Firewall Settings
- Double click the
Indigo 2023.2
application (inside/Applications/Indigo 2023.2.app
) on the remote Mac. - If this is the first time to run
Indigo
on this remote Mac, then press theConnect to Remote Server…
button in the connection status window. - If you are wanting to connect to a different Indigo Server, then select the
Indigo 2023.2→Connect to Remote Server…
menu item. - Enter the
IP address
for the Indigo Server Mac discovered in the section above. - If you overrode the Indigo Server port number (default:
1176
) in the Start Local Server dialog on the server Mac, then select theOverride default port number
checkbox and enter your custom port number. - Press the
Connect
button.
on the Settings
http://192.168.1.23:8176/
Managing Plugins
Installing/Updating Plugins
- Click the
Download Latest Release
button, which will download the plugin. If the release isn't compatible with your version of Indigo, you can click on the Releases tab, and look through the list for a version that works with your version of Indigo (click on it and then click theDownload this release
link). - Most plugins will show the plugin directly as the above image. If it does, double click it and proceed to step 8 below.
.indigoPlugin
. Double-click that file. - You will be switched to the Indigo Client app, and you'll a dialog window which asks you if you want to install and enable the plugin . You will see a different dialog if the version number is lower than an already-installed version; for safety, Indigo will ask you to confirm that you want to downgrade the plugin.
- NOTE: due to a bug in some macOS releases, this step may try to launch a previous version of Indigo. If it does, quit it, then right-click the plugin file, select the
Open With
menu item, then select Indigo 2023.2. - Click the
Install and Enable
button. - Done!
Plugin Menus in Indigo
Main Plugins Menu
- a gray dot means the plugin is disabled
- a green dot with no arrows means the plugin is enabled and up to date.
- a green dot with a black arrow means the plugin is enabled and there is an update available that will work with your Indigo version
- a green dot with a red arrow means the plugin is enabled and there is an update available but it won't work with your version of Indigo
- a yellow dot with no arrows means the plugin is enabled but needs updating before the next Indigo release
- a yellow dot with a black arrow means the plugin is enabled and there is an update available that will work with your Indigo version - you should install the update before upgrading to the next version of Indigo
- a yellow dot with a red arrow means the plugin is enabled and there is an update available but it won't work with your version of Indigo
- the plugin is not compatible with your version of Indigo and we are not aware of a version that will work with your version of Indigo.
- the plugin has failed due to a catastrophic error that has caused the plugin to crash or has caused Indigo to stop the plugin. An error will be output to the log to explain the problem.
- the plugin's
self.stopPlugin()
method has been called for any reason.
The Manage Plugins…
The Plugin Store
will open the Scripts folder (where you can save external scripts in a version-agnostic way).
The Open Scripting Shell
Individual Plugin Submenu
menu. For instance, here's the 3rd party Harmony Hub plugin submenu when it's enabled:
Enable
to enable the plugin andDisable
to disable the plugin. - the
Reload
menu item will reload the plugin and will only be present if the plugin is enabled. - there may be a couple more menus if you have the
Enable debugging menus
item selected in the Plugins tab of the Indigo Preferences (and are discussed in that section).
The next section contains:
- the
Configure…
menu item will open a config dialog if the plugin has plugin-specific configuration items (if not or if the plugin is disabled, it will not be present). - the
Show in Plugin Store…
menu item will open the plugin's entry in the Plugin Store in the default browser. If there is an available plugin update that will work on your version of Indigo, the menu title will beDownload New Version…
which will also open the plugin's entry in the Plugin Store in the default browser so you can download the new version, and if there is an incompatible version the menu title will beIncompatible Version Available…
which will drop a sheet showing what version of Indigo is required to run the new plugin version. This menu item will always show, but if it's grayed out it means the plugin isn't from the Plugin Store. - the
Copy Plugin ID
menu item will always show, and when selected will copy the plugin's unique ID for use in scripts. - the
About…
menu item will always show the current version of the plugin and will always be enabled.
Other Menus with Plugin Items
You can also enable/disable a plugin and download a new plugin version from the Plugins tab in the Indigo Preferences. You open the config window choosing the Indigo 2023.2→Preferences…
menu item discussed above.
- the
checkbox will add two new menus to the plugin's menus:Reload in Debugger
will reload the plugin and connect to the selected debugger;Reload in Interactive Shell
will open a terminal window with a Python shell that's connected to the plugin so the developer can run commands and inspect arbitrary objects in the running plugin. - the
Use debugger
popup is used to tell Indigo which debugger to start the plugin up when you use the above menu items.
Uninstalling a Plugin
Help→Show Indigo Server Install Folder
menu item. This will switch you to the Finder and open a window to the Indigo install folder. - Switch back to Indigo and shut down the Indigo Server by selecting the
Indigo 2023.2→Stop Server
menu item in the Mac client (you can leave the client app running). - In the Finder window opened in step 1, you'll see two folders:
Plugins
andPlugins (Disabled)
. Depending on whether the plugin is enabled or not will determine which folder it's in. Open the appropriate folder and delete the unwanted plugin. Check to make sure that somehow there aren't plugins in both locations. - Switch back to the Indigo 2023.2 Mac client and click on the
Start Local Server…
button in theServer Connection Status
dialog.
- Choose
System Preferences
from theApple
menu. - Select the
Date & Time
icon. - Select the
Time Zone
panel. - If the current
Closet City
location is not near your location, then follow the instructions on the panel to choose your location.
- Choose the
menu item, then make sure theSunset & Sunrise
tab is selected. - Select the
Override system location
checkbox. - Enter your exact
Latitude
andLongitude
coordinates.
You can configure other Indigo settings by opening the preferences dialog (selecting the Indigo 2023.2→Preferences…
tab.
You can have Indigo check for updates immediately by selecting the Indigo 2023.2→Check for Updates…
menu item.
- Choose
System Preferences
from theApple
menu. - Select the
Energy Saver
icon. - Move the
Computer sleep:
slider toNever
. - Uncheck
Put the hard disk(s) to sleep when possible
. - Select the
Start up automatically after a power failure
checkbox.
Where to Go Next
