Indigo Scripting Tutorial
Turn off all devices:
indigo.device.allOff()
indigo.devices.len()
if hasattr(lamp, 'onState'):
    isOn = lamp.onState
from datetime import datetime
Access a custom device state
# get the device
# show all the device states:
print(dev.states)
Getting a variable object and using it's value:
myVar = indigo.variables[123]
if myVar.value == "true":
Duplicating a variable:
import requests
my_unicode_string = "éçø"
my_integer = 1
my_float = 1.0
import json
my_new_dictionary["my_list"]
Custom Python classes that you create can implement the __str__(self) method. Take this simple example:
class myCustomClass:
    def __init__(self):
        self.a=1
        self.b=2
    def __str__(self):
        return outputString
cl = myCustomClass()
Get the current server time:
indigo.server.getTime()
import datetime
Log to the Indigo Event Log window all of the attributes/properties of the device "office desk lamp":
import logging
print(logList)
except ValueError as e:
        myFolder = None
if lamp.folderId != 0:
    lampsFolder = None
Sending emails
# Simple Example
/usr/local/indigo/indigo-host
indigo-host -e '
indigo_attachments.py
    import indigo
except ImportError:
    raise ImportError
def log(message, label=None):
import indigo_attachments
    raise ImportError
ImportError
pluginSupportURL str The URL supplied by the plugin that points to it's user documentation
Method Description
restart(waitUntilDone=True) This method will restart the plugin if it's already running. Pass the optional parameter waitUntilDone=False if you don't want to block while the plugin restarts (waitUntilDone defaults to True if it's no parameters are passed). If you're a plugin developer and you want to restart the plugin from within itself you should pass that parameter.
Plugin actions may return a value (a Python “primitive”) when you call the executeAction method, but they are not required to. The return value can be any one of the following object types:
  • None None,
  • booleans bool,
  • integers int(),
  • floats float(),
  • strings str(),
  • Indigo Dicts indigo.Dict(),
  • Indigo Lists indigo.List().
Restart a Plugin
    airfoil_plugin.restart()
Wait Until Done
if airfoilPlugin.isEnabled():
            'getSources',
            waitUntilDone=True
    except Exception as e:
     audioDevices : (list)
          Item : (dict)
               icon : [SNIP]
          Item : (dict)
               icon : [SNIP]
          Item : (dict)
               icon : [SNIP]
     recentApplications : (list)
          Item : (dict)
               icon : [SNIP]
          Item : (dict)
               icon : [SNIP]
    systemAudio : (list)
    	  Item : (dict)
    	  	   icon : [SNIP]
  • /www/perceptive/wiki/data/pages/indigo_2023.2_documentation/plugin_scripting_tutorial.txt
