EasyDAQ Relay Card Plugin
  • USB24MxS (24 relays)
  • USBDIO24 (24 DIO channels)
Some actions have additional options available via the Edit… button. For example, the Change Multiple Outputs action allows you to control (turn on, turn off, or toggle) all of the outputs with a single, and very fast, action:
Turn On Output
Action id: turnOnOutput
Properties for scripting:
plugin_id = "com.perceptiveautomation.indigoplugin.easydaq-usb-relay-cards"
easyDaqPlugin = indigo.server.getPlugin(plugin_id)
if easyDaqPlugin.isEnabled():
	easyDaqPlugin.executeAction(
        "turnOnOutput",
        deviceId=131523919,
        props={'channelSel':1}
Turn Off Output
Action id: turnOffOutput
        "turnOffOutput",
        deviceId=131523919,
Toggle Output
Action id: toggleOutput
        "toggle",
        deviceId=131523919,
All Outputs On
Action id: allOutputsOn
        "allOutputsOn",
        deviceId=131523919
All Outputs Off
Action id: allOutputsOff
        "allOutputsOff",
        deviceId=131523919
Action id: changeMultiple
        "changeMultiple",
        deviceId=131523919,
        props={
            'channelSel1':'turnOn',
            'channelSel8':'toggle',
            'channelSel17':'turnOff'
  • /www/perceptive/wiki/data/pages/indigo_2023.2_documentation/plugins/easydaq_1.txt
