Triggers
Trigger Base Class
globalProps | dictionary | No | an indigo.Dict() representing all name/value pairs associated with this trigger - each plugin will have its own dictionary (globalProps[pluginId]) - see About Plugin Properties below for details |
sharedProps | dictionary | No | API v2.3 : an indigo.Dict() representing the name/value pairs that are shared by all plugins. This is the property dictionary that you can edit via the Global Properties plugin, and your plugin may manage properties in this dictionary as well to add metadata to devices that your plugin can use for other purposes. Use trigger.replaceSharedPropsOnServer() to update them (as with pluginProps, you should get copy first, update the copy, then set them back to that copy so as to not accidentally remove some other plugin's props). |
Commands (indigo.trigger.*)
indigo.trigger.delete(123) |
| Parameters | |||
| Parameters | |||
Enable/Disable Trigger
| Parameters | |||
duration | No | integer | number of seconds before the trigger is switched back to its original state |
Execute Trigger
| Parameters | |||
depDict = indigo.trigger.getDependencies(123) |
| Parameters | |||
| direct parameter | Yes | integer | id or instance of the trigger to get the dependencies for. |
ID : 552463741 (integer)
ID : 296710860 (integer)
| Parameters | |||
| Parameters | |||
# Change a trigger's name: trigger = indigo.triggers[123] trigger.name = "My new name." trigger.replaceOnServer() # Change a trigger's description: trigger = indigo.triggers[123] trigger.description = "My new description." trigger.replaceOnServer()
DeviceStateChangeTrigger
State Change Type Enumeration
| indigo.kStateChange | ||
State Selector Enumeration
| indigo.kStateSelector | |
BinaryOutputsAll | |
HumidityInput | monitor (one of) the humidity sensor(s) available on the device for =, !=, <, >, and any change - stateSelectorIndex is required to be in the range of available inputs |
KeypadButtonLed | |
folder=1234)
| Parameters | |||
EmailReceivedTrigger
emailFrom | string | Yes | if emailFilter is MatchEmailFields, the value to match against the sender’s address |
emailSubject | string | Yes | if emailFilter is MatchEmailFields, the value to match against the subject line |
Email Filter Enumeration
| indigo.kEmailFilter | |
Commands (indigo.emailRcvd.*)
folder=1234)
| Parameters | |||
theTrigger=indigo.emailRcvd.create(name="Emails from [email protected]") theTrigger.emailFilter = indigo.kEmailFilter.MatchEmailFields theTrigger.emailFrom = "[email protected]" theTrigger.replaceOnServer()
InsteonCommandReceivedTrigger
INSTEON Command Enumeration
| indigo.kInsteonCmd | |
folder=1234)
| Parameters | |||
InterfaceFailureTrigger
folder=1234)
| Parameters | |||
InterfaceInitializedTrigger
folder=1234)
| Parameters | |||
PluginEventTrigger
folder=1234),
pluginTypeId="myEvent",
| Parameters | |||
PowerFailureTrigger
folder=1234)
| Parameters | |||
ServerStartupTrigger
folder=1234)
| Parameters | |||
X10CommandReceivedTrigger
X10 Command Enumeration
| indigo.kX10Cmd | |
X10 A/V Button Enumeration
| indigo.kX10AvButton | |
| Value | Value |
0 | Left |
1 | Menu |
2 | Mute |
3 | Pause |
4 | PC |
5 | Play |
6 | Power |
7 | Recall |
8 | Record |
9 | Return |
AB | Rewind |
ChannelDown | Right |
ChannelUp | Stop |
Display | Title |
Down | Up |
Enter | VolumeDown |
Exit | VolumeUp |
Forward | |
folder=1234)
| Parameters | |||
VariableValueChangeTrigger
| indigo.kVarChange | |
folder=1234)
| Parameters | |||
