Integration APIs
NOTE:
  • /v2/ - this is the top level version number and will change as necessary
  "key1": "value 1",
  "key2": 2
PythonJSON Equivalent
True true
False false
float Number
int Number
None null
dict Object
list Array
tuple Array
str String
There are 7 WebSocket feeds that that are available:
  • /v2/api/ws/device-feed - WebSocket to do all communication about devices
  • /v2/api/ws/variable-feed - WebSocket to do all communication about variables
  • /v2/api/ws/action-feed - WebSocket to do all communication about action groups
  • /v2/api/ws/schedule-feed - WebSocket to do all communication about schedules
  • /v2/api/ws/trigger-feed - WebSocket to do all communication about triggers
  • /v2/api/ws/page-feed - WebSocket to do all communication about control pages
  • /v2/api/ws/log-feed - WebSocket to do all communication about logs
WebSocket Lifecycle
  1. Setup:
Python Receiver Example
import asyncio
import websockets
import json
API_KEY = 'YOUR-API-KEY'
async def receiver():
            while True:
    except Exception as exc:
        print(f"Exception:\n{exc}")
asyncio.run(receiver())
import asyncio
import json
async def receiver(ws):
        refresh_message = {
            "message": "refresh",
            "objectId": DEVICE_ID
        counter = 0
        device = {}
        while counter < 20:
            if message_type == "refresh":
            elif message_type == "patch":
            counter += 1
async def sender(ws, count):
        print("Starting sender task")
        message = {
        for count in range(10):
            msg = json.dumps(message)
            await asyncio.sleep(5)
async def main():
asyncio.run(main())
JavaScript Example
  console.log(message.data);
add device message
  "message": "add",
  objectDict": {
    "address": "3B.04.7A",
    "batteryLevel": null,
    "blueLevel": null,
    "brightness": 100,
    "buttonConfiguredCount": 0,
    "buttonGroupCount": 1,
    "configured": true,
    "defaultBrightness": 100,
    "deviceTypeId": "",
    "displayStateValRaw": 100,
    "displayStateValUi": "100",
    "enabled": true,
    "energyAccumBaseTime": null,
    "energyAccumTimeDelta": null,
    "energyAccumTotal": null,
    "energyCurLevel": null,
    "errorState": "",
    "folderId": 1552926800,
    "globalProps": {
      "emptyDict": {}
    "greenLevel": null,
    "id": 1508839119,
    "ledStates": [],
    "name": "Insteon Dimmer",
    "onBrightensToLast": false,
    "onState": true,
    "ownerProps": {},
    "pluginId": "",
    "pluginProps": {},
    "redLevel": null,
    "remoteDisplay": false,
    "sharedProps": {},
    "states": {
      "brightnessLevel": 100,
      "onOffState": true
    "subModel": "Plug-In",
    "subType": "Plug-In",
    "supportsAllOff": true,
    "supportsColor": false,
    "supportsOnState": true,
    "supportsRGB": false,
    "supportsWhite": false,
    "version": 67,
    "whiteLevel": null,
    "whiteLevel2": null,
    "whiteTemperature": null
update device message
  "message": "patch",
  "objectId": 1508839119,
  "patch": [
      "change",
      "brightness",
      [100, 0]
      "change",
      "displayStateImageSel",
      "change",
      "displayStateValRaw",
      [100,  0]
      "change",
      "displayStateValUi",
      ["100", "0"]
      "change",
      "lastChanged",
      "change",
      "lastSuccessfulComm",
      "change",
      "onState",
      [true, false]
      "change",
      "states.brightnessLevel",
      [100, 0]
      "change",
      "states.onOffState",
      [true, false]
device refresh messages
  "list": []
  "objectDict": {}
delete device message
  "message": "delete",
  "objectId": 123456789
Device messages to the server
device refresh requests
  // Specify the object type
device command messages
  "objectId": 123456789,
  "class": "indigo.Variable",
  "description": "",
  "folderId": 0,
  "globalProps": {
  "id": 345633244,
  "name": "house_status",
  "pluginProps": {},
  "readOnly": false,
  "remoteDisplay": true,
  "sharedProps": {},
  "value": "home"
add variable message
  "message": "add",
update variable message
delete variable message
variable refresh messages
variable command messages
updateValue
  "parameters": {
    "value": "Some string value"
  "description": "",
  "folderId": 532526508,
  "globalProps": {
      "speakDelayTime": "5",
  "id": 94914463,
  "name": "Movie Night",
  "pluginProps": {},
  "sharedProps": {
add action group message
  "message": "add",
update action group message
delete action group message
action group refresh messages
action group command messages
This is the WebSocket you'll use for all control page-related communication. You will receive the following messages from the Indigo server during the lifetime of the WebSocket. The control page feed has no command messages you can send to the server; rather, its purpose is to use incoming messages to manage a list of the available control pages which (presumably) the user would select to open that page.
  "backgroundImage": "",
  "description": "",
  "folderId": 0,
  "globalProps": {},
  "hideTabBar": true,
  "id": 963336187,
  "name": "Weather Images",
  "pluginProps": {},
  "sharedProps": {}
add control page message
  "message": "add",
update control page message
delete control page message
  "id": 617272302,
  "class": "indigo.Folder",
  "name": "My Device Folder",
refresh folder server message
The only message you will receive on the log feed will be an add message for every new log entry:
  "message": "add",
  "objectDict": {
    "message": "Stopping plugin \"Web Server 2025.1.0\" (pid 1020)",
    "typeStr": "Application",
    "typeVal": 0
You can also send messages to the log feed from your websocket client with the following payload:
  "messageText": "My log message.",  // required
  "message": "indigo.server.log",  // required
  • /v2/api/indigo.devices - endpoint to get a list of devices
  • /v2/api/indigo.devices/123456789 - endpoint to get a specific device instance (See Device Objects below)
  • /v2/api/indigo.variables - endpoint to get a list of variables
  • /v2/api/indigo.variables/123456789 - endpoint to specific variable object (See Variable Objects below)
  • /v2/api/indigo.actionGroups - endpoint to get a list of action groups
  • /v2/api/indigo.actionGroups/123456789 - endpoint to get a specific action group (See Action Group Objects below)
  • /v2/api/command - endpoint to send Indigo a command (device control, variable update, action execution).
Getting All Device Objects
import json
with urlopen(req) as request:
    print(device_list)
const http = require("https")
const options = {
  headers: {
  let result = ""
    result += chunk;
  response.on("end", () => {
    console.log(deviceList);
import json
DEVICEID = 123456789
    print(device_instance)
const DEVICEID = 123456789
const options = {
  headers: {
  let result = ""
    result += chunk;
    console.log(deviceInstance);
Controlling an Indigo Device
import json
message = json.dumps({
    "objectId": DEVICEID
}).encode("utf8")
    reply = json.load(request)
    print(reply)
const options = {
  path: "/v2/api/command",
  method: "POST",
  headers: {
  let result = ""
    result += chunk;
req.write(message)
req.end()
import json
  "objectId": DEVICEID,
  "parameters": {
    "value": 50,
    "delay": 10
}).encode("utf8")
    print(reply)
  "parameters": {
    "value": 50,
    "delay": 10
const options = {
  method: "POST",
  headers: {
  let result = ""
    result += chunk;
req.write(message)
req.end()
Getting All Variable Objects
import json
    print(variable_list)
const options = {
  headers: {
  let result = ""
    result += chunk;
    console.log(VariableList);
import json
    print(var_instance)
const VARID = 123456789
const options = {
  headers: {
  let result = ""
    result += chunk;
    console.log(varInstance);
Updating a Variable's Value
import json
VARIABLEID = 123456789
  "objectId": VARIABLEID,
  "parameters": {
}).encode("utf8")
    print(reply)
const VARIABLEID = 123456789
  "parameters": {
const options = {
  method: "POST",
  headers: {
  let result = ""
    result += chunk;
req.write(message)
req.end()
import json
    print(action_group_list)
const options = {
  headers: {
  let result = ""
    result += chunk;
    console.log(actionGroupList);
Executing an Action Group
import json
ACTIONGROUPID = 123456789
  "objectId": ACTIONGROUPID
}).encode("utf8")
    print(reply)
const options = {
  method: "POST",
  headers: {
  let result = ""
    result += chunk;
req.write(message)
req.end()
Device Objects
Example device object
  "blueLevel": null,
  "brightness": 0,
  "configured": true,
  "deviceTypeId": "",
  "displayStateValRaw": 0,
  "displayStateValUi": "0",
  "enabled": true,
  "errorState": "",
  "folder": {
    "id": 1552926800,
    "name": "Insteon",
  "globalProps": {},
  "greenLevel": null,
  "id": 1508839119,
  "ledStates": [],
  "onState": false,
  "ownerProps": {},
  "pluginId": "",
  "pluginProps": {},
  "redLevel": null,
  "sharedProps": {},
  "states": {
    "brightnessLevel": 0,
    "onOffState": false
  "version": 67,
  "whiteLevel": null,
indigo.device
  "parameters": {
    "delay": 5,
    "duration": 10
  "parameters": {
    "delay": 5,
    "duration": 10
  "parameters": {
    "delay": 5,
    "duration": 10
  "parameters": {
    "delay": 5,
    "duration": 10
  "parameters": {
    "delay": 5,
    "duration": 10
  "parameters": {
    "value": True,
indigo.dimmer
  "parameters": {
    "by": 5,
    "delay": 10
  "parameters": {
    "by": 5,
    "delay": 10
  "parameters": {
    "value": 50,
    "delay": 10
indigo.iodevice
  "parameters": {
    "index": 5,
    "value": true
indigo.sensor
  "parameters": {
    "value": true
indigo.speedcontrol
  "parameters": {
    "by": 2,
    "delay": 5
  "parameters": {
    "by": 2,
    "delay": 5
  "parameters": {
    "value": 2,
    "delay": 5
  "parameters": {
    "value": 50,
    "delay": 5
indigo.sprinkler
  "parameters": {
  "parameters": {
    "index": 2
indigo.thermostat
  "parameters": {
    "delta": 2
  "parameters": {
    "delta": 2
  "parameters": {
    "delta": 2
  "parameters": {
    "delta": 2
  "parameters": {
    "value": 76
  "parameters": {
  "parameters": {
    "value": 76
  "parameters": {
Variable Objects
  "description": "",
  "folderId": 0,
  "folder": {},
  "globalProps": {
  "id": 345633244,
  "pluginProps": {},
  "readOnly": false,
  "sharedProps": {},
  "value": "home"
  "parameters": {
  "description": "",
  "folder": {
    "id": 532526508,
    "name": "Mood Scenes",
  "globalProps": {
  "id": 94914463,
  "pluginProps": {},
  "sharedProps": {
Schedule Objects
You’ll receive full variable JSON objects which represent an Indigo trigger instance. See the Indigo Object Model docs for trigger details.
    "class": "indigo.Trigger",
    "configured": true,
    "description": "A trigger description.",
    "enabled": true,
    "folderId": 12345678,
    "globalProps": {
        "com.indigodomo.webserver": {
            "httpMethod": "GET",
            "postProcessing": "JSON",
            "webhookId": "8aa4b5140c5c473ea170465239143839"
        "emptyDict": {}
    "id": 12345678,
    "name": "My Trigger Name",
    "pluginProps": {},
    "sharedProps": {},
    "suppressLogging": false
Schedule Command Messages
These are the available schedule commands. The id key is optional, but may contain a user generated ID that will be logged and returned to help match up with message requests. Custom id values should be strings.
execute indigo.schedule.execute(123456789)
  "message": "indigo.schedule.execute",
  "objectId": 12345678,
objectId is the id of the schedule.
enable
  "message": "indigo.schedule.enable",
  "parameters": {"value": false}
Trigger Objects
    "configured": true,
    "enabled": true,
    "globalProps": {
        "emptyDict": {}
    "id": 12345678,
    "pluginProps": {},
    "sharedProps": {},
Trigger Command Messages
These are the available trigger commands. The id key is optional, but may contain a user generated ID that will be logged and returned to help match up with message requests. Custom id values should be strings.
  "message": "indigo.trigger.execute",
objectId is the id of the trigger.
enable
  "message": "indigo.trigger.enable",
Example Log Message
  "typeVal": 0
EVENT_TYPES = {
  Application = 0,
  Error = 1,
  Error_Client = 2,
  Warning = 3,
  Warning_Client = 4,
  Debug_Server = 5,
  Debug_Client = 6,
  Debug_Plugin = 7,
  Custom = 8,
Log Command Message
import requests
API_KEY = "MY_API_KEY"
message = {
    device_list = response.json()
    print(device_list)
Plugin Command Messages
restart plugin
    "message": "plugin.restart",
    "pluginId": "com.some.indigo.plugin"   # the plugin's bundle identifier
Execute Plugin Action
    "pluginId": "com.some.indigo.plugin",   # the plugin's bundle identifier
    "actionId": "some_plugin_action",  # the ID of the plugin action found in the plugin's Actions.xml file [string]
    "deviceId": 12345678,  # the device ID targeted by the plugin action (not all actions will require a device ID). [int]
    "props": {"prop1": "foo", "prop2": "bar"},  # required if the plugin action requires props to fire the action [valid JSON]
    "waitUntilDone": True  # optional [True/False]
Generic Error Message
  "validationErrors": {
Example API Call
  "parameters": {
    "value": 1234.56
Resulting Error Message
  1. message,
  2. objectId,
  3. parameters, and
  4. value
Invalid JSON
Example Invalid JSON Message
  "error": "invalid JSON"
Web Server Warnings
Code Condition Description
200 OK or Success Indicates that the request has succeeded.
400 Bad Request Indicates that the server cannot or will not process the request due to something that is perceived to be a client error (for example, malformed request syntax, invalid request message framing, or deceptive request routing)
401 Unauthorized Indicates that the client request has not been completed because it lacks valid authentication credentials for the requested resource.
404 Not Found Indicates that the server cannot find the requested resource.
500 Internal Server Error Indicates that the server encountered an unexpected condition that prevented it from fulfilling the request.
Other Errors and Warnings
  • /www/perceptive/wiki/data/attic/indigo_2025.1_documentation/api.1769974819.txt.gz
  • Last modified: 2026/02/01 19:40
