Indigo Web Server
Security Certificates
Select the Indigo 2025.1→Advanced Web Server Settings… menu item and you'll get this dialog:
Web Server Settings Dialog
The menu has three options:
/Library/Application Support/Perceptive Automation/Indigo 2024.1/Web Assets/images
/Library/Application Support/Perceptive Automation/Indigo 2024.1/Web Assets/plugins
/Library/Application Support/Perceptive Automation/Indigo 2024.1/Web Assets/public
/Library/Application Support/Perceptive Automation/Indigo 2024.1/Web Assets/static
images folder
plugins folder
public folder
For example:
static folder
For example:
Authentication
API Keys
Local Secrets
    "here-is-a-key",
    "this*is*another*key"
    "here-is-a-key",
    "this*is*another*key",
    "do-not-use-api-keys"
Custom Web Page Example
<!DOCTYPE html>
<html lang="en">
  <head>
    <meta charset="utf-8">
  </head>
      Hello world.
    </div>
  </body>
</html>
The Indigo Web Server is a complex piece of the Indigo ecosystem, but it rarely has issues. There are some things that have happened in the past and we thought we'd outline some debugging steps here.
Websocket Failures
In rare circumstances, problems may arise that cause an inability to connect to Indigo's Websocket API. This will often manifest as Indigo Touch for Web hanging at the Loading page. Here are some troubleshooting tips that should get you back in business.
Enable Diagnostic Tools
Webserver Debug Options
In the Indigo client UI, go to Indigo > Advanced Web Server Settings… and enable Debug Logging. In rare circumstances you may need to enable Cache Debug Logging as well. This logging may provide some useful details.
Browser Debugging
Enable console debugging in your browser. The steps vary depending on the browser you're using, but in Safari go to Settings > Advanced > Show features for web developers. You should now see a Developer tab in settings and on the main Safari menu. Head to Develop and select Show Javascript Console. Now trying to load Indigo Touch for Web and see if there are any errors shown in the console log (Indigo Touch for Web uses JavaScript to render the various pages).
Script Debugging
If you're having trouble getting a Python, JavaScript or other code to connect, it's best to add a lot of logging and error trapping to your code which will help to isolate any issues. You can always turn off or remove extra logging when you're done.
Make Sure You Have the Right Websockets Version Installed
Each new version of Indigo is tested against a specific version of the websockets library and having a different websockets version can potentially cause problems. If you can't connect to the server using Indigo Touch For Web, the websockets library may be causing some trouble. To check which version of the websockets library you have installed, open a terminal window and run the following command:
pip3 show websockets
To see which version should be installed, head over to Python Packages and Indigo and follow the instructions there. Also, note that you may have multiple version of Python installed, so you'll want to make sure you're using the right pip by specifying the full version (pip3.11, pip3.13, etc).
Make Sure You're Using the Right Security Layer
The security settings you chose when you started the Indigo Server affect how you connect to the web server.
Security Protocols
HTTPS enabled must use links that start with https:// and wws://
HTTPS not enabled must use links that start with http:// and ws://
Another diagnostic tool you can try is to attempt to connect to the server using simple, known methods to try to isolate the issue. There are sample websocket scripts near the top of the Integration APIs page. These scripts will attempt to make a simple connection to the websocket API.
Review Your Network Configuration
Some networking configurations can impact your ability to attach to the Indigo Server using the API endpoints. You should ensure that you're not blocking IPs or ports that you're trying to connect with. If you're running your traffic through a VPN, blocking or filtering traffic through applications like Little Snitch or PiHole, make sure these programs aren't blocking the traffic. Make sure that your Indigo Server and client are both on the same network (including subnet). Also check to ensure that nothing else is trying to use the port you're using with Indigo.
Other Potential Issues
There are other issues that may arise with the Indigo Web Server. If you are having issues outside of the above, then you can use the next sections to help diagnose what might be causing them.
Check Your Hosts File
Sometimes, hosts file settings can cause conflicts. Review your hosts file (do not make changes unless you know what you're doing) to see if anything looks like it might be rerouting your connection. The hosts file is typically located in /etc/hosts. It should only contain lines similar to this:
  127.0.0.1       localhost
  255.255.255.255 broadcasthost
  ::1             localhost
If you have other declarations, especially for localhost, then that might be interfering with normal Web Server operation. We recommend commenting out any lines that are not the above lines to debug any issues you may have.
Check Your Server's Network Connection and Settings
Assuming your server machine is able to connect to your network, check to ensure that the server machine isn't connecting with both wired and wireless connections. This can sometimes cause issues with network traffic. It's generally best to stick to one connection method.
Try Local and Reflector Connections
If you can't connect locally, you still may be able to connect with the Indigo Reflector service. The reverse is also true. If you can connect via one method but not the other (both should work under normal circumstances) that may help you isolate the issue.
Disable Firewalls and Virus Protection
Sometimes various firewall products (including macOS built-in firewall) can block different types of network connections. Virus Protection software can be especially bad about interfering with network traffic. While troubleshooting it's recommended to disable all such software on your Mac.
  • /www/perceptive/wiki/data/pages/indigo_2025.1_documentation/indigo_web_server.txt
  • Last modified: 2026/02/04 23:03
  • by jay
