Install the FTDI VCP Drivers
Connecting the Interface
- Choose
Indigo 2025.1→Preferences…menu, then make sure theInterfacestab is selected. - Select the
INSTEON/X10 Power Line Interfaceline in the table (you can also get to this dialog by selecting theInterfaces→INSTEON/X10 Power Line→Configure…menu item) - Choose your
- Optionally select the
To add a new Insteon device:
- Press the
New…button at the top of the Home window and selectINSTEONfrom theTypepopup.
Resyncing Links
Use this dialog to resync a device when its links have been altered outside of Indigo. You may be asked to use this dialog by technical support when troubleshooting device problems.
Replacing a Device
Managing INSTEON Links
The INSTEON protocol has linking built-in as part of its core functionality. The idea is that one device, a controller in INSTEON speak, can be linked to another device, a responder, then from that point forward the controller device sends its command directly to the responder device. So, for instance, you can link a KeypadLinc button to a SwitchLinc so that when you press the button on the KPL the SwitchLinc responds. That's normally done by pressing various buttons on each device in specific ways until the link is established.
Managing INSTEON Device Links
- Select the
Defining the Scene
- Choose
Executing the Scene
- Select the
Scenepopup item.
INSTEON Link Syncing
Resetting your PowerLinc
- Release the button
- In Indigo, select the
Sync Linksbutton
Replacing Your PowerLinc
Execute Raw INSTEON Command
Set Motion Sensor Timeout
Set LED Brightness
if insteonPlugin.isEnabled():
actionProps = dict()
Configure SynchroLinc
Set I/O Linc Momentary Mode
Set Siren Alarm Sound
Set Siren LED Mode
Set OutletLinc Load Sense
Troubleshooting
If you can't get a device to sync, follow these steps:
- Hold down the shift & option keys while selecting the Interfaces→INSTEON/X10 Power Line→Configure… menu item
- In the resulting dialog, check the box next to LILO debug logging (leave the dialog open)
- Switch back to the home window and try the define and sync with the AL again - you'll see a lot of debugging information show up in the Event Log window.
- Starting with the first part of the define and sync, copy/paste all the event log lines into an email to [email protected].
- Switch back to the INSTEON Debugging window and uncheck the LILO debug logging checkbox (and close the dialog)
