Back to Top
Folder Structure Image
in this location:
Back to Top
Bundle Layout Image
<plist version="1.0">
<dict>
    <key>PluginVersion</key>
    <string>1.2.3</string>
    <key>ServerApiVersion</key>
    <string>2.0</string>
    <key>CFBundleIdentifier</key>
    <key>CFBundleVersion</key>
    <string>1.0.1</string>
    <key>CFBundleURLTypes</key>
    <array>
        <dict>
            <key>CFBundleURLName</key>
        </dict>
    </array>
</dict>
</plist>
Back to Server Plugins
Server Plugin Folder Image
  • cannot contain spaces.
<ConfigUI>
    <Field id="autoLabel"
            type="label"
            visibleBindingValue="false">
    </Field>
    <Field id="exampleButton"
            type="button"
        <Title>Find Node ID</Title>
    </Field>
    <Field id="nodeID"
            type="textfield"
            readonly="YES"
        <Label>Node ID:</Label>
    </Field>
    <Field type="checkbox"
            id="manualEntry"
            defaultValue="false">
    </Field>
    <Field id="manualNodeID"
            type="textfield"
            visibleBindingValue="true">
        <Label>Enter Node ID:</Label>
    </Field>
</ConfigUI>
Text Field
    <Label>Text Field:</Label>
</Field>
Back to Configuration Dialogs
Configuration UI Menu Image
	<Label>Popup Menu:</Label>
</Field>
</Field>
    return valuesDict
List
COnfiguration UI List Image
	<Label>List:</Label>
</Field>
Dynamic Lists
</Field>
Dynamic List Attributes
Attribute Required Notes
Dynamic List Filters
Class: indigo.devices
Optional Filters Description
indigo.relayrelay devices
indigo.dimmerdimmer devices
indigo.sprinklersprinklers
indigo.thermostatthermostats
Class: indigo.triggers
</Field>
	return myArray
</Field>
</Field>
Serial Port
Checkbox
	<Label>Checkbox:</Label>
</Field>
</Field>
    return valuesDict
Label
Configuration UI Label Image
	</Label>
</Field>
Separator
<Field id="simpleSeparator1"
		type="separator"
		visibleBindingValue="1"/>
Button
Configuration UI Button Image
		type="button"
		visibleBindingValue="1">
</Field>
The process flow is this:
    <Name>Music Server</Name>
    <ConfigUI>
            <Title>Begin Pairing</Title>
        </Field>
<!-- SNIP -->
</Device>
    return valuesDict
Color Picker
<Field id="exampleColorPicker" type="colorpicker" tooltip="Click this button to select a color.">
    <Label>Color:</Label>
</Field>
UiValuesDict : (dict)
     instructions :  (string)
type Yes 2.0 This must be colorpicker.
Validation Methods
    return True
    return (True, valuesDict)
    errorDict = indigo.Dict()
Validating serialport Fields
    errorsDict = indigo.Dict()
    if len(errorsDict) > 0:
Dialog Close Notification
Dialog Type Method Signature
<?xml version="1.0"?>
<PluginConfig>
</PluginConfig>
/Library/Application Support/Perceptive Automation/Indigo 2025.2/Preferences/Plugins/
Custom HTML Config Dialogs
Device Types
Name Type Required Notes
        <ConfigUI>
            </Field>
        </ConfigUI>
            <State id="temperature">
    </Device>
Device Sub-Types
In Devices.xml
Device Subtype Example Image
In Python:
newdev.name = u"Device 1"
Custom Device Type
        <ValueType>Number</ValueType>
    <State id="heatSetPoint">
    <State id="coolSetPoint">
    <State id="mode">
Device Factory
<DeviceFactory>
    <ConfigUI>
        </Field>
            <Label>Name:</Label>
        </Field>
    </ConfigUI>
</DeviceFactory>
<DeviceFactory>
    <ConfigUI>
        </Field>
        </Field>
    </ConfigUI>
</DeviceFactory>
    <ConfigUI>
        </Field>
        </Field>
            <Label>Setting:</Label>
        </Field>
    </ConfigUI>
        <State id="state">
            <ValueType>String</ValueType>
</Device>
        <State id="state">
</Device>
        <State id="state">
</Device>
    new_dev.subModel = "Dimmer"
    new_dev.replaceOnServer()
    new_props['name'] = my_name
    new_dev.subModel = "Lock"
<Events>
    <Event id="updateAvailable">
    </Event>
</Events>
<Event id="sep1"/>
<Actions>
    <Action id="resetInterface">
        <Name>Reset Interface</Name>
    </Action>
</Actions>
</Field>
<Action id="sep1"/>
configured : True
     config_prop_1 : 123 (integer)
     config_prop_2 : true (bool)
textToSpeak :
def writeToLog(self, action):
    if theType:
        indigo.server.log(theMessage)
%%v:12345%%
%%d:12345:someStateId%%
into their string where 12345 is the ID of a device and someStateId is a valid state identifier, the call will return a string with all device state occurrences substituted. See the substitutions docs for more information.
  • None None,
  • booleans bool,
  • integers int(),
  • floats float(),
  • strings str(),
  • Indigo Dicts indigo.Dict(),
  • Indigo Lists indigo.List().
    return some_value
   completeHandler = None
      # called from another thread.
      # via:
   except Exception, exc:
<MenuItems>
    <MenuItem id="menu1">
    </MenuItem>
    <MenuItem id="menu2">
    </MenuItem>
    <MenuItem id="menu3">
        <ConfigUI>
			<Label>Light:</Label>
		</Field>
        </ConfigUI>
    </MenuItem>
    <!-- Added in v1.2 -->
    <MenuItem id="menu4">
    </MenuItem>
</MenuItems>
def checkForUpdates(self):
        menu_items = indigo.Dict()
        if menu_id == "my_menu_id":
        return menu_items
Custom HTML Menu Item Dialogs
General Plugin Methods
__init__(self,
         pluginId,
         pluginDisplayName,
         pluginVersion,
         pluginPrefs)
__del__(self)
def __del__(self):
startup(self)
def startup(self):
The startup method supports a return value: don't return anything (or return None explicitly) - your plugin will start up<html><br></html>- return True - your plugin will start up<html><br></html>- return False - your plugin stops with a default message <html><br></html>- return a string - your plugin stops with that string as the message<html><br></html>- return anything else - plugin stops with a default message
shutdown(self)
def shutdown(self):
runConcurrentThread(self)
    while True:
        # Do your stuff here
        self.sleep(60) # in seconds
except self.StopThread:
    # do any cleanup here
    pass
stopConcurrentThread(self)
    self.stopThread = True
prepareToSleep(self)
wakeUp(self)
Device Specific Methods
getDeviceStateList(self,
                   dev)
getDeviceDisplayStateId(self,
                        dev)
deviceStartComm(self,
                dev)
deviceStopComm(self,
               dev)
                            origDev,
                            newDev)
deviceUpdated(self,
              origDev,
              newDev)
deviceDeleted(self,
              dev)
getDeviceConfigUiValues(self, pluginProps, typeId, devId)
No This method will get called whenever an Device configuration is opened. Indigo will look for this method and, if it exists, will pre-populate the configuration dialog with the information created/modified in the method. This method is particularly helpful when you want an Device's configuration to be different from the default (set in the Device configuration XML file). A simple example is provided below.
Here is an example of the getDeviceConfigUiValues method's mechanics:
def getDeviceConfigUiValues(self, pluginProps, typeId, devId):
        valuesDict = indigo.Dict(pluginProps)
        if len(valuesDict) == 0:
            if typeId == "foo":
                valuesDict["bar"] = "123"
        return (valuesDict, errorsDict)
Trigger Specific Methods
triggerStartProcessing(self,
                       trigger)
triggerStopProcessing(self,
                      trigger)
                                   origTrigger,
                                   newTrigger)
triggerCreated(self,
               trigger)
triggerUpdated(self,
               origTrigger,
               newTrigger)
triggerDeleted(self,
               trigger)
Schedule Specific Methods
Action Group Specific Methods
Name Required Notes
 getActionConfigUiValues(self, pluginProps, typeId, devId)
No This method will get called whenever an Action configuration is opened. Indigo will look for this method and, if it exists, will pre-populate the configuration dialog with the information created/modified in the method. This method is particularly helpful when you want an Action's configuration to be different from the default (set in the Actions configuration XML file). A simple example is provided below.
Here is an example of the getActionConfigUiValues method's mechanics:
def getActionConfigUiValues(self, pluginProps, typeId, devId):
            if typeId == "foo":
Variable Specific Methods
Name Required Notes
variableCreated(self, var)
variableDeleted(self, var)
Helper Methods
                                bundleID)
browserOpen(self,
            url)
debugLog(self,
         msg)
errorLog(self,
         msg)
openSerial(self,
         ownerName,
         portUrl, baudrate, bytesize,
         parity, stopbits, timeout,
         dsrdtr, interCharTimeout)
other args - all other arguments are passed directly to the pySerial's Serial constructor
sleep(self,
         seconds)
substituteVariable(self,
                   inString,
                   validateOnly=False)
String
if validateOnly is False
(BOOL, errStr)
if validateOnly is True
%%v:VARID%%
substituteDeviceState(self,
                      inString,
                      validateOnly=False)
String
(BOOL, errStr)
%%d:DEVICEID:STATEKEY%%
substitute(self,
           inString,
           validateOnly=False)
Properties
Property Value Type Notes
pluginFolderPath
pluginSupportURL
Attribute Description
self.indigo_log_handler
Embedded Script Logging Image
self.plugin_file_handler
Log Levels
class MyClass(object):
    def __init__():
Custom IndigoLogHandler
exc_info
    x = 1 / 0
Full Example
import logging
def __init__(self):
        x = 1 / 0
    except ZeroDivisionError:
Which yields:
    x = 1 / 0
import logging
  • If for some reason you can't include the header, you may pass the API key as an additional GET argument on the URL (https://myreflector.indigodomo.net/message/PLUGINID/actionId/?other=args&api-key=KEYHERE)
Plugin API scripting can be a great way to add useful features to your plugin. For example, you could create a path for an external script to communicate with your plugin to provide status information or fire a trigger. We have provided a complete example below.
    <Name>some message</Name>
</Action>
Notice that the uiPath=“hidden” attribute will keep the action from displaying in the Indigo UI, but it will still be callable by your users using the URL structure shown above. Using the hidden attribute is optional but it is recommended for actions that are meant to be used solely as an API (otherwise, they will appear in Indigo's list of available actions.
Here's how an action method is defined in your plugin:
    return some_value
Key Value
file_path this will be a list of path parts from the URL after the action ID. So for the url: http://host/message/pluginid/actionid/path/to/some/file.txt the value will be an indigo.List with the following items: [“path”, “to”, “some”, “file.txt”]
KeyValue
StatusMeaning
KeyValue
Usage Guidance
  • Binary data - the API isn't designed for binary data
Here is a generic example that includes all the necessary parts of a plugin API interaction.
Plugin
Your plugin needs to define an Indigo Action to receive the data.
</Action>
Your plugin needs to define a callback method to do something.
    some_value = action.props["someKey"]  # this is from the incoming API request
    some_other_value = action.props["someOtherKey"]
    # the reply must be valid JSON or an indigoDict() object
    reply = indigo.Dict()
    reply["content"] = some_other_value * 2
    reply["status_code"] = 200
    return some_result
The Request
The caller needs to construct a valid request.
import httpx
MY_API_KEY = "abcd1234efgh"  # obtained through the user's Indigo account
MY_REFLECTOR = "someReflectorID"  # the name of the user's server machine on their Indigo account
PLUGIN_ID = "com.something.myPlugin"
ACTION_ID = "handle_message"  # The ID from Actions.xml (not an Action object ID number)
# The payload must be valid JSON. The API does not support binary encoding and payloads should be of a reasonable size.
payload = {
    "someKey": 1,
    "someOtherKey": 2,
    "field3": 3,
my_url = "https://MY_REFLECTOR.indigodomo.net/message/PLUGIN_ID/ACTION_ID/?other=payload&api-key=MY_API_KEY"
response = httpx.get(my_url, verify=False)
print(f"{response.status_code}")
print(f"{response.text}")
my_url will contain the response of a successful call (if the action returns a response) or an error if the call was unsuccessful (error codes above). Using the above example, the resonse will include 24,691,356 or “someOtherKey” * 2.
    ###### TURN ON ######
        if send_success:
    ###### TURN OFF ######
        if send_success:
    ###### STATUS REQUEST ######
Back to Top
Indigo 2025.2 includes a variety of popular 3rd party Python libraries which are described on the Python Packages page. Any changes to the libraries installed will be detailed there. You should not make changes to the packages that Indigo installs. If you need a different package version, you should include it within your plugin package distribution.
  • /www/perceptive/wiki/data/pages/indigo_2025.2_documentation/plugin_guide.txt
  • Last modified: 2026/05/04 23:49
