Airfoil Pro
Airfoil is a great application from Rogue Amoeba that allows you to stream sound from your Mac or Windows computer to any combination of Airplay Devices, Bluetooth speakers, and Airfoil satellite clients (iOS, Android, Mac, Windows, Linux) - and it keeps it all in sync. Many Indigo users use it in conjunction with Apple TVs, Airport Expresses, and other computers and iOS devices to create whole-home audio systems, all streaming from your Mac/Windows computer running iTunes or other music applications.
Adding an Instance
Add Airfoil Instance Image
  • machineIconAndScreenshot.png - a screenshot from the host computer with the machine icon overlaid (though this functionality seems to be missing in Airfoil versions through v5.1.0 - you just get the same image as the machine icon)
Airfoil Edit Group Image
Airfoil instances are actually a group of devices: the instance itself (the first tab), and then multiple speaker devices, one for each speaker device that your instance knows about. We set the name of the Airfoil Instance to the Airfoil name. For each speaker, we name the speaker with this pattern: “Speaker Name (Airfoil Instance Name speaker)” to help you see how the devices relate to each other. We also add a note to each speaker device with a bit more detail about its relationship to its parent Airfoil Instance device.
Airfoil Triggers Image
Warning: due to changes that Apple has made to their API, the Source Status Is Playing trigger will no longer fire. This trigger option will be adjusted in a future release.
States available to Scripts
Notes
Each Airfoil Instance device has a collection of “Speaker” devices in its group. These are all the various outputs to which Airfoil can direct its source audio. These devices are created automatically when you create your Airfoil Instance and any time a new source gets added to the instance. For instance, if you create an Airfoil Instance and it finds 3 speakers, then at a later time you add a Bluetooth speaker to the Mac that Airfoil is running on, the plugin will automatically create a new speaker device for that Bluetooth speaker.
We never automatically delete speakers: if you have a Bluetooth speaker that fails, and you won't ever use it again, you'll need to remove it manually.
name string The name of the speaker in Airfoil (which is different than its name in Indigo)
type string (local, airplay, Bluetooth, group) The type of speaker
Action Menu Image
You may also note that the action calls are inside a try block. If you specify waitUntilDone=True in your action call, you may catch an exception if something happened during the action execution. The exception message will explain in a human-readable string what occurred.
Connect Speaker
Scripting details
Action id: connect
if airfoilPlugin.isEnabled():
            "connect",
            waitUntilDone=True
    except Exception as e:
Disconnect Speaker
Scripting details
Action id: disconnect
            "disconnect",
            waitUntilDone=True
Toggle Speaker
Scripting details
Action id: toggle
            "toggle",
            waitUntilDone=True
Save Current Speaker States
This action will save the connection state for each speaker on the selected Airfoil device. This is useful if you need to temporarily change the state of some speakers, but you want to be able to easily, set them back to how they were before the change. You can optionally specify that Airfoil Group states also be saved though this option is usually not very useful since storing the current state of all speakers will usually accomplish the same as restoring a group.
Scripting details
Example 1 (no groups):
            "saveCurrentSpeakerStates",
            waitUntilDone=True
Example 2 (include groups):
            waitUntilDone=True
Restore Saved Speaker States
Scripting details
            "restoreSavedSpeakerStates",
            waitUntilDone=True
Set Volume
Scripting details
Action id: setVolume
            'setVolume',
            props={'volume': 50},
            waitUntilDone=True
Increase Volume
Scripting details
Action id: increaseVolume
            'increaseVolume',
            waitUntilDone=True
Example 2 (specifying delta):
            'increaseVolume',
            props={'volume': 15},
            waitUntilDone=True
Decrease Volume
Scripting details
Action id: decreaseVolume
            'increaseVolume',
            waitUntilDone=True
            'decreaseVolume',
            waitUntilDone=True
Disconnect All Speakers
Scripting details
            'disconnectAllSpeakers',
            waitUntilDone=True
Change Source
Scripting details
Action id: changeSource
            "changeSource",
            props=props,
            waitUntilDone=True
Save Current Source
Scripting details
Action id: saveCurrentSource
            "saveCurrentSource",
            waitUntilDone=True
Restore Saved Source
Scripting details
Action id: restoreSavedSource
            "restoreSavedSource",
            waitUntilDone=True
Toggle Play/Pause
Scripting details
Action id: playPause
            'playPause',
            waitUntilDone=True
Next Track
Scripting details
Action id: nextTrack
            'nextTrack',
            waitUntilDone=True
Previous Track
Scripting details
Action id: prevTrack
            'prevTrack',
            waitUntilDone=True
getSources
Action id: getSources
            'getSources',
     audioDevices : (list)
          Item : (dict)
               icon : [SNIP]
          Item : (dict)
               icon : [SNIP]
          Item : (dict)
               icon : [SNIP]
     recentApplications : (list)
          Item : (dict)
               icon : [SNIP]
          Item : (dict)
               icon : [SNIP]
    systemAudio : (list)
    	  Item : (dict)
    	  	   icon : [SNIP]
  • /www/perceptive/wiki/data/pages/indigo_2025.2_documentation/plugins/airfoilpro.txt
