Indigo Scripting Tutorial
Talking to the Indigo Server
The Indigo Plugin Host (IPH) provides a python scripting and plugin environment, which makes controlling the Indigo Server easy via the high-level python language (the official python website has great python tutorials). Every plugin automatically runs inside its own Indigo Plugin Host process, but you can also start the IPH in an interactive mode to directly communicate with the Indigo Server. It is a great way to experiment with Indigo's python environment, which is available to both python scripts run by Indigo and the plugin architecture.
– or –
If you already have a Terminal shell running, you can launch it directly. The file path to the IPH executable is a bit deep, so create an alias to it inside your .bashrc (or .bash_profile) file by copying/pasting this into the Terminal (you only need to do this once!):
echo "alias indigohost='/Library/Application\ Support/Perceptive\ Automation/Indigo\ 5/IndigoPluginHost.app/Contents/MacOS/IndigoPluginHost'" >> ~/.bashrc
Next, close the Terminal window and open a new one to load the shortcut alias to the IPH executable. To start the IPH in interactive mode we pass the -i flag to it inside the Terminal:
indigohost -i
As shown, the IPH will automatically connect to the IndigoServer running on the same Mac and will show the server's version information. Additionally, you'll notice that Indigo Server logs the connection of the interactive shell plugin.
Connecting Remotely over SSH
ssh username@indigo_mac_ipaddr -t "/Library/Application\ Support/Perceptive\ Automation/Indigo\ 5/IndigoPluginHost.app/Contents/MacOS/IndigoPluginHost" -i
What Else Can it Do?
indigohost -e 'return indigo.devices["office lamplinc"].brightness'
indigohost -e '
Caveat: Each call creates a new IPH (indigohost) process which must establish a connection to the Indigo Server. Although this is relatively fast, calling it multiple times a second is not recommended.
Executing Indigo Python Files
indigohost -x /SomeFolder/indigo_script.py'
Shared Classes and Methods in Python Files (Python Attachments)
In Indigo, if you want to write AppleScript handlers that are shared by any script that Indigo executes, you can just put an AppleScript full of handlers in the /Library/Application Support/Perceptive Automation/Indigo 5/Scripts/Attachments folder. You can do the same thing with Python using a built-in mechanism that Mac OS X supports for Python. There is a folder in the Library folder at the top level of your boot disk that is very similar to the Attachments folder:
/Library/Python/2.5/site-packages
Any Python files in this directory that define methods and/or classes will be loaded by the Python interpreter whenever it's loaded (note that it's the Library directory at the top level of your boot disk, not the one in your user folder). So, you can create files of handlers you want to share between all Python scripts. Files here can also import the entire IOM - IF the script that's actually running is started by Indigo. Here's a simple shell that you can use that will safely import the IOM and will show a specific error when used from a Python script that's not started by Indigo:
#!/usr/bin/env python2.5
indigoAttachments.py
import indigo
except ImportError:
print "Attachments can only be used from within Indigo"
raise ImportError
def specialLog(text):
indigo.server.log(text, type="indigoAttachments")
import indigoAttachments
indigoAttachments.specialLog("Here's a special sort of log message")
FatMac:testdir jay$ python2.5 testHandlerCall.py
File "testCallingIndigo.py", line 3, in <module>
File "/Users/jay/Library/Python/2.5/site-packages/indigoAttachments.py", line 14, in <module>
raise ImportError
ImportError
Scripting Indigo Plugins
Indigo plugins are also scriptable. Because plugin-defined devices look almost identical to built-in devices, you can get (but not set) state information from them (see device examples a bit further down for a lot of examples). You can also get some of the other properties for a plugin. Most importantly you can execute plugin-defined actions, which is how you'd set their state values.
| pluginDisplayName | The name displayed to users in the clients |
| pluginId | The ID of the plugin (same as was passed to the getPlugin() method above) |
| pluginSupportURL | The URL supplied by the plugin that points to its user documentation |
| pluginVersion | The version number specified by the plugin |
iTunes Toggle Play State
if itunesPlugin.isEnabled():
iTunes Set Volume to 50
Example Code Snippets
Below are some example you can copy/paste directly into the Terminal application (running the IPH via the indigohost -i command explained above). Keep in mind these are only examples, so be sure and read over the full Indigo Object Model (IOM) Reference.
Device Examples
indigo.device.duplicate("office desk lamp", duplicateName="office desk lamp2")
indigo.device.turnOn("office desk lamp", duration=2, delay=4)
Turn off all devices:
indigo.device.allOff()
indigo.devices.len()
lamp = indigo.devices["office desk lamp"] if hasattr(lamp, 'onState'): isOn = lamp.onState
lamp = indigo.devices["office desk lamp"] if lamp.__class__ == indigo.DimmerDevice: theBrightness = lamp.brightness
Variable Examples
myVar = indigo.variables[123]
if myVar.value == "true":
Duplicating a variable:
Date and Time Examples
Get the current server time:
indigo.server.getTime()
Action Group Examples
Log Examples
lamp = indigo.devices["office desk lamp"] indigo.server.log(lamp.name + ": \n" + str(lamp))
Folder Examples
except ValueError, e:
myFolder = None
Miscellaneous Examples
Sending emails
# Simple Example
Add examples for:
- refreshing objects
- replacing objects
- enabling/disabling objects
- sprinkler control
- etc.
