Triggers
Trigger Base Class
actions | list of Action | Yes | a list of Action objects (action steps in AS) that are executed for this trigger |
globalProps | dictionary | No | an indigo.Dict() representing all name/value pairs associated with this trigger - each plugin will have its own dictionary (globalProps[pluginId]) - see About Plugin Properties below for details |
id | integer | No | a unique id of the trigger, assigned on creation by IndigoServer - not available in AppleScript |
Commands (indigo.trigger.*)
indigo.trigger.delete(123) |
| Parameters | |||
| Parameters | |||
Enable/Disable Trigger
| Parameters | |||
duration | No | integer | number of seconds before the trigger is switched back to its original state |
Execute Trigger
Tell the IndigoServer to execute the actions associated with the trigger. If you're plugin implements events, this is the method you'd call when the conditions for your specific event are met. If you're calling it this way, make sure you include the ignoreConditions=False parameter (or don't include the parameter since False is the default) so that any conditions associated with the trigger (by the user in the UI) are evaluated.
| Parameters | |||
| Parameters | |||
| Parameters | |||
add examples of updating a trigger's properties
DeviceStateChangeTrigger
In AppleScript, we didn’t describe them particularly well, but basically we use a 1-based index into an array of possible values. So, for an I/O device, for instance, you’d refer to “binaryInput1”, “binaryInput2”, etc. Or for a sprinkler with multiple zones, it would be “zone1”, “zone2”, etc. In the Python API, we’ve made it easier when referencing these events with the introduction of the stateSelectorIndex. It’s the index into list of available “things” represented by the device’s state.
State Change Type Enumeration
| indigo.kStateChange | ||
State Selector Enumeration
| indigo.kStateSelector | |
BinaryOutputsAll | |
HumidityInput | monitor (one of) the humidity sensor(s) available on the device for =, !=, <, >, and any change - stateSelectorIndex is required to be in the range of available inputs |
KeypadButtonLed | |
folder=1234)
| Parameters | |||
| Python | AppleScript |
theTrigger=indigo.devStateChange.create(name="Temp exceeds 80 degrees") theTrigger.deviceId = 738 theTrigger.stateChangeType = indigo.kStateChange.BecomesGreaterThan theTrigger.stateSelector = indigo.kStateSelector.TemperatureInput theTrigger.stateSelectorIndex = 1 theTrigger.stateValue = 80 theTrigger.replaceOnServer() | set theTrigger to make new trigger action with properties {name:"Temp exceeds 80 degrees"}
set theTrigger's trigger type to deviceChanged
set theTrigger's device name to "Main Thermostat"
set theTrigger's state change type to becomesGreaterThan
set theTrigger's state selector to "TemperatureInput1"
set theTrigger's state value to 80
EmailReceivedTrigger
emailFrom | string | Yes | if emailFilter is MatchEmailFields, the value to match against the sender’s address |
emailSubject | string | Yes | if emailFilter is MatchEmailFields, the value to match against the subject line |
Email Filter Enumeration
| indigo.kEmailFilter | |
Commands (indigo.emailRcvd.*)
folder=1234)
| Parameters | |||
theTrigger=indigo.emailRcvd.create(name="Emails from [email protected]") theTrigger.emailFilter = indigo.kEmailFilter.MatchEmailFields theTrigger.emailFrom = "[email protected]" theTrigger.replaceOnServer() | set theTrigger to make new trigger action with properties {name:"Emails from [email protected]"}
set theTrigger's trigger type to emailReceived
set theTrigger's email filter to matchEmailFields
set theTrigger's email from to "[email protected]"
InsteonCommandReceivedTrigger
INSTEON Command Enumeration
| indigo.kInsteonCmd | |
folder=1234)
| Parameters | |||
theTrigger= indigo.insteonCmdRcvd.create(name="KeypadLinc button 1 Any Change") theTrigger.command = indigo.kInsteonCmd.AnyCommand theTrigger.commandSourceType = indigo.kDeviceSourceType.Device theTrigger.deviceId = 43829874 theTrigger.buttonOrGroup = 1 theTrigger.replaceOnServer() | (Can't be created in AppleScript) |
InterfaceFailureTrigger
folder=1234)
| Parameters | |||
theTrigger= indigo.interfaceFail.create(name="Any Interface Failed") | set theTrigger to make new trigger action with properties ¬
{name:"Any Interface Failed", trigger type:interfaceFailure}
InterfaceInitializedTrigger
folder=1234)
| Parameters | |||
theTrigger= indigo.interfaceInit.create(name="Any Interface Initialized") | set theTrigger to make new trigger action with properties ¬
{name:"Any Interface Initialized", trigger type:interfaceInitialized}
PluginEventTrigger
folder=1234),
pluginTypeId="myEvent",
| Parameters | |||
PowerFailureTrigger
folder=1234)
| Parameters | |||
theTrigger= indigo.powerFailure.create(name="Any Interface Detected Power Failure") | set theTrigger to make new trigger action with properties ¬
{name:"Any Interface Detected Power Failure", trigger type:powerFailure}
ServerStartupTrigger
folder=1234)
| Parameters | |||
theTrigger= indigo.serverStartup.create(name="Startup") | set theTrigger to make new trigger action with properties ¬
{name:"Startup", trigger type:startup}
X10CommandReceivedTrigger
AvButton | kX10AvButton | if command = AvButtonPressed, the A/V button to monitor |
X10 Command Enumeration
| indigo.kX10Cmd | |
X10 A/V Button Enumeration
| indigo.kX10AvButton | |
| Value | Value |
0 | Left |
1 | Menu |
2 | Mute |
3 | Pause |
4 | PC |
5 | Play |
6 | Power |
7 | Recall |
8 | Record |
9 | Return |
AB | Rewind |
ChannelDown | Right |
ChannelUp | Stop |
Display | Title |
Down | Up |
Enter | VolumeDown |
Exit | VolumeUp |
Forward | |
folder=1234)
| Parameters | |||
VariableValueChangeTrigger
| indigo.kVarChange | |
folder=1234)
| Parameters | |||
theTrigger=indigo.varValueChange.create(name="Var Changed to True") theTrigger.variableChangeType = indigo.kVarChange.BecomesEqual theTrigger.variableId = 9283749872 theTrigger.variableValue = "True" theTrigger.replaceOnServer() | set theTrigger to make new trigger action with properties {name:"Var Changed to True"}
set theTrigger's trigger type to variableChanged
set theTrigger's variable change type to varBecomesEqual
set theTrigger's variable name to "SomeVarWhoseIdIs9283749872"
set theTrigger's variable value to "True"
