Indigo Mac Client
When you double click on the Indigo 5 icon in the Applications folder, you're actually starting the Indigo Mac Client, which will start up the Indigo Server process according to the options selected in the Start Server dialog.
Home Window
The Home Window is in 5 areas:
- Outline View
- Item List
- Item Detail
- Status Bar
Outline View
The outline view shows all high-level objects (except Variables which have their own window): Devices, Triggers, Schedules, Action Groups, and Control Pages. Selecting one of these in the outline view will switch the Item List to view all of those types of objects. The same goes for folders that are under the high-level headings except only the devices in those folders will show.
To create a new folder, select the main object type in the list then click the plus (+) button at the lower-left corner of the outline view. A new folder will appear and you can just start typing its new name. To delete a folder, select it, then click on the gear icon or right-click the folder (bring up the contextual menu). The resulting menu will allow you to select Delete Folder the delete it. If the folder isn't empty, it will show you a sheet with 3 options: Cancel (do nothing), Delete Items (delete the items in the folder along with the folder), or Move Items (move the items to the parent first then delete the folder).
From the same menu, you can select Rename Folder… to rename it, Enable/Disable Remote Display (for devices, action groups, and control pages) to show/hide it in remote clients (like Indigo Web Server (IWS) pages or Indigo Touch), or copy the unique folder ID for use in Python scripts.
Item List
This menu will:
- Enable/disable the event.
Item Detail
If you have no device selected, only controls that affect collections of devices are shown:
Each of the other device types have their own sets of controls.
Lights/Appliances and Sensors (Motion Sensors, etc)
For lights (dimmers), appliance modules (relays), and sensors (Motion Sensor, TriggerLinc, etc), you see the same details above with some of the others enabled as is appropriate for the device.
iMeter
The iMeter has its own detail area - it shows the current load in watts, total usage (since the last reset) and the date of the last reset. Use the Refresh All button to immediately update the information and the Reset Total Usage button to reset the total usage information.
Sprinklers (Pro Only)
Sprinkler detail allow you to turn on a specific zone, go to the next or previous zone, update the valve status. And, if a schedule is currently running, pause/resume it, begin running the previous schedule, and stop all activity.
Thermostats (Pro Only)
The thermostat detail area shows the current temperature, humidity, mode, cool/heat setpoints, and fan mode. You can also adjust all of those as well as refresh the values and turn everything off. Note that on rev2 thermostat adaptors the circles next to cool and heat setpoints will be lit if their respective HVAC system is actually running (A/C or heater).
Control Input / Output Device (Pro Only)
IO Device detail area shows the state of all the input and output states available for the device and you can update them immediately using the Get Input/OutputStatus button. The Outputs grid shows all available outputs and their status. If you're unfamiliar with the square push buttons on the Mac, when they are light, they are OFF - when they are dark, they are ON. Use the All Off button to turn off all binary outputs.
Plugin Devices (Pro Only)
Because plugin devices can define as many states as they like, we've provided a list of all states and values in the detail area for every plugin device.
Triggers and Schedules
The detail area for triggers and schedules is identical - it shows the triggering event (either a state change or some time/date description), whether the condition is always, rules, or a script, and a summary of actions. The popup will allow you to specify how the object is processed:
The Execute Actions Now button will do exactly that - execute all the actions associated with the object. NOTE: just as the triggering event will be ignored, so will any conditions associated with the object.
Control Pages
Status Bar
Event Log Window
Click the Clear Window button to clear the log entries. Click on Show Event Logs Folder to open the Logs folder in the Finder. Here you will find one file for each day's events. You can change how many day's worth of event log files are stored by selecting Indigo 5→Preferences… and then selecting the General tab. There, you can enter the number of days of event log files that you want to keep. Indigo Server will delete all files outside that period of time.
Variable Window
Preferences Window
In the Getting Started guide, we visited almost all the tabs on the Indigo Preferences window. We did, however, miss the General tab:
Menus
Indigo 5 Menu
About Indigo 5- this will show the About window which will show what client and server versions you're running and what your registration code isStart Local Server…- this will open the Start Server dialogStop Server- this will stop the Indigo ServerConnect to Remote Server…- this option will allow you to connect to a different Indigo server or a server running on another MacClose Connection- this will close the connection to the serverPreferences…- this opens the preferences dialogCheck for Updates…- this will have the server your connected to contact us to see if there is an update available
File Menu
New Database…- this will close the current database and create a new one - you'll be prompted for a name and save locationSelect Database…- this will allow you to switch to a different databaseClose Window- this will close the frontmost windowNew Device…- this will switch the Home Window to the devices view and open the new device dialogNew Trigger…- this will switch the Home Window to the triggers view and open the new trigger dialogNew Schedule…- this will switch the Home Window to the schedules view and open the new schedule dialogNew Action Group…- this will switch the Home Window to the action groups view and open the new action group dialog
Edit Menu
View Menu
Go Menu
Browser Devices Page- this will open your default web browser to the built-in devices listBrowser Actions Page- this will open your default web browser to the built-in actions listBrowser Variables Page- this will open your default web browser to the built-in variable listBrowser Control Pages- this will open your default web browser to the control page list (this option is only available in Indigo Pro)Event Logs Folder- this will open the Event Logs folder in the FinderPurchase Hardware- this will open your default web browser to our online store (the Indigo Store) – if you are running a trial copy this item will be called “Purchase Indigo” and will take you to the Indigo purchase pageOnline Support Forum- this will open your default web browser to our online support forums
Interfaces Menu
Manage Interfaces…- opens the interface preferences
INSTEON/X10 Powerline Submenu
Enable/Disable- toggles the interface on and offConfigure…- opens the configuration preferences for this interfaceUpload Settings…- opens the upload dialogManage INSTEON PowerLinc Links…- opens the PowerLinc link editor windowManage INSTEON Device Links…- opens the device link editor windowStart Sync INSTEON Device Links…- starts any pending link sync operationsStop Sync INSTEON Device Links- stops any ongoing linking operations
X10 RF Submenu
Plugins Menu
The Plugins menu (Indigo Pro Only) will adjust based on the what plugins you have installed. Three menu items will always be present:
Reload AppleScript Attachments- this will reload all the attachment AppleScripts that are in the Scripts/Attachments directory of the Indigo system directory (/Library/Application Support/Perceptive Automation/Indigo 5/)Online User Contribution Library- this will open the file library in your default browser where you can find and download user-contributed plugins, scripts, applications, etc.Open Scripting Shell- this will open a terminal window and start the interactive Python shell with the Indigo module loaded - see the Scripting Tutorial for more information
For information about the plugins, see the About… menu item for each plugin.
Window Menu
Help Menu
Help for Devices- this will change slightly based on what window is selected and what's selected in that window - but it will open the default browser to the page in the help documentation for that particular itemHow-To Wiki- this will also change slightly based on what's selected - it will open to the How-To wiki for the selected item (if a device is selected it will go to the wiki for that device, otherwise it will just go to the landing page)Indigo 5 Documentation- this will open your browser to the landing page for all Indigo 5 documentationGetting Started Guide- this will open your browser to the Getting Started Guide, the place where everyone new to Indigo should startOnline Support Forum- this will open your browser to our support forum - it's very active and is the primary place where you should seek help - we answer questions there very quickly and in fact we have many helpful users that can help as well
