Indigo Overview
Object Definition
Devices in Indigo are “things” that Indigo can interact with. In previous versions of Indigo, they were pretty simple: they were either INSTEON or X10 devices. With Indigo 5, we've added the ability for third parties (and us) to create new kinds of devices that use the same UI and device lists that INSTEON and X10 devices use. This greatly expands the kind of devices that can be defined in Indigo.
There are two primary ways you can use a device in Indigo: you can use changes in it's various states to trigger some actions (e.g. when the motion sensor detects motion) and you can tell a device to perform some action (e.g. turn on the porch light). Indigo also provides you various ways to interactively control these devices and inspect their state (Indigo Touch, Indigo Web Server web pages, etc.)
Here is the device dialog:
We'll get to the device types in just a second, but first let's look at the common fields and buttons. At the top, you have the Name field, which represents the unique name of this device. Next you have the Description field - it's a free-form text field that you can put anything into you want - perhaps to help describe what features you're using.
At the bottom of the dialog, you have the Display in remote UI checkbox which, as it says, lets you see this device in remote client applications.
Under that you have the Enable Indigo communication to and from this device checkbox - this is useful if you have a device that you're temporarily taking out of service or moving. If you uncheck this checkbox, Indigo will not attempt to communicate with it in any way - so you won't receive errors in the Event Log when any action is taken for this device.
First, make sure that Indigo has enabled communication with the interface. If Indigo is not online with the interface, then choose Connect from the Interface menu. See connecting the Interface in the Getting Started guide for more details.
Additionally, make sure you have your Access Point RFs (or SignaLinc RFs) correctly installed on opposite power legs. If the Access Point RFs or other dual-band devices are improperly installed or missing, then you may not be able to control some of your INSTEON devices. See the instructions included with your Access Point RF pair for installation details.
TIP: Access Point RFs do not bridge X10 signals, so if you also have X10 devices you will need an additional bridge.
This is how you initially add an INSTEON device to Indigo. The directions on this dialog are quite self-explanatory. When you click the Start button you'll see the checkboxes turn green when each step is complete, and the Close button will enable when the process is complete. The sync process can take a few minutes to complete. Lamp and appliance devices normally take less than a minute, but KeypadLincs and ControLincs can take a few minutes because of the additional link information needed for all of the buttons.
If the sync process fails or does not complete, then make sure that the device is correctly wired or plugged in, both Access Point RFs are installed and on opposite power legs, and that you do not have an uninterruptible power supply (UPS) or surge protector strip plugged into the outlet the PowerLinc is using. If syncing still fails and the device is portable (ApplianceLinc or LampLinc), then try plugging it directly into the pass through outlet on the PowerLinc. See our website troubleshooting tips for additional help.
The Re-Sync Links… dialog will open the Synchronize INSTEON Device Links dialog:
The last button, Manage Links… is how Indigo allows you to remotely manage INSTEON links (without having to walk around pressing set buttons, etc.) and is discussed in great detail on the Indigo INSTEON Link Management page.
However, you may have a device module not currently listed in the Type popup menu. To use devices that are not defined in the device Type popup, you can click the Definition… button you will be shown the Module Definition dialog:
Along with built-in INSTEON and X10 devices, Indigo ships with plugins that allow you to define iTunes Music servers, EasyDAQ relay boards, and NOAA Weather Stations, etc. Each of these new device types define a set of “states” that you can use in other places: for instance, the iTunes Server device has states that represent the player state (playing, paused, etc), the current album, artist, and track, etc. The EasyDAQ plugin allows you to specify the specific board you have and the state of each relay/DIO.
We hope that eventually you'll be able to find many 3rd party plugins available in our file library that will cover many other types of devices. If you're a programmer and would like to develop plugins, check out our technical documentation section for all the docs you need to get started building Indigo plugins.
Plugins may define events - use the Type Plugin then select the Plugin and the Event to configure the event further.
  • Every X hours Y minutes - this is the typical repeating setting. TIP: you can use fractional minutes if you like (i.e. .5 is every 30 seconds, .25 is every 15 seconds, etc)
There are 17 built-in actions and plugins may also implement actions, so you have a wide variety of things that Indigo can do for you with just a few menu selections and clicks.
Control Light / Appliance
This action will allow you to control a light (dimmer) or appliance (relay) device. There are 13 possible actions, some of which aren't available for every light or appliance device:
  • Send Status Request - send a status request message to the device (only useful for INSTEON and 2-way X10 devices)
  • Beep Device - send a command to the INSTEON device to “beep” the device (only supported on some INSTEON devices)
  • Turn On KeypadLinc Button - tell the KeypadLinc to turn on the button's LED (only supported on late model KPL's)
  • Turn Off KeypadLinc Button - tell the KeypadLinc to turn off the button's LED (only supported on late model KPL's)
Control Sprinkler (Pro Only)
There are seven actions available once you've selected your sprinkler device:
  • Run Schedule - selecting this action will show you the zone table (shown above) that will allow you to set the duration for each zone and optionally multiply those durations by the selected variable. This last option is useful if you change durations based on time of year - you can change the variable value but keep the existing schedule and it'll adjust the duration as appropriate.
Control Thermostat (Pro Only)
There are 12 actions available once you've selected your thermostat:
  • Set Mode - set the mode of the thermostat to one of the following:
    • Fan Auto On - turn the fan on (so it'll continuously run)
    • Fan Always On - set the fan so that it only runs as needed)
  • Get Ambient Humidity - get the humidity
v1 thermostat adaptors didn't broadcast out updates (and Indigo 4 didn't catch the v2 broadcasts) to update it's internal state representations for the thermostats (Indigo 4 polls periodically) - which is why there are so many options to get status. Indigo 5 catches the v2 thermostat update broadcasts so the need to manually get updates should be reduced.
Control Input / Output Device (Pro Only)
There are eight actions available once you've selected your IO device:
Execute INSTEON Scene
Finally, if you need to add, modify, or delete a device from the scene, click on the Modify Scene… button. See the Indigo and INSTEON Link Management page for more details.
Execute Action Group
Execute Script (Pro Only)
Modify Variable
Send Email
Reset Interface Connections
This action will attempt to reset all built-in hardware interfaces. There are no options.
Enable Device
Enable Trigger
Enable Schedule
Disable Device
Disable Trigger
Disable Schedule
Plugin (Pro Only)
For plugin actions, you specify the Plugin: and Action:. If the action requires a device to be selected, you'll be shown the Device: popup and if there is further configuration for the action you'll see an Edit… button. Click on that button and follow the instructions for that specific action.
Action Options
  • Delay by X minutes - this will delay the execution of the action by some number of minutes (you can add fractional minutes as well e.g. .5 is 30 seconds, etc.)
To create a new action group:
  4. Optionally give the group a Description.
  5. Select the action Type: and select the various options. (See the actions section above for details on all of the action's settings, and information on how to add additional actions to the Action Group)
Control pages are custom graphical pages that you can use to control Indigo, either through the browser or Indigo Touch. You design the page - from the background image and/or color to the placement of text labels, control images, and what actions clicking/tapping on those images performs.
This is where you set global information about the page itself. The Page Name: and Description: fields are pretty self-explanatory. Check the Hide Tab Bar at bottom of Indigo Touch when shown to have the bottom navigation bar hidden when this page is viewed in Indigo Touch. You can use a Background image: by selecting it from the popup, such as a floorplan or other image. You can add your own image by creating a PNG file and adding it to the backgrounds folder (to open that folder in the Finder just click the Show Folder button - and if you add an image while Indigo is running, click the Refresh button to have it added to the popup).
  • iPhone/iPod touch
  • iPad
Device State
Variable Value
Static Image/Caption
Refreshing Image URL
Server Status Text
Server Status Icon
Client Actions
  1. Popup UI Controls - this will cause the client to pop up a dialog with the controls appropriate for the device or variable selected (it doesn't do anything for other page element types)
  2. Link to Control Page - this will cause the client to display the selected control page so it's useful to navigate between control pages. The Open in new window checkbox really only effects viewing pages in a browser, not Indigo Touch
  3. Link to URL - this will cause the client to open the provided URL in a browser window (a new browser window if the Open in new window checkbox is checked).In Indigo Touch, it will cause Mobile Safari to open and show the page specified by the URL.
Server Actions
Variables are used to hold information that can help your home automation logic. For instance, Indigo ships with an AppleScript which stores weather information in variables. You can use that information to display on control pages, as part of your conditional logic (see Conditions below), or as a trigger for some other action.
If you right-click a variable, you can toggle the Remote Display attribute or copy the variable id to the clipboard (for easy pasting into scripts).
  2. if it's too cold outside
All of the following rules are true
	If variable windows_open is false
	If variable outside_temp is greater than value "40"
	If variable rain_total is less than value "0.75"
  • /www/perceptive/wiki/data/pages/indigo_5_documentation/overview.txt
