Indigo is a powerful home control server that integrates an assortment of popular INSTEON and X10 hardware devices to provide control of your home. Depending on your needs and budget, you can create a simple system that controls only a couple of lights or you can automate your entire home.
We recommend that you read through all of the help topics under the Getting Started section. These will help you setup Indigo and gain a familiarity with the application.
Indigo comes in two versions: Indigo Pro and Indigo Lite. There are several places in the documentation where you'll see (Pro only feature) - that indicates that the feature/function being described is only available to Indigo Pro users.
Aside from the Indigo 5 documentation page, you should also visit our web site for valuable support resources:
If you do not have the required hardware, you can still use the software in offline mode.
Indigo can run as a standalone application on a single Mac or can be run in a client/server mode on two or more Macs. In either case, you must first run the Indigo installer on the main Mac (also referred to as the server Mac) to which the home automation interface hardware (PowerLinc, CM11, etc.) will be connected.
The Indigo 5 application can be found here:
/Applications/Indigo 5
/Library/Application Support/Perceptive Automation/Indigo 5/
Database files are stored in the Database
folder in that folder.
Note: this is the Library folder at the top level of your hard drive, not the one in your User folder. Lion and greater hide these folders by default, but if you select the “Go→Go to Folder…” menu item in the Finder and paste in the path above it will open that folder in a Finder window.
Time Machine will do this by default. To recover, just recover that directory and then install Indigo 5 again.
Scripts:
Control Page Images:
Web Server Plugins:
NOTE: Do not replace the Indigo 5 versions of the files with your Indigo 4, 3, or 2 files. They have been modified to run optimally under Indigo 5.
[USERHOMEDIRECTORY]/Documents/Indigo User Data/Scripts/
) to the new folder specified above if you modified or added new script or script attachment files.NOTE: Do not replace the Indigo 5 versions of the files with your Indigo 1.x files. They have been modified to run optimally under Indigo 5.
NOTE: this is not the Library folder that's in your home directory - it's the one at the top level of your hard drive. The easiest way to get there is to select the “Go→Go To Folder…” menu item in the Finder and paste in this:
To uninstall Indigo, make sure that you have the server and client completely shut down (select “Stop Server” from the “Indigo 5” menu before you quit the Indigo Mac Client). Then, delete the following files:
The first three directories are at the top level of your hard drive. The last four are in the Library folder that's in the home directory of the account Indigo runs under. In Mac OS X Lion, the Library folder is hidden in the Finder so you'll have to use the “Go to Folder…” menu item in the Finder and type in the path (“~/Library/Preferences”). That will open a Finder window to the Preferences folder. The last three aren't really required to uninstall but they are included for completeness.
Indigo can run as a standalone application on a single Mac or can be run in a client/server mode on two or more Macs. Regardless of which you are doing, the first step after installation is to launch Indigo and configure the local server.
Indigo 5
application (/Applications/Indigo 5).Indigo 5
button in the connection status window.Indigo 5→Start Local Server…
menu item.
If you only have one Mac and do not wish to remotely access Indigo from a Web browser, iPhone, or iPod Touch, then you can choose the Run client/server as single application
radio button. This will automatically run the client/server as a single application, avoiding some complexity.
Uploading to the PowerLinc 1132CU or 2414U for operation while your Mac is turned off is supported in both standalone and client/server mode. In standalone mode the built-in Web server will not be started and you will not have remote Web browser access to control Indigo. NOTE: Indigo Server must be running to use Indigo Touch or to access the Indigo Web Server.
Choose the Start and connect to Indigo Server
Use the Allow remote access
checkbox to enable remote access from other Macs and Web browsers.
Use the Enable iPhone, iPod Touch, and remote Web browser access
checkbox to allow Indigo Touch (must be downloaded from the iTunes App Store) and remote Web browser access from other computers. Any modern Web browser (Safari, Firefox, Opera) on any computer that has internet access to your server Mac will be able to control and check the state of your home.
Use the Enable remote RSS feeds
checkbox to turn on the RSS and Atom server feeds, giving you RSS/Atom access to the last modified time stamp of all Indigo Devices.
Use the Require authentication
checkbox to enable password protection for both remote Indigo Clients and Web browser access. It is highly recommended that you enable authentication and assign a strong password.
Use the Enable anywhere secure access
checkbox for secure Web browser access from anywhere. This option requires a subscription to the Prism Reflector service, which handles maintaining the secure connection to Indigo Server automatically.
checkbox to allow remote Indigo Clients on other Macs to connect to the Indigo Server (Pro only feature).
checkbox to change the TCP/IP port number that the Mac OS X client uses to connect to the server (Pro only feature).
Use the Log Device state history to SQLite or PostgreSQL
checkbox to efficiently save Indigo Device state changes, Variable value changes, and Event Log messages to a SQLite or PostgreSQL database. Visit the online support forum for installation and configuration instructions (Pro only feature).
Press the Start Server
button, or the Restart Server
If this is the first time you've started the server, you'll be prompted first to click through our Enduser License Agreement (EULA), then you'll see the server registration dialog:
Enter you name and registration code exactly as they appear in your registration email (copy/paste works best) and click OK. The server will continue to start up.
If you purchased a retail disk, you should enter your full first and last name along with the registration code exactly as it appears on the label on the disk sleeve. When you click OK you'll be prompted to register your copy on our website:
While this isn't required, it's highly recommended. If you don't, we won't be able to locate your registration code in the future should you need it again - and you will to get discounted upgrades to major new releases and access to dot releases.
If you desire easy remote Indigo Server access from outside your home, then you may want to subscribe to the Prism Reflector service, which provides secure Indigo Touch and remote Web browser access from anywhere with no network configuration needed. A free trial subscription is available for all Indigo customers.
In order to remotely access the Indigo Server we must enable the ports Indigo Server uses in the system's network firewall. Follow these steps on the Mac running Indigo Server.
Indigo 5→Stop Server
menu item.Apple Menu→System Preferences
menu item.Security
preference panel.Firewall
tab.Set access for specific services and applications
radio button.Indigo 5→Start Local Server…
menu item and pressing the Start Server
button.IndigoServer.app
and Python.app
. Press the Allow
button for each.The Indigo Web Server advertises itself via Bonjour, so Indigo Touch and Safari (by clicking on the bookmarks icon, then selecting Bonjour) will automatically find any local servers. In addition to that, when connecting to a local server for the first time, Indigo Touch will also automatically fetch Prism Reflector settings for that connection so that you'll be able to connect outside your LAN via Edge/3G.
For other browsers to remotely access the Web server, we need to know the network IP address for the Mac running Indigo Server. This address will be used on the remote Mac or Web browser when connecting to the Indigo Server. Follow these steps on the Mac running Indigo Server.
menu item.Sharing
preference panel.File Sharing
is not turned on, then temporarily enable it.afp://xxx.xxx.xxx.xxx/
IP address
is the number portion of the URL (ex: 192.168.1.23
).System Preferences
window.You now have the IP address for the Mac running Indigo Server. Depending on your home network setup, this IP address may change periodically, such as when the Indigo Server Mac or router is restarted. If this happens, then you can use the steps above to discover the IP address again, or you can configure a static (not dynamic) IP address for the Mac running Indigo Server.
Indigo 5
application (inside /Applications/Indigo 5
) on the remote Mac.Indigo 5
on this remote Mac, then press the Connect to Remote Server… button in the connection status window.Indigo 5→Connect to Remote Server…
menu item.IP address
button.NOTE: the Indigo Mac Client doesn't use the Prism Reflector service. Connecting an Indigo Mac Client to a server over the internet is a complex topic that is well beyond this document – we suggest you search our online forums for others that have configured this type of access.
Indigo Touch, the iPhone and iPod Touch application from Perceptive Automation, allows the user to view and control Devices, activate Action Groups, view Variables, and access custom Control Pages (Pro only feature). One of the best features of Indigo Touch is it's ability to automatically detect and configure network connections. If your iPhone (or iPod Touch) is connected to your local wireless LAN, then it should automatically discover your server. In Indigo Touch, tap the Settings
At this point, Indigo Touch will also query the server to see if you have a Prism Reflector account set up for the server. This makes connecting to your home server via Indigo Touch completely seemless. If you have a reflector set up and running, then Indigo Touch will automatically attempt to connect no matter where you are or how you're connected. If you're local, it will use the local wireless LAN, If you're on a remote wireless LAN, it will attempt to use the reflector account. If you're on you iPhone on EDGE/3G, it will also attempt to connect via your reflector account. This makes Indigo Touch truly location agnostic!
on the Settings
Indigo, when run in client/server mode, will automatically start its built-in Web server on launch. This allows access from remote Macs, PCs, and other internet devices like the iPhone, iPod Touch, Nokia 770 and PepperPad. Any device that can run a modern Web browser (Safari, Firefox, Opera) will work.
http://192.168.1.23:8176/
Alternatively, if you already have the Indigo Client on a remote Mac connected to the Indigo Server, then you can use Indigo's Go→Browser…
menu items to open a new browser page pointing to the built-in Web server.
Indigo can communicate with dozens of different home automation modules, providing control of lighting, lamps, appliances, sprinklers, thermostats and more. Indigo communicates with these INSTEON and X10 compatible modules by using one of several computer interfaces: PowerLinc (2412U, 2412S, 2414U, 1132CU, 1132U), CM11/CM12/HD11/HD12, ActiveHome Pro (CM15A), or LynX-PLC. These interfaces directly communicate with the modules by receiving and sending INSTEON or X10 signals on your power lines.
Different interfaces support different protocols and module features. For example, Indigo can currently upload compiled logic to the PowerLinc 2414U and 1132CU, but not the CM11. We highly recommend INSTEON interfaces and modules over X10 because of their increased signal reliability, performance, and features.
Looking to get started quickly? We've partnered with our online reseller to put together some terrific starter packages.
For specific questions or discussions on hardware, we recommend you join us on our online forum.
Some modules require that you leave Indigo running (and your Mac on) in order to be controlled. Most of the lighting and appliance modules can be controlled after your Mac is turned off when using a PowerLinc 2414U, if you have defined simple Time/Date Actions or Trigger Actions that are upload compatible with the PowerLinc's capabilities.
As an alternative to INSTEON hardware, dozens of X10 modules are also supported by Indigo. Some modules require that you leave Indigo running (and your Mac on) in order to be controlled. Most of the lighting and appliance modules can be controlled after your Mac is turned off when using a PowerLinc 2414U / 1132CU, if you have defined simple Time/Date Actions or Trigger Actions that are upload compatible with the PowerLinc's capabilities.
Dimming may not be accurate for some module types, especially when the PowerLinc is operating in standalone mode (Mac is turned off).
Once you have chosen an INSTEON or X10 interface, see the Connecting the Interfaces section for installation and configuration directions.
RF wireless X10 modules (motion detectors and remote controls) require either a plug-in transceiver (V572AB, TM751, or EZX10RF) or a computer interface that can receive the RF commands, such as: W800USB, W800RF32, MR26, or CM15. There are two different approaches you can use for wireless communication:
For information about connecting and using the W800USB, W800RF32 or the MR26a RF receiver, see the Connecting X10 RF Interfaces section.
The PowerLinc 2414U/1132CU/1132U and CM15A interfaces can be plugged directly into your computer. The Indigo installer automatically installed the drivers for these interfaces. Make sure you have restarted after the installation process. If you reinstall your OS, then you will need to rerun the Indigo installer for the driver.
The PowerLinc 2412U, 2413U, and 2448A7H interfaces can be plugged directly into your computer as well but require the FTDI Virtual COM Port (VCP) driver to be installed (as does the W800USB mentioned above). You can get the driver installer at FTDI's web site - be sure to get the installer that's appropriate for the architecture of your machine (Intel or PowerPC). If you select PowerLinc 2412U/2412S/2413U/2413S/2448 from the Interface type
with a separate USB to serial adapter, you can ignore that warning alert.
The other supported interfaces (PowerLinc 2412S/2413S, CM11 / HD11, LynX-PLC) are serial based, and will require a USB serial port adapter. If you are using one of the serial based interfaces, then make sure that the latest drivers for the USB serial adapter are installed on your system. Look on the adapter manufacturer's website for the latest driver downloads.
See the choosing hardware section for details on the supported INSTEON and X10 interfaces and the supported control modules.
Plug the interface directly into an outlet. Do not plug the interface into your computer's power strip because many power strips contain filters that will severely degrade the INSTEON / X10 signal quality being received and transmitted by the interface. Additionally, uninterruptible power supplies (UPSs) can cause signal quality problems. If at all possible plug the interface into a different outlet than used by power strips and UPSs. Signal filters are available to isolate computer power strips and UPSs as well.
Indigo is pre-configured to recognize and use the PowerLinc 2414U/1132CU/1132U interfaces but not the other PowerLinc models. If you are using the PowerLinc 2414U/1132CU/1132U, then you can skip to the Enabling and Disabling Communication section below by choosing the Interface→Connect
menu item. Depending on the PowerLinc, Indigo may have to upload information and synchronize with it, which can take a couple of minutes. If you receive an error or are using a different interface model, then manually configure the interface.
Indigo 5→Preferences…
menu, then make sure the Interfaces
tab is selected.Enabled
checkbox next to the INSTEON / X10 Powerline Interface
item.Interface type
in the popup menu.Serial port:
popup menu will be disabled because these interfaces do not use a virtual serial port driver.Serial port:
popup menu will be enabled and the FTDI driver (see Install the Correct Drivers above) will create a new Serial port:
popup menu item that looks like usbserial-XXXXXXXX
. Select that item. NOTE: you must have the FTDI driver installed already.Serial port:
popup menu will be enabled and you should choose which serial port adapter name the interface is connected to in the Serial port:
popup menu. NOTE: if no names are listed in the Serial port:
popup menu, then you probably do not have the proper driver installed for your USB serial adapter. Download your adapter's driver from the driver manufacturer's website.Group addresses on transmission
checkbox to combine like-command transmissions together. For example A1-On, A3-On, A4-On, would be transmitted as A1, A3, A4, On.
Choose the Interfaces→INSTEON/X10 Powerline>Disable
menu item to disable/enable the powerline interface.
The process for connecting X10 RF Interfaces is basically the same as for powerline interfaces - you just need to select the correct serial port. The W800USB will require installing the FTDI drivers mentioned above.
Indigo can upload Time/Date and Trigger Actions to the PowerLinc 2414U and 1132CU interfaces, allowing you to have basic home control even when your Mac is not turned on. This is ideal for users that cannot leave their computer on 24/7 or are going out-of-town and want minimal control without a computer.
Indigo has powerful and extensible home control logic and scheduling capabilities. Not all of Indigo's control logic and schedule settings (Trigger Actions and Time/Date) are capable of being run by a standalone interface, such as the PowerLinc. As detailed below, Indigo will describe in the Upload Settings dialog what logic and schedules are compatible to be uploaded to the active interface.
Interfaces→INSTEON/X10 Powerline→Upload Settings…
menu item. If the menu item is not enabled, then make sure that you have the correct Interface type selected and enabled in the preferences dialog.Upload
checkboxes for all the actions you want uploaded to the Interface.
Note to the right of the Upload
checkbox column there is the Compatibility column. Actions labeled as:
good
are fully supported by the interface.okay
will translate and upload, but the interface does not fully support some of the action’s settings. For example, the PowerLinc 1132CU interface only supports Time/Date actions with sunset and sunrise offsets of +/- 60 minutes. Therefore, any amounts larger (or smaller) than this will be capped to the range the PowerLinc understands. See the Compatibility Details
column for detailed information about how each trigger, condition, or action will be translated.poor
will not translate at all and will not be uploaded to the interface regardless of the Upload
checkbox setting. For example, a Trigger Action that sends an email cannot work at all from within an interface. See the Compatibility Details
column for detailed information about why the trigger, condition, or action cannot be uploaded.
Indigo will keep the interface synchronized with your changes by automatically uploading actions whenever you quit the Indigo Client. If you press the Upload Actions
button to immediately upload the actions, then Indigo will connect to the interface, upload the compiled actions, and disconnect. TIP: The USB cable must be connected to the Mac and the PowerLinc for this procedure to work correctly.
If you are already connected to the interface, then the Indigo Server itself (not the interface) will continue to control your home automation logic and schedules. Whenever Indigo Server is stopped or told to disconnect from the interface, it will automatically activate the PowerLinc's standalone mode so that your uploaded logic is internally handled by the PowerLinc itself.
TIP: If you want the PowerLinc to operate in standalone mode, you should never disconnect the USB cable from your Mac before the Indigo Server (not the client) shuts down (or disconnects from the interface) - doing so will not allow Indigo to instruct the PowerLinc to begin functioning in standalone mode and none of your schedules or triggers will work correctly.
Indigo has built-in support to both send and scan (Pro only feature) emails. Using this functionality, Indigo can provide remote notification of triggers, such as motion detection or power failures. You can also control Indigo remotely. For example, you could send Indigo an email from your mobile phone to turn on lights or change your home's thermostat temperature.
Typically, ISPs or other email service providers allow multiple email addresses for each customer. We recommend that you create a new email address specifically for Indigo, such as jetsons-house@myisp.com. Using a separate email address for Indigo will eliminate the possibility that Indigo might trigger an action from a personal email not intended for Indigo, and will allow you to use the Delete from server
options shown below to reduce mailbox clutter.
menu item, then make sure the Email
tab is selected.Reply-to email address
field. Note that some SMTP mail servers are configured to not send emails unless the reply-to address specified matches the email address for the account. If mail sending fails, then make sure that the reply-to email address matches the email address for your account.Indigo 5→Preferences…
tab is selected.Check email every
checkbox.Delete from server emails that trigger actions
to have Indigo automatically remove any email messages that cause Indigo to trigger an action from your mail server. You should only use this option if Indigo has a dedicated email account.Delete from server all emails
to have Indigo automatically remove all email messages from your mail server. You should only use this option if Indigo has a dedicated email account.Once the Preferences dialog is closed, Indigo will automatically connect to your mail server to scan messages. This will happen within 10 seconds from the time the Preferences dialog is closed. Watch the progress bar in the main window and look for error messages in the Event Log Window to verify that Indigo was able to correctly connect.
To have Indigo send an email, create a Send Email
action.
To execute an action based on a scanned email, create an Email Received
trigger (Pro only feature).
System Preferences
from the Apple
menu.Date & Time
icon.Time Zone
panel.Closet City
Indigo 5→Server Preferences…
checkbox.Latitude
and Longitude
coordinates.
The General
tab in the Indigo Preferences window allows you to configure what types of update checking Indigo will perform for you, Event Logging options, etc.
For optimal use of Indigo and reliable continuous control of your home, the following operating system settings should be verified. If you are not using Indigo to provide continuous 24 hour/day control or if you are using an interface that supports uploading like the PowerLinc 2414U or 1132CU, then you can ignore the following instructions.
System Preferences
from the Apple
menu.Energy Saver
icon.Computer sleep:
slider to Never
checkbox.Congratulations! You should now have a basic functioning Indigo installation that's ready for you to start adding devices and defining your home automation logic. We suggest that you next go to the Overview of Devices, Triggers, Schedules, Action Groups, Control Pages, and Variables - that will give you the information you need to begin using the features of Indigo.
